Herstellerlink
Bezugsquellen
•Spezifikationen•
CPU
- Support for Socket AM3+ processors
- Support for Socket AM3 processors: AMD Phenom™ II X6 / X4 / X3 / X2 (except 920 / 940) / Athlon II X4 / X3 / X2 / Sempron processors
- Supports 8-Core CPU
- Supports UCC feature (Unlock CPU Core)
- Advanced V8 + 2 Power Phase Design
- Supports CPU up to 140W
- Supports AMD's Cool 'n' Quiet Technology
- FSB 2600 MHz (5.2 GT/s)
- Supports Untied Overclocking Technology
- Supports Hyper-Transport 3.0 (HT 3.0) Technology
Chipsatz
- Northbridge: AMD 890FX
- Southbridge: AMD SB850
- AMD Vision Black
Arbeitsspeicher
- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 1866(OC)/1800(OC)/1600(OC)/1333/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
BIOS
- 32Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, VCCM, NB, SB Voltage Multi-adjustment
Audio
- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
- Premium Blu-ray audio support
- Supports THX TruStudio PRO™
LAN
- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111E
- Supports Wake-On-LAN
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE
Steckplätze
- 3 x PCI Express 2.0 x16 slots (PCIE2/PCIE4 @ x16 mode; PCIE5 @ x4 mode)
- 2 x PCI Express 2.0 x1 slots
- 2 x PCI slots
- Supports ATI™ Quad CrossFireX™ , 3-Way CrossFireX™ and CrossFireX™
SATA3
- 6 x SATA3 6.0 Gb/s connectors by AMD SB850, support RAID (RAID 0, RAID 1, RAID 0+1 and RAID 5), NCQ, AHCI and "Hot Plug" functions
- 2 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions
USB 3.0
- 2 x Rear USB 3.0 ports by NEC UPD720200, support USB 1.0/2.0/3.0 up to 5Gb/s
- 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by NEC UPD720200, supports USB 1.0/2.0/3.0 up to 5Gb/s
Anschluesse
- 8 x SATA3 6.0 Gb/s connectors
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x IEEE 1394 header
- 1 x HDMI_SPDIF header
- 1 x Power LED header
- CPU/Chassis/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
- 1 x USB 3.0 header (supports 2 USB 3.0 ports)
- 1 x Dr. Debug (7-Segment Debug LED)
Chipsatz
- AMD Vision Black
Arbeitsspeicher
BIOS
Audio
LAN
- Realtek RTL8111E
- Supports PXE
Steckplätze
- 2 x PCI slots
SATA3
USB 3.0
Anschluesse
- 1 x IR header
- CD in header
•Restliche Angaben•
ATX-Blende I/O Panel
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 6 x Ready-to-Use USB 2.0 Ports
- 2 x Ready-to-Use USB 3.0 Ports
- 1 x eSATA3 Connector
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch with LED
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Einzigartige Features
- ASRock Extreme Tuning Utility (AXTU)
- Instant Boot
- ASRock Instant Flash
- ASRock AIWI
- ASRock APP Charger
- SmartView
- ASRock XFast USB
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- Turbo 50 / Turbo 60 CPU Overclocking
- Turbo UCC
Smart Switch - 1 x Power Switch with LED
- 1 x Reset Switch with LED
Produktzubehör
- Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 Cables
- 4 x SATA Data Cables (optional)
- 2 x SATA 1 to 1 Power Cables (optional)
- 1 x Front USB 3.0 Panel
- 4 x HDD Screws
- 6 x Chassis Screws
- 1 x Rear USB 3.0 Bracket
Hardware überwachung
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/Power Fan Tachometer
- CPU Quiet Fan
- CPU/Chassis Fan Multi-Speed Control
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Formfaktor
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
Betriebssystem
- Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
Zertifizierungen
- FCC, CE, WHQL
- ErP/EuP Ready (ErP/EuP ready power supply is required)
- Instant Boot
- ASRock AIWI
- SmartView
- ASRock XFast USB
- Hybrid Booster:
- ASRock U-COP
- Turbo UCC
Produktzubehör
- 4 x HDD Screws
- CPU Quiet Fan
Formfaktor
Betriebssystem
Zertifizierungen
- FCC, CE, WHQL
•Impressionen•
•UEFI•
KeBeNe's Slideshow
Die Fotos sollen erstmal nur einen kleinen Einblick in das UEFI liefern. Sobald AM3+ Prozessoren verfügbar sind, wird natürlich ein Update gemacht.
Aktuelle Version:
Code:
[b]2.00[/b]
[b]1.90[/b]
[b]1.80[/b]
[b][URL="http://www.pctreiber.net/asrock-bios-downloads?did=375"]1.70[/URL][/b] (PCTreiber Download!)
[b][URL="http://www.file-upload.net/download-3865857/890FXD51.63.html"]1.63[/URL][/b]
[b]1.60[/b]
[b][URL="http://wp1170450.wp199.webpack.hosteurope.de/ebay/890FXD51.45"]1.45[/URL][/b] Bereitgestellt von Arek!
[b]1.40[/b]
UEFI Download:
Code:
[URL="http://www.asrock.com/mb/download.de.asp?Model=890FX%20Deluxe5&o=BIOS"]Asrock.com[/URL]
[URL="http://www.asrock.com/mb/beta.asp?Model=890FX%20Deluxe5"]Asrock.com (Betasection)[/URL]
[URL="http://www.pctreiber.net/asrock-bios-downloads?category=177"]PCTreiber.net[/URL]
•Arbeitsspeicher•
Code:
[URL="http://www.asrock.com/mb/memory/890FX%20Deluxe5.pdf"]Asrock Memory QVL[/URL]
Memtest Stable also kompatibel:
[URL="http://preisvergleich.hardwareluxx.de/a610055.html"]Patriot Gamer 2[/URL]
[URL="http://preisvergleich.hardwareluxx.de/812173"]Patriot Viper 3[/URL]
[URL="http://preisvergleich.hardwareluxx.de/crucial-ballistix-sport-vlp-dimm-kit-32gb-pc3l-12800u-cl9-9-9-24-ddr3l-1600-bls4c8g3d1609es2lx0beu-bls4k8g3d1609es2lx0-a862502.html"]Crucial Ballistix Sport VLP 32GB[/URL]
•Reviews•
Code:
[URL="http://www.pureoverclock.com/article1267.html"]pureoverclock.com[/URL]
[URL="http://www.pctreiber.net/2011/asrock-890fx-deluxe5.html"]pctreiber.net[/URL]
[URL="http://www.overclockingstation.de/content/-asrock-deluxe-5-im-kurztest-a561.html"]overclockingstation.de[/URL]
[URL="http://www.ocinside.de/go_d.html?http://www.ocinside.de/html/results/mainboard_asrock_890fx_deluxe5_d.html"]www.ocinside.de[/URL]
•CPU Kühler•
kompatibel:
Prolimatech Genesis - 2 Lüfter
Scythe Mugen 2 - 1 Lüfter
Noctua NH-U12P SE2 - 2 Lüfter
be quiet! Dark Rock Pro C1 - 3 Lüfter
Noctua NH-D14
Alpenföhn Brocken - 2 Lüfter
Phanteks-PH-TC14PE - 2 Lüfter
•Wasserkühler•
NB: Anfi-tec UCD grande
SB: Anfi-tec NBSB-006
SPAWAs: Anfi-tec PWM-014
Spawa und NB montiert:
. Ums Core unlocken gehts mir dabei auch nicht. Asrock.com:
