[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
und wenn es speedfan kann, kann es auch ein bios.
ich hab ein aquaero, mir soll es egal sein. aber diese arroganz seitens der mobo-hersteller find ich übel
Kann ich nachvollziehen;)
Abit war aber klar der beste Mobo - Produzent seiner Zeit.
Hatte selbst div. NF-7
Dann stelle ich malwieder eine dumme Frage. Sorry aber hier kennt sich jeder besser aus. ^^
Warum sind die ganzen Lüfter 4-Pin, wenn sie nicht regelbar sind? Ist das icht sinnlos?
PWM ist lediglich eine andere Art der Ansteuerung von Fans :d es heißt nicht 4 PIN = Regelbar
Google das Ganze einfach mal ^^
+ Man kann im prinzip jeden Lüfter regeln entweder per Voltage direkt oder über die Rate bei PWM's.
Das Board kann aber trotzdem nur 2 "Header" steuern daran wird sich nix ändern ^^
++ hier steht auch noch was interessantes dazu
http://www.heise.de/ct/hotline/PWM-Luefter-322024.html
Ich meine mal gelesen zu haben das bei PWM (4 Pins) der Lüfter ganz schnell an und ausgeschaltet wird in gewissen Frequenzen. (Daher Rateneinstellung in %)
Bei normalen Voltage Fans (3 Pins) liegt dauerhaft eine Spannung an. (kann auch durch erhöhen bzw. verringern "gesteuert" werden)
Ich glaube noch mehr vereinfachen kann mans nich ;)
Warum aber nur 2 Kanäle steuerbar sind ist vermutlich, wie ich schonmal schrieb, ein reiner Kostenfaktor.
Wie PWM die Drehzahl steuert wusste ich, aber das mit PWM z. B. der Temperatursensor im Lüfter angesprochen werden kann, habe ich erst aus deinem Link rausgefunden.
ne, sowas gibts auch nicht. Ist im (5 Jahre alten) Link etwas missverständlich geschrieben, es bleibt alles wie gehabt: CPU-Temp wird vom Bios ausgelesen und dann wird der Lüfter je nach gemeldeter Temp und hinterlegter Logik schneller oder langsamer geschaltet. Der Lüfter selber hat keinerlei Temp-Sensoren (er hat ja auch keinen Kontakt mit der CPU), diese wären sowieso nicht ohne Weiteres verwertbar. Die Steuerung via PWM ist u.a. deutlich zuverlässiger beim Anlaufen, die 3-Pin Lüfter sind da aufgrund unterschiedlichster Schwellen und Trägheiten unberechenbarer.
pwm braucht auch weniger saft bzw erhitzt die spawas nicht zu sehr. ein heatmaster (pwm) kommt im gegensatz zum aquaero ("normale stromversorgung") sogar mit 2 geregelten laings gänzlich ohne kühlung aus, während der AE da schon weggeschmolzen ist
Wollte jedenfalls nur mal berichten, dass durch den Switch auf Asus hier wieder alles tip top im grünen Bereich ist.
Ich hätte auch gewechselt, wenn mein Board rumzicken würde, mein UD5H läuft aber mit dem BIOS F7 ohne irgendwelche Probleme.
Hatte mal vor einigen Jahren ein MSI Board, das hab ich nach 3 Monaten ausgemustert, weil ich mich nicht jeden Tag darüber ärgern wollte.
Habe jetzt ein Z77MX-D3H, aber der Via VT2021 macht zicken. Ich kann Front-Kopfhörer und Rear-Audio nicht getrennt voneinander verwenden. Also Spielesound aus den Boxen und Kopfhörer für's TS.
Hat da jemand ne Lösung?
...mit einem neueren treiber (z.b. 6.0.1.10500 vom 12.07.2012) und der deck-software sollte es gehen...
mein ud3h lief eigentlich sorgenfrei, hatte dann das 12h/12d mit mod und ohne mod geflasht, aber letztenendes doch wieder zum 12d zurück. aber seit tagen hab ich 1-2s mousefreezes, flash-videos schmieren ab, beim runterfahren BSOD's, und dabei blieben die einstellungen die alten. hoffe mal, dass mit einem cmos-clear bzw f7 wie von jz empfohlen wieder getan ist.
kann bisher entwarnung geben. cmos clear + f7 sowie neuester gpu-treiber lassen es wieder smooth laufen. dafür hat sich der usb-hub verabschiedet, manchmal klemmt das keyboard. wenn ihr mich fragt, ist dieser mix aus via + intel ursache sämtlicher usb-probleme
ich habe jede Menge Probleme mit dem Z77-UD5H Wifi
i7 3770k
G.Skill TridentX DIMM Kit 8GB PC3-19200U CL10-12-12-31 (DDR3-2400) (F3-2400C10D-8GTX)
Gigabyte GV-R797OC-3GD F2
GA-Z77X-UD5H-WB WiFi Bios z.Z. F10a JZ Mod
Samsung SSD 830 Series 128GB
Intel X25-M G2 Postville 120GB, 2.5", SATA II
Asrock Sata 6 Card
Pioneer BDR-207D
NT: Corsair Professional Series HX850 850W ATX 2.3 (CMPSU-850HX)
1. XMP Profile gehen nicht mehr ab F10a wenn die Timings und Spannung nach XMP Profil von Hand eingegeben werden. G.Skill TridentX DIMM Kit 8GB PC3-19200U CL10-12-12-31 (DDR3-2400) (F3-2400C10D-8GTX)
2.keine dieser Sata Karten läuft richtig bei PC Start und das Bios ist total instabil beim Start wenn diese Karten verbaut sind (einzeln oder alle)
1a.Digitus DS-30104 (Marvell 88sx7042) PCIe 4x
2a.Digitus DS-30102 (S.Image 3132) PCIe 1x
3a.Asrock Sata 6 Card PCIe 1x
1a. verbaut im PCIe 4x Slot unten es werden von Channel nur 2 angezeigt ( Channel 0 und 1)
2a. funktioniert tadellos wenn in keinem anderen PCIe 1x Slot eine Karte verbaut ist (Fw: r7703) allerdings kommt man oftmals nicht in das Raid Bios wenn die Eingabe möglich sein soll "F4" es muss gleich nach einschalten des Boards "F4" gedrückt werden.
Wenn eine andere der oben genannten Karten in irgendeinen der leeren 2 PCIe 1x Slots oder 8x Slot verbaut wird findet die DS-30102 keine HDD mehr
3a.Die funktioniert nur sporadisch richtig. Die Firmware der Karte hängt ewig bei "Initialisierung" und in Verbindung mit den anderer 2 genannten Karten im (einzeln oder zusammen)
unter Windows sind alle Karten dann da und funktionieren, zumindest sind die angeschlossenen HDD da und ansprechbar.
Biose von F6 - F10a incl. Mod Biose JZ bei Allen das Gleiche Problem mit den Sata Karten. XMP Problem nur mit F10a incl. JZ Mod.
UEFI und Win7 Boot
Es wird ständig nicht ordentlich gebootet. Dieser Vorgang kann schon mal Minuten dauern bevor „Starting Windows“ angezeigt wird. Die Boot Reihenfolge wurde manuell im Bios festgelegt natürlich.
Nur mit „F12“ geht es fix aber da fehlen auch oftmals ein Teil der Laufwerke im Boot-Menü.
Es kommt nach einschalten der Sart Screen und dann blinkt der Cursor Oben links eine ganze Weile das kann bis zu 1 Min 30 Sekunden dauern. Dabei sucht das Bios alle HDD nach Boot Sektoren ab (Wahrscheinlich). Wenn es die Win7 dann gefunden hat kommt „Starting Windows“ ohne die Animation und es passiert 2-3 Minuten nichts dann geht’s plötzlich weiter als wäre nichts gewesen und Win7 fährt hoch.
Das geschieht auch in Standard Settings ohne die Sata Karten und XMP Aktivierung= Board Bios alles auf „ F7“ Opti. Default mit eingestellter Boot Reihenfolge und unabhängig von der Bios Version F6 – F10a.
Es gibt aber auch lichte Momente wo das Board sofort in 22 Sek. Bis ins Windows ohne Nachhilfe brauch aber das kommt selten vor. Von 10 Starts gehen 2 -3 flott.
Ich hab auch schon andere Ram Kits getestet und auch mit diesen sind all diese Probleme da.
Das Problem Z77-UD5H wurde auch Kreuz getestet durch ein Z-77- UD5H um einen technischen Defekt des Board auszuschließen.
Auch die Sata Karten funktionieren nach Spezifikation einwandfrei auf GA-X58A-UD5 Rev.2.0 ,GA-EX58-UD5 Rev. 1.0, GA-A75M-UD2H Rev.1.0 fehlerfrei einzeln und in Kombination.
Amazon schickt mir über Nacht noch ein Asus P8Z77-V Deluxe zu mit dem ich diese ganze Geschichte nochmals testen werde.
Bohne02
UPDATE: Ich hab das Asus P8Z77-V Deluxe jetzt am laufen mit Identischen Zusatzkomponenten und was soll ich sagen es läuft.
Ich habe weder Probleme mir USB 3.0 Hubs,HDD,G15,G700 und auch gar keine mit den SATA Pcie Karten alles funktioniert reibungslos.
Zum Beweis das nur das Board verändert wurde hänge ich wieder eine Report von aida64 an.
Also was soll das Gigabyte? Ich will kein ASUS auch wenns bestens funktioniert!
cu Bohne02
  • Report.zip
  • Report 2.zip
Yep, das vermute ich auch.
Ich benutze die beiden ports neben dem PS2 für Maus und Tastatur, welche an einem aktiven Usb-Hub hängen.
Mein altes 890 FXA UD5 hat damals schon rumgezickt, weil Gigabyte als einziger (?) Hersteller die 5v-SB Spannung vom Netzteil für die USB-Ports nutzt, daher auch meine Frage erneut:
@JZ
Ist das immer noch so?
@JZ
Hallihallo,
hab ein clear cmos mit dem ud3h @ 12h durchgeführt kann nun nach neu parametrierung den intel management treiber sauber installieren. ich hoffe damit haben sich auch die anderen Probleme (Freeze) erledigt. :)
---------- Post added at 00:58 ---------- Previous post was at 00:57 ----------
hast du schon probiert die usb 3.0 xhci deaktivieren bzw. die via ports zu deaktivieren? als ich mit den älteren bios versionen noch probleme hatte mit meinem eingabegeräten habe ich usb 3.0 deaktiviert und auf ehci gesetellt, so konnte ich wenigstens störfrei arbeiten.
...also,
habe gerade das UD3H Board mit F12h Mod am laufen... ich kann ohne Probleme die "Intel® Management Engine Treiber Version 8.0.13.1502" installieren... auch ErP funktioniert mit meiner Logi G510 einwandfrei... läßt sich sogar mit nem Voltmeter messen, dass die Spannung je ErP Einstellung da ist oder nicht ;-)
ich würde mal ein ClearCMOS empfehlen, im BIOS die Defaultwerte mit der F7 Taste laden und keine alten Profile verwenden !!!
Kann das GA-Z77X-UD3H F12h Mod im Board auf Deiner Site nicht finden:
JZ Board
Pflegst Du das noch ein ? :)
Das dritten von unten ist es doch!?
Gemoddet sind in dem Thread glaube ich alle. Dahinter steht nix, weil beim F12h der CPU-Patch bereits aktuell war.
...wie schon häufig von mir erwähnt !!!
die meisten Probleme würden wie folgt sich in Luft auflösen ;-)
...ich würde mal ein ClearCMOS empfehlen, im BIOS die Defaultwerte mit der F7 Taste laden und keine alten Profile verwenden !!!
---------- Post added at 10:59 ---------- Previous post was at 10:58 ----------
...genau,
danke @Murazor :-)
Danke auch für die Mühe - ist sich wohl das erste "offizielle" JZ Mod Bios das ich flashe ?! Für das GA-Z68X-UD3H 1.3 könnte ich das auch noch brauchen. ;)
Kommen vermutlich fast alle GA Biose mit der einen oder anderen JZ Deep Mod daher. ^^
Ich habe ein Z77X-D3H und 16 Gbyte Kit von Corsair mit 1600 MhZ. (Mit i5-3570K)
Das Board (F9) stellt mir standardmäßig aber 1333 MhZ ein. Warum ist das so?
Servus, heute leider schlechten Tag mit dem Board gehabt (UD5H). :(
Zum einen startet der Rechner ständig neu mit dem Blue Screen "Memory_Management".
Direkt mal einen Memory Check laufen lassen mit einem desaströsen Ergebnis (ein kompletter Durchlauf war das):
Speicher ist der Corsair CMZ32GX3M4X1600C10 (4 mal 8 GB Kit). Er meldet die Fehler nur bei 2048-350XMB. In einem anderen Memory Test Tool hat er die Slots angezeigt, da war es dann auf allen Bänken der Fehler.
Ich kann mir nicht erklären woher das auf einmal kommt. Geändert wurde an dem Rechner nix.
Dann habe ich zudem mal das F10a geflasht, Rechner geht in Bootloops, kein Bild mehr. Backup Bios (F4) läuft.
Nun bin ich etwas ratlos, was den nun nicht geht und wie ich das nun fixen soll.
Das mein Dell U2711 an der HD4000 (Display Port) nicht sauber läuft ist nur eines der kleineren Probleme, die ich auf Windows 8 schiebe.
Würde mich über euer Feedback freuen.
Mein UD5H läuft,mit allem was ich bisher versucht habe,ebenfalls einwandfrei.Bios ist bei mir F9c.
Jo meins funzt auch gut jetzt ;) F9f
ich hab eine kurze Frage zum Thema Gehäuselüfter:
Ich bin grade auf das UD3H umgestiegen und mein altes Mainboard hatte keine PWM-Anschlüsse.
Ich habe zwei Gehäuselüfter, die jeweils dreiadrig angesteuert werden.
Einer hängt an Sysfan1, der andere an Sysfan4.
Früher konnte ich die einfach zB auf 70% Spannung laufen lassen.
Ist das hier nicht möglich?
Steht doch auf der ersten Seite ^^
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
und wurde auch schon X mal gesagt.
Zusatz Y-Kabel FTW ;-)
greets
Ein Modul auf ner anderen Rambank (alle Kombinationen durchtesten) testen (Memtest)
CMOS clear probieren + neueinstellen (ggf. Batterie raus)
Auf nem anderen Board den RAM testen.
Falls das alles nix hilft RAM in die RMA.
greets
Danke für dein Feedback. Wie gesagt es wird nur bei 2-3,5GB angezeigt. Meinst du es wäre dann nur ein Modul das kaputt ist?
