Hades2k
Hatte auf der einen ein OpenWRT im NAND installiert und heut morgen neu gebootet, ging nicht - also serielles Kabel angeschlossen und mitgeschnitten:
Heißt für mich im Endeffekt, NAND mit Samthandschuhe anfassen und alles nur von USB arbeiten.
Code:
U-Boot 1.1.4 (Jul 16 2009 - 21:02:16) Cloud Engines (3.4.16)
U-Boot code: 00600000 -> 0067FFF0 BSS: -> 00690D60
Soc: 88F6281 A0 (DDR2)
CPU running @ 1200Mhz L2 running @ 400Mhz
SysClock = 400Mhz , TClock = 200Mhz
DRAM CAS Latency = 5 tRP = 5 tRAS = 18 tRCD=6
DRAM CS[0] base 0x00000000 size 128MB
DRAM Total size 128MB 16bit width
Flash: 0 kB
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
NAND:256 MB
CPU : Marvell Feroceon (Rev 1)
CLOUD ENGINES BOARD: REDSTONE:1.0
Streaming disabled
Write allocate disabled
USB 0: host mode
PEX 0: interface detected no Link.
Net: egiga0 [PRIME], egiga1
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x100000, size 0x300000
Reading data from 0x3ff800 -- 100% complete.
3145728 bytes read: OK
## Booting image at 00800000 ...
Image Name: Linux-2.6.30.10
Created: 2010-07-31 14:08:28 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 903036 Bytes = 881.9 kB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.30.10 (ecc@stratocaster) (gcc version 4.4.4 (GCC) ) #10 Sat Jul 31 10:08:26 EDT 2010
CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: Seagate DockStar
Memory policy: ECC disabled, Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 ro
NR_IRQS:114
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 127260KB available (2224K code, 193K data, 84K init, 0K highmem)
Calibrating delay loop... 1192.75 BogoMIPS (lpj=5963776)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 296 bytes
NET: Registered protocol family 16
Kirkwood: MV88F6281-A0, TCLK=200000000.
Feroceon L2: Enabling L2
Feroceon L2: Cache support initialised.
Kirkwood: Gating clock using mask 0x1ac224
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Registering mini_fo version $Id$
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 248
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
console [ttyS0] enabled
Driver 'sd' needs updating - please use bus_type methods
MV-643xx 10/100/1000 ethernet driver version 1.4
mv643xx_eth smi: probed
net eth0: port 0 with MAC address 00:10:75:1a:d5:f0
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 649 at 0x000005120000
Creating 4 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x000000000000-0x000000100000 : "u-boot"
0x000000100000-0x000000500000 : "uImage"
0x000000500000-0x000002500000 : "rootfs"
0x000002500000-0x000010000000 : "rootfs_data"
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
orion-ehci orion-ehci.0: Marvell Orion EHCI
orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1
orion-ehci orion-ehci.0: irq 19, io mem 0xf1050000
orion-ehci orion-ehci.0: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
usb 1-1: new high speed USB device using orion-ehci and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
rtc-mv rtc-mv: internal RTC not ticking
i2c /dev entries driver
cpuidle: using governor ladder
TCP cubic registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
end_request: I/O error, dev mtdblock2, sector 2
EXT3-fs: unable to read superblock
EXT2-fs: unable to read superblock
end_request: I/O error, dev mtdblock2, sector 0
SQUASHFS error: squashfs_read_data failed to read block 0x0
SQUASHFS error: unable to read squashfs_super_block
VFS: Cannot open root device "mtdblock2" or unknown-block(31,2)
Please append a correct "root=" boot option; here are the available partitions:
1f00 1024 mtdblock0 (driver?)
1f01 4096 mtdblock1 (driver?)
1f02 32768 mtdblock2 (driver?)
1f03 224256 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
