ronin7
Urgestein
- AMD Ryzen 9 7950X3D, 16C/32T (WC watercooled, vddsoc 2.1v, cpu vddio 1.3v, 42-60°C)
- ASUS ROG Crosshair X670E Hero (WC chipset watercooled, 42-45°C)
- Watercool Heatkiller IV Pro Nickel
- 32GB DDR5-6000 Corsair Dominator Platinum CL30-36-36-76 (Iceman watercooled, 1mm wlp, Expo II, 30°C)
- GeForce RTX 4090 Zotac Gaming AMP Extreme AIRO 24GB, @2.750Mhz (ALC watercooled, wireview, 35-45°C)
- 37.5" Alienware AW3821DW, IPS, 1ms, 144 Hz, NVIDIA G-Sync Ultimate, Ergotron HX Monitorhalterung
- 2x Samsung 980 Pro 2TB (ALC watercooled, 1/0,5mm wlp, 31°C), 860 Pro 2TB
- Opt. Laufwerk
- LiteOn iHBS112-115
- Soundkarte
- Creative Soundblaster AE-7, Denon PMA-60 Amp, 2x Canton Chrono 502.2 Speaker, Canton AS 85.2 SC Sub
- Lian Li PC-G70 Aluminium, gedämmt
- beQuiet Dark Power Pro 12 1200W
- Keyboard
- Corsair K95 RGB Platinum Keyboard (Brown Switches)
- Mouse
- Razor Deathadder Chroma, 2x Xbox One Wireless Controller
- Windows 11 64 Bit
- Sonstiges
- AC Aquaero 6 Pro, Quadro, Watercool Heatkiller Clear Softtubes 13/10, 2x Loop (CPU/RAM 184l/h & GPU/SSD/MB 134l/h: WC Mora3 420/NF-A20 PWM, Heatkiller Tube 200, AC Laing D5 mit WC Cover, Highflow Next
Unter Einstellungen --> Info kannst du es erneut holen.
ne da will es es nicht bringen. denke da kommt es erst wenn vodafone es verbreitet.
