[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
cpu_opt=statisch 12V
So, gestern BF3 mit meinem Schwager auf dem (leeren) BF-X Server mit der Karte Metro getestet. Kann nur sagen läuft echt "cremig" und das selbst mit der GTX460 auf Details AUTO. Werde jetzt noch ein bissle an der Grafik schrauben :coolblue:
Beim P8Z77-V gibt es den CPU_FAN und den CPU_OPT. Für was ist den der letztere? OPT=Optional?
Hallo, der CPU_OPT ist optional, da kannst du einen zweiten Lüfter anschließen der dann die gleiche geschwindigkeit wie der erste Cpu Lüfter hat (auch wenn der per PWM runtergeregelt wird, der opt geht dann mit)
Wenn noch interesse besteht, was kompatible ist und was nicht (wird das noch im ersten Post akt. ?)
Mit Bios und Lüftersteuerung incompatible : Arctic F12PWM
Mit Bios und Lüftersteuerung kompatible:
EKL Alpenföhn Föhn 120 Wing Boost Black & White Plus
Be quiet! Shadow Wings SW1 Mid-Speed 120mm
Revoltec Dark Blue 120x120x25mm
BitFenix Spectre schwarz, 230x230x30mm
Ram: G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 XMP 2 Profil
Genau! Ich hatte ja vor dem Einbau meines Boards die gleiche Frage hier gestellt. Meine zwei PWM-Lüfter laufen an den beiden Anschlüssen nun im Gleichschritt und ich sparte mir den PWM-Y-Adapter. :)
Legt das Board bei Vcore auf Auto die von Intel in der CPU festgelegten Spannungen an oder springt die Spannung ohne Kontrolle drüber? Falls doch die Intel-Empfehlungen genommen werden: Wie verhält sich das Board bei Auto, wenn man Taktraten jenseits des Intel-Turbos anlegt? Dafür kann Intel ja nichts mehr festgelegt haben...
Ich werde über's WE einen neuen PC mit P8Z77-V Deluxe in Betrieb nehmen und habe nun gesehen, dass mein PC-Schrauber die SSD an den Dunkelblauen Marvell-Port und die HDD an den Blauen Intel-SATA3Gb-Port gehängt hat.
Welche Anschlüsse würdet ihr empfehlen? SSD und HDD an die Grauen Intel-SATA6Gb-Ports? Hab hier im Thread gelesen, dass der Marvell bei der Win-Installation Probleme machen könnte.
Ich würde die SSD an die weissen SATA-3 Ports anschliessen, sofern es eine SATA-3 SSD ist. Sonst an die hellblauen SATA-2 Ports. Die HDD dann an die hellblauen SATA-2 Ports. Eine HDD kann das SATA-2 Interface nicht auslasten. Reicht also vollkommen, auch wenn die HDD ein SATA-3 Interface hat.
Besten Dank, die SSD ist eine Samsung 830.
Dann werde ich diese vor der Installation erst noch umklemmen.
Genauso habe ich es auch gemacht!
So, der zweite aufgebaute Rechner (für den Kumpel) läuft. Verbaut wurden ein 3550 mit einem P8H77-V und 8GB RAM. Dazu noch eine m4 sowie eine 500GB HDD als Datengrab. Beheimatet wird das ganze im Coolermaster Haf 912 Plus und "gepowert" von einem be Quiet E9 mit 580 Watt. Der ganze PC ist im IDLE so leise das es fast in den Ohren weh tut :fresse:
Kann ich so bestätigen. CPU-FAN und CPU-OPT werden synchron geregelt.
Auch ich spare mir jetzt das PWM-Y-Kabel. Feine Sache.
ich wollte heute mein P8H67-M Evo gegen das P8Z77-V Pro tauschen, da ich noch ein Board mit SB-Bug hatte und das noch einschicken wollte bevor Garantiezeit um ist.
Nun kam das böse erwachen ... erstmal ging nach Montage garnix will heißen Board LED grün und nix passiert bei Powerknopf.
Wollte schon alles wieder auseinander nehmen und dachte mir bevor ich das tue versuch ichs mal mit einem Bios Reset und siehe da der Reset Jumper hat out-of-the-box auf der Reset-Stellung gesteckt.
Nunja auf default gesteckt und siehe da Board ging an und ich mich schon gefreut, da kam der nächste Hammer Piep 1x Lang 3x Kurz und rote LED am PCIex-Port was auf VGA Problem hindeutet.
Also Grafikkarte zum testen reingesteckt und siehe da die Kiste geht an. Ich wollte aber die iGPU von meinem i7-2600 nutzen weil das nur ein Arbeitsrechner ist.
Das nächste Problem von meinen 4x4GB G.Skill F3-10666CL9D-8GBRL werden nur 8GB erkannt obwohl im Bios unter SPD Informationen alle 4 Module angezeigt werden.
Ich hab alle Bios-Versionen durch dies gibt und geb nun auf da, das Board wohl ne Macke haben muß oder?
Hat jemand eine SandyBridge CPU mit iGPU auf dem Board problemlos am laufen?
Klingt nach einem tollen Rechner! Ein kleineres NT hätte es wohl auch getan ;)
Danke! Ich dolle vergaß aber die Grafikkarte zu erwähnen. Ist eine Sappire HD 7850 in der OC - Variante.
Edit: Irgendwie lassen sich die zwei Frontqurille per Q-FAN beim P8Z77-V nicht beruhigen und drehen immer volle Pulle. Erst per XFAN 2 konnte ich sie auf 400RPM runterregeln und damit eine angemenhme Lautstärke herstellen. Bug im BIOS?
Mit dieser Grafikkarte hätte z.B. ein BeQuiet Straight Power E8 400W gereicht. Natürlich auch der Nachfolger E9 400W.
Wie ich die Konfigs für die beiden PC erstellt habe war ich mir diesbezüglich noch unsicher und da der preisliche Unterschied zw. dem E9 480 Watt und dem E9 580 Watt nur ca 15€ betragen hat, habe ich beim letztere zugegriffen. Bei mir hingegen bin ich das "Experiment" eingegangen und habe es mit meinem alten E5 mit 500Watt versucht. Da meiner bis jetzt auch problemlos läuft bin ich da wieder schlauer geworden ;) Ich hoffe bei mir reicht es noch wenn dann nich nächster Zeit noch die GTX460 durch eine GTX670 ersetzt wird. Denke aber schon, auch wenn meine Konfig mit einem 3570K sowie 16GB RAM ein bissle mehr Strom braucht.
habe in meinem PC nun auch ein P8Z77-V Deluxe und eine Frage zu zwei Funktionen. Auf dem Mainboard befinden sich zwei Schalter, TPU und EPU. Beide habe ich auf Auslieferungszustand gelassen.
Im Handbuch ist kurz etwas zu den Funktionen geschrieben, so richtig verstehen tue ich die aber nicht.
TPU ist zum Automatischen Übertakten gut, EPU hat irgendetwas mit Stromversorgungzu tun.
Solle man beide aus machen wenn manuell Übertaktet werden soll? Wie verhält es sich wenn man eher auf Strom sparen gehen will, dann EPU an?
Hoffe könnt mir ein wenig Weiterhelfen bei diesen Funktionen!
Gruß ace0n
So langsam lichtet sich bei mir das Chaos mit der Windows Installation im AHCI-Modus.
Kann es sein, dass das nur im Legacy Bootmodus ein Problem darstellt? Ich habe nämlich gerade eine Installation bei aktivem AHCI laufen. Habe diesmal bewusst einen UEFI Boot von der DVD gemacht und es geht einfach mal direkt ?! Bin gerade ziemlich froh, dass es läuft und werde daher erst später mal testen, ob es wirklich der Unterschied zwischen Legacy und UEFI ist, ob Win 7 im AHCI Modus knallt oder nicht beim Laden der ersten Dateien (noch bevor man die Sprache wählen kann).
Spannend danach wird dann, ob ich das LAN vernünftig zum Laufen bekomme. Hatte da beim ersten Anlauf mal LAN, mal nicht. War für mich nicht nachvollziehbar. Werde jetzt komplett auf die Asus InstallationsCD setzen. Wenn das dann nicht klappt, habe ich bis Dienstag Zeit, meinen Kauf zu widerrufen (gut, dass es 14 Tage sind ud nicht bloß eine Woche), was ich dann wohl per Mail machen würde, und kann das Motherboard zurückschicken. Ansonsten wäre es vll noch einen Versuch wert, die X-Fi Xtreme Music auszubauen. Mit der hatte ich schon auf dem nForce 4 Probleme mit IRQs.
also ich hab mich kurz-entschlossener Weise für das Z77MA-G45 von MSI entschieden.
Mit dem konnte ich mit einem "normalen" Win7 USB-Stick (also ohne Änderung für UEFI) im Legacy-Modus booten und auch ohne Probleme installieren. So liegts schon mal nicht am Chipsatz o.ä. direkt.
Hast du schon mal Asus kontaktiert, die sind ja auch hier im Forum vertreten
Ich würde das Board ohne Zusatzkarten aufsetzen. Erst danach die Karten einbauen und Treiber dazu installieren.
Nie die Treiber von der CD verwenden. Immer die Treiber von der Asus Seite runterladen. Die sind aktueller als jene auf der CD.
Das habe ich im ersten Anlauf gemacht, schade, ging auch nicht...
Ich mosere hier weiter und würde mich hier nur noch für Lösungen melden:
http://www.hardwareluxx.de/communit...t-treiber-geht-nicht-891775.html#post18910044
Hier sind schon 12 Seiten voll und du bist der erste bei dem LAN nicht geht ...
Kann mir nicht vorstellen, dass es sich hier um ein generelles Problem handelt. Scheint an deinem Exemplar zu liegen.
Ich unterstelle ja kein allgemeines Problem, dennoch würde ich mir im Fall der Fälle ein neues, anderes Motherboard bestellen, das P8Z77 hätte dann verloren.
Habe zumindest einen weiteren, bei dem es aktuell nicht geht, und einen bei dem es mal nicht ging (siehe oben verlinkter Thread).
EDIT:
Hi, glaube das Problem zu kennen und die lösung zu haben in der fritzbox config bei den lan einstellungen den lan anschluss auf "immer an" stellen nicht auf automatisch oder so. :wink: mfg omni
@katsche, bei systemoptionen energieoptionen so isses bei meiner 7270. :wink:
Danke. Zum Vergleich: Bei der 7170 findet sich das unter System->Energiemonitor-> Reiter "Einstellungen"
Muss noch etwas intensiver testen, aber ich glaube, ich habe gerade meinen persönlichen Helden des Abends gefunden!!! :)
Das kann doch nicht im Ernst so sein oder? Bin sehr froh, dass es jetzt zu funktionieren scheint, auch wenn ich mich noch nicht zu sehr zu früh freuen möchte. Kann mir jemand erklären, warum dieses Problem nur das Asus P8Z77 belastet, aber sonst niemanden auf der Welt?
---------- Post added 21.05.12 at 00:26 ---------- Previous post was 20.05.12 at 21:22 ----------
Bin mir ziemlich sicher, dass das Thema hier schon einmal gefallen ist, kann den Post aber leider nicht mehr auftreiben, sorry...
Mein 3570K läuft auf dem P8Z77-V durchgängig mit 3,8GHz auf allen vier Cores. Eingestellt in Windows ist das Energieprofil "Ausgeglichen".
Was muss ich dann wohl im BIOS anpassen, damit die CPU wie gewollt in den Energiesparmodus wechselt? Dass ich quasi AutoOC auf 3,8GHz habe, finde ich gar nicht mal so schlimm. Kann bei der brutalen Leistungssteigerung vom alten Sockel 939 DualCore aber auch gerne auf Inteldefaults gebracht werden.
Hi. Guck mal nach einem meiner letzten beiträge hier im thread. Hatte das thema auch. Du mußt c1e von auto auf enable stellen.
Gesendet von meinem GT-I9001 mit der Hardwareluxx App
Danke, hat geklappt. Schon komisch diese oc Einstellungen ab Werk...
Habe jetzt immer noch die 3,8Ghz auf allen Kernen bei Volllast, das nehme ich dankend mit. ;)
Gesendet von meinem HTC Desire S mit der Hardwareluxx App
Ich hab ein Problem mit meinem P8Z77-V Pro (Bios 1015, Prozessor 3770K) mit meinen Ram-Riegeln (4x 4 MB Geil Black Dragon 2133 CL10-11-11-30). Das Ram wird zunächst als DDR2-1600 erkannt, in dieser Konfiguration ist mein Rechner auch stabil. Wenn ich nun im Bios das XMP-Profil werden Takt und Timings korrekt auf 2133 gesetzt, ich kann den Rechner auch normal booten. Aber sobald ich den Rechner mit Prime95 etwas belaste kommt nach wenigen Minuten ein Bluescreen. Ich hab schon rausgefunden daß es bei Vollbestückung helfen kann VCCIO zu erhöhen, aber diese Spannung kann ich wohl bei diesem Board nicht einstellen. Hat jemand vielleicht eine Idee wie ich den Ram bei 2133 stabil bekomme?
Katsche, ahhh das gute alte Fritzbox-Problem ;) Hättest mal eher erwähnt, dass du eine hast :d
Gab vor kurzen hier im Board einen Fall und auch bei einem Bekannten von mir - dieses Green-Ethernet-Zeugs von der FB macht gerne mal Problemchen. War glaub ich auch ein Asus-Board, allerdings ein H61 oder H67... tritt aber auch mit anderen Boards/Nics auf.
Ähnliche Themen
