XTaZY
aka h0schi
- Ort
- HD
- Desktop System
- RAW
- Laptop
- Apple Macbook Air M1
- AMD Ryzen 9800X3D
- Asus Strix B650E-I
- Custom-Loop
- 32GB Crucial Pro DDR5-6000
- Nvidia RTX 5070 Ti
- Dell AW3225QF
- Samsung 9100 Pro & 960 Evo 1TB
- Soundkarte
- Onboard
- LOUQE RAW S1
- Corsair SF750
- Keyboard
- Mechanisch !
- Mouse
- Lemokey G2
- Windows 11 Pro
- Sonstiges
- Aquaero 6 LT
- Internet
- ▼1000 MBit ▲50 MBit
LSI hat eine neue Firmware released ( 4.10 P2 Firmware ).
Hab sie dem Firmware-Pool hinzugefügt.
(05.03.2013_LSI_12.13.0-0154)
Download:
Code:
LSI Corp. MegaRAID Firmware Release
Release date: 03/05/13
Supported Controllers:
MegaRAID SAS 9260-4i
MegaRAID SAS 9260CV-4i
MegaRAID SAS 9260-8i
MegaRAID SAS 9260CV-8i
MegaRAID SAS 9260DE-8i
MegaRAID SAS 9261-8i
MegaRAID SAS 9280-4i4e
MegaRAID SAS 9280-8e
MegaRAID SAS 9280DE-8e
MegaRAID SAS 9280-24i4e
MegaRAID SAS 9280-16i4e
MegaRAID SAS 9260-16i
******* This firmware supports Cachecade Pro 2.0 (if activated) for the controllers mentioned above.
******* This single firmware image can be used on all of the controllers mentioned above (no longer need separate image for the high-port-count controllers).
Component:
SAS MegaRAID Firmware Release for MegaRAID Controllers
Version Numbers:
Current Firmware Package (with CacheCade Pro 2.0): 12.13.0-0154 (Merged)
Firmware 2.130.383-2315
Medusa_Expander SAS2XFW-25.05.04.00_MFGIMG-25.05.04.00
NVDATA 2.09.03-0045
BootBlockCommon 09.250.01.219
BootBlock 2.02.00.00-0000
ROMENV 1.08
WebBIOS 6.0-51-e_47_Rel
PCLI 4.04.20
UEFI_Driver 0x05270000
Hii 1.36.00
BIOS 3.27.00
FCODE 4.12.05.00
Previous Firmware Package (with CacheCade Pro 2.0): 12.13.0-0151 (Merged)
Firmware 2.130.383-2230
NVDATA 2.09.03-0041
ROMENV 1.08
PCLI 4.04.20
Hii 1.36.00
BIOS 3.27.00
FCODE 4.12.05.00
Bug Fixes and Enhancements:
Firmware:
SCGCQ00307050 Defect Not able to flash both 9265-8i and 9285-8e card with 5.3 patch 1 firmware.However, it is ok on 9266-8i.
SCGCQ00338490 Defect Invalid target ID after new logical drive creation
SCGCQ00341791 Defect Support for mutlipath topology is broken
SCGCQ00361303 Defect On iMR FW update caused card to FW fault state and card cannot boot to OS.
SCGCQ00371477 Defect During Reconstruction (R0->R5) when system reboots the reconstruction doesnt resume. System hangs.
SCGCQ00375250 Defect OEM BMC see clock stetching on I2C bus
SCGCQ00375854 Defect adapterOperations.alarmControl is being set to 1 even if controller doesnot have alarm on board
SCGCQ00384381 Defect Drive temperature is shown very high on 9240
SCGCQ00391094 Defect 9260-16i's drive locate/fault LED header doesn't work
SCGCQ00392062 Defect Firmware halts when flashing components other than app.rom for OEM controller
SCGCQ00392063 Defect PL library and files checkin for PL version 5.38
SCGCQ00396335 Defect 9260-16i's drive locate/fault LED header is not working properly.
SCGCQ00363619 EnhancementRequest Set the Recovery mode page (WriteRetryCount and recoveryTimeLimit)
Installation:
Use MegaCLI or StorCLI to flash the SAS controllers. These tools can be downloaded from the support and download
section of www.lsi.com.
Command syntax:
MegaCli -adpfwflash -f mr2108fw.rom -a0
or
StorCLI /c0 download file=mr2108fw.rom
Download:
