[Sammelthread] GTA IV [FAQ & Performance]
hey leute ich habe hier was sehr interessantes ;) es gibt für GTA IV ne FXAA Effect.txt ^^ erstellt ne txt datei und setzt das ein ;) und schon habt ihr ein AA was nur 1-2 fps frisst und dabei echt gut aussieht ;)
2 screens ohne FXAA und mit
//http://enbdev.com
THIS IS HLSL FILE FORMAT FOR EXECUTING ADDITIONAL
POST PROCESSING EFFECTS. MAKE THE COPY BEFORE CHANGING IT!
//keyboard controled variables
float tempF1;
float tempF2;
float tempF3;
float tempF4;
float tempF5;
float tempF6;
float tempF7;
float tempF8;
float tempF9;
float tempF0;
//global variables, already set before executing this code
float ScreenSize; //width of the display resolution (1920 f.e.)
float ScreenScaleY; //screen proportions (1.333 for 1920/1080)
//textures
texture2D texColor;
sampler2D SamplerColor = sampler_state
Texture = <texColor>;
MinFilter = LINEAR;
MagFilter = LINEAR;
MipFilter = NONE;//NONE;
AddressU = Clamp;
AddressV = Clamp;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
struct VS_OUTPUT_POST {
float4 vpos : POSITION;
float2 txcoord : TEXCOORD0;
struct VS_INPUT_POST {
float3 pos : POSITION;
VS_OUTPUT_POST VS_PostProcess(VS_INPUT_POST IN)
VS_OUTPUT_POST OUT;
float4 pos=float4(IN.pos.x,IN.pos.y,IN.pos.z,1.0);
OUT.vpos=pos;
OUT.txcoord.xy=IN.txcoord.xy;
return OUT;
//--------------------Fast Approximate Anti-Aliasing --------------------------
// FXAA v2 CONSOLE by TIMOTHY LOTTES @ NVIDIA
// Ported to ENBSeries by MysTer92 (Svyatoslav Gampel)
float4 PS_PostProcess(VS_OUTPUT_POST i) : COLOR
#define FXAA_SUBPIX_SHIFT (1.0/8.0)
#define FXAA_REDUCE_MIN (1.0/32.0)
#define FXAA_REDUCE_MUL (1.0/16.0)
#define FXAA_SPAN_MAX 15.0
half2 rcpFrame = half2(1/ScreenSize, 1/(ScreenSize/ScreenScaleY));
half4 posPos;
posPos.xy = i.txcoord.xy;
posPos.zw = posPos.xy - (rcpFrame.xy * (0.5 + FXAA_SUBPIX_SHIFT));
half3 rgbNW = tex2D(SamplerColor, posPos.zw ).xyz;
half3 rgbNE = tex2D(SamplerColor, posPos.zw + half2(rcpFrame.x, 0.0) ).xyz;
half3 rgbSW = tex2D(SamplerColor, posPos.zw + half2(0.0, rcpFrame.y) ).xyz;
half3 rgbSE = tex2D(SamplerColor, posPos.zw +rcpFrame.xy ).xyz;
half3 rgbM = tex2D(SamplerColor, posPos.xy).xyz;
half3 luma = half3(0.299, 0.587, 0.114);
half lumaNW = dot(rgbNW, luma);
half lumaNE = dot(rgbNE, luma);
half lumaSW = dot(rgbSW, luma);
half lumaSE = dot(rgbSE, luma);
half lumaM = dot(rgbM, luma);
half lumaMin = min(lumaM, min(min(lumaNW, lumaNE), min(lumaSW, lumaSE)));
half lumaMax = max(lumaM, max(max(lumaNW, lumaNE), max(lumaSW, lumaSE)));
half2 dir;
half lumaNWNE = lumaNW + lumaNE;
half lumaSWSE = lumaSW + lumaSE;
dir.x = -((lumaNWNE) - (lumaSWSE));
dir.y = ((lumaNW + lumaSW) - (lumaNE + lumaSE));
half dirReduce = max( (lumaSWSE + lumaNWNE) * (0.25 * FXAA_REDUCE_MUL),
FXAA_REDUCE_MIN);
half rcpDirMin = 1.0/(min(abs(dir.x), abs(dir.y)) + dirReduce);
dir = min(half2( FXAA_SPAN_MAX, FXAA_SPAN_MAX),
max(half2(-FXAA_SPAN_MAX, -FXAA_SPAN_MAX),
dir * rcpDirMin)) * rcpFrame.xy;
half3 rgbA = (1.0/2.0) * (
tex2D(SamplerColor, posPos.xy + dir * (1.0/3.0 - 0.5) ).xyz +
tex2D(SamplerColor, posPos.xy + dir * (2.0/3.0 - 0.5) ).xyz);
half3 rgbB = rgbA * (1.0/2.0) + (1.0/4.0) * (
tex2D(SamplerColor, posPos.xy + dir * (0.0/3.0 - 0.5) ).xyz +
tex2D(SamplerColor, posPos.xy + dir * (3.0/3.0 - 0.5) ).xyz);
half lumaB = dot(rgbB, luma);
if((lumaB < lumaMin) || (lumaB > lumaMax))
return half4(rgbA, 1.0);
return float4(rgbB, 1.0);
//--------------------Fast Approximate Anti-Aliasing Techniques -------------
technique PostProcess
pass P0
VertexShader = compile vs_3_0 VS_PostProcess();
PixelShader = compile ps_3_0 PS_PostProcess();
FogEnable=FALSE;
ALPHATESTENABLE=FALSE;
SEPARATEALPHABLENDENABLE=FALSE;
AlphaBlendEnable=FALSE;
FogEnable=FALSE;
SRGBWRITEENABLE=FALSE;
technique PostProcess2
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess3
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess4
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess5
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess6
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess7
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess8
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess9
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess10
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess11
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess12
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess13
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess14
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess15
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
Hatte das schon kurz vor dir angefangen...das ist schon ne neue Version von Mysteri ^^
Hab weiter oben einen verlinkt
So hier kann man gut sehen was ich mit den Texturen meinte
Da gehört das Stück Straße nicht hin
Das Stück in der Mitte ist OK..."ohne diesen Streifen in der Mitte" allerdings sind das für den Highway alles die selben Texturen ^^...zumindest jetz, von mir :d
funzt bei mir net
und was ist Sharpening????
Erklärt uns mal wie man das genau macht ^^
du musst die ENB series benutzen damit die effect.txt geladen wird es sollte eine von anfang an vorhanden sein...wenn nicht erstell eine txt datei mit dem namen effect.txt und füge einfach das ein was im spoiler steht ein und starte das game
hast du das ENB AA deaktiviert?? wenn nicht probier das mal ;)
//http://enbdev.com
float tempF1;
float tempF2;
float tempF3;
float tempF4;
float tempF5;
float tempF6;
float tempF7;
float tempF8;
float tempF9;
float tempF0;
//textures
texture2D texColor;
MinFilter = LINEAR;
MagFilter = LINEAR;
AddressU = Clamp;
AddressV = Clamp;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
VS_OUTPUT_POST OUT;
OUT.vpos=pos;
return OUT;
#define FXAA_SPAN_MAX 2.0
half4 posPos;
half2 dir;
FXAA_REDUCE_MIN);
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
Moin... Könntest du bitte deinen Mod zum Download freigeben? sieht richtig geil aus! wäre echt nett
mfG
Sry, mein Fehler... vom User "n3o123" Beitag #1497 Seite 60, diesen Mod hätte ich gerne! sieht fantastisch aus.
Hate da die ENB von dpsant ?
Weil ich habe die zurzeit auch laufen, nur mit dem Licht aus meiner ENB...und da funzt es ja.....hab aber auch das FXAA nicht von hier :d
ja dann gib mir mal dein FXAA junge ^^
Disjocking ich Uploade sie dir morgen denke ich
Wow, Dragozool, das sieht ja geil aus mit dem FXAA. Wo haste das her? hab ich bisher noch nirgends gesehen für GTA 4. Funktioniert das wirklich nur mit ENB? Spiele momentan @Vanilla, allerdings wäre so ein bisschen AA schon nett. Sonst richte ich mir demnächst mal wieder downsampling im Treiber ein, aber da das andere anscheinend weniger Leistung kostet, würde ich lieber das nehmen :fresse2:
mist, ich hab mich schon gefreut als ich die ersten Bilder gesehen habe^^. So ein Dreck, dass Boris keine ENB mehr für Patch 7 machen möchte :fire: Würd gerne das Hauptspiel und EFLC in gleich schöner Qualität spielen :shake:
