Hier entsteht ein Sammelthread für das Biostar TH55.
Noch ein wenig Geduld
Inhaltsverzeichnis
7 phases VRM design with high quality power components such as low RDS(on) Mosfet for lower temperature and raise the overclocking ability.
BIOSTAR Dura-MAX™ designed for the highest quality and most innovative motherboard design. Featuring the industry's first design to innovate IR DirectFET™ MOSFET which deliver dramatically lower system temperature, improved energy efficiency and enhanced stability for overclocking needs. Also , combined with Japanese Solid Capacitors, Ferrite core chokes with higher power swiching efficiency. Tpower i55 motherboards with Dura-MAX™ pledged to provide the stability, reliability and Durability to meet the Motherboard power needs of new Intel processors and other components running today's most demanding applications and games.
BIOSTAR G.P.U (Green Power Utility) is a new function, it will enhance energy efficiency by disabling extra phases while CPU on light loading. It integrated a friendly GUI to monitor what's your CPU resourcing, response and optimized the power saving on your system. Such as Heavy 3D Gaming, Internet or MSN charting, G.P.U will always arrange the best power efficiency in your system.
LED display indicates real-time power saving.
BIOSTAR "GT60" means GreatTurbo boost your H55 platform 3Dmarks score over 60%. Just enable the "Intel GPU clock" to adjust intel 1156 Clarkdale ( Core i5/Core i3/Pentium G690 ) iGPU clock as you want .
Intel H55 chipse includes FDI (Flexible Display Interface), allowing direct connection between the CPU and the Graphics core. This allows the display information to be sent back to the H55 chipset for output.
The graphics core inside the Clarkdale processor is known as GMA HD. In comparison with G45 GMA X4500HD, the difference is the number of Unified shaders which was increased from 10 to 12.
Lynnfield is the first Intel 45nm CPU processors family using Intel Nehalem micro architecture in LGA1156 package. Supported Intel® DMI Interconnec and integrated with memory controller support Dual-channel with 4 DIMM slots DDR3 memory. It supported intel Turbo boost technology and smart cache.
It supports 4 DIMM Slots DDR3 memory that features data transfer rates of DDR3 2000(O.C.)/1800(O.C.)/1600/1333 , .As the LGA 1156 Intel® Core™ i7 and Intel® Core™ i5 Processors supported 2 memory channels, and the channel speed can be selected by setting the memory multiplier, It will obviously uplift the bandwidth and boost the overall system performance.
TWO external SATA 3Gb/s ports connectivity with minimal host overhead and host to device latency.
IEEE 1394a is a serial bus interface for high-speed communication and data transfer. Major applications are in Desktop and digital Video/Audio and some portable device.
On board Optical & Coaxial connector supported your desktop to transfer the non-distortion digital audio output to AV amplifier and professional speaker system.
To read directly voltages from the RAM, Chipset, PCI-E, CPU, QPI and CPU Pll's.
O.M.G (Overclocking Matrix Genie ) is designed to automatically adjust the key items to maximize system performance. Just press F10 when boot, it allows you to make simple Overclocking steps as a OC expert It will let you adjust the CPU Clock , CPU Voltage ..etc key items for Overclocking needs.
Effortlessly update BIOS from a USB flash disk before entering your OS.
BIO-FLASHER is a convenient BIOS update tool. Just launch this tool and put the BIOS on USB Pen Driver before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or other complicated flash utility.
BIO-ReLife Technology let you to resume crushed BIOS data from a USB flash Pen Driver that put the new BIOS file. This considerate BIOS utility can restore your system and far from the BIOS Crush situation.
Toverclocker presents a simple Windows based system performance enhancement and manageability utility. Featuring several powerful yet easy to use tools such as Overclocking for enhancing system performance. Also for special enhancement on CPU and Memory. Smart-Fan control for managing fan speed control of both CPU cooling fan and North-Bridge Chipset cooling fan. PC health for monitoring system status. And pre-set OC modes for easy OC.
No more meddling with Power and Reset jumpers on the board. The Power and Reset buttons are built onboard. It is convenient for DIY users to test the board without short-circuiting the wrong pins.
No need to check any H/W installation error flurried. On board LED indicator will answer the question for user.
Biostar owned unique engineering PWM layout with low ESR and high ripple conductive solid state caps to provide sufficient, stable power supply to the CPU. And the same philosophy applies to our DDR design to enhance voltage stability of memory.
fehlen leider noch... Ich nehme auch gerne eure selbst gemachten Bilder
Das Bios bietet sehr viele Features. Unter anderem kann man 10 Profile sichern uvm.
Sämtliche Möglichkeiten sieht man auf den Fotos:
Ja, dieses süsse µATX-Board eignet sich hervorragend zum übertakten
Man kann nahezu alle wichtigen Spannungen und Frequenzen beeinflussen. Siehe Biosbilder und Spannungsauflistung unten.
Obwohl ich die Onboard-Grafik benutze habe ich über 220 BCLK erreicht:
Auch im XS-Forum wird das Board benutzt und gelobt:
Intel’s Latest 32nm Clarkdale Platform - Core i5 661 With BIOSTAR H55 OC 5G On Air - XtremeSystems Forums
Intel Core i5 670 on µATX Biostar H55 Board - XtremeSystems Forums
Einige Spannungen lassen sich über Messpunkte auf dem Board mit einem entsprechenden Messgerät kontrollieren.
1. direkt von Biostar: BIOSTAR :: TH55XE :: BIOS
2. von Rebels Haven: Biostar TH55 XE Motherboard BIOS Download Page <- vielleicht kommt da auch mal eine modifizierte Version...
3. von meinem Mirror. Ich packe, wenn möglich, alle Dateien grundsätzlich mit 7Zip.
Version: H55AAC15
Release Date 2009/12/28
Update Description:
1. Engineering BIOS release.
Download: http://www.mwirths.de/biostar/H55AAC15.7z
Version: H55AAC28
Update Description:
1. Initial BIOS release.
Download: http://www.mwirths.de/biostar/H55AAC28.7z
Version: H55AA107
Release Date 2010/01/07
Update Description:
1. Support Intel GPU overclock ( Beta ).
Download: http://www.mwirths.de/biostar/H55AA107.7z
Ich empfehle euch, entweder die Treiber auf den einschlägigen Treiberseiten:
1. Station-Drivers: le site de drivers, bios, firmwares avec un forum d'aide
2. TousLesDrivers.com - Téléchargement gratuit de mises à jour PC (drivers, bios, firmwares)
herunterzuladen oder von meinem Server.
Ich werde noch genau posten, welchen Treiber ihr benötigt.
Ihr könnte natürlich auch die Seite von Biostar benutzen (BIOSTAR :: TH55XE :: Driver), aber wie wir alle wissen sind dort meist nicht die aktuellen Versionen.
Wer XP benutzt, und trotz installiertem Intel-Inf-Paket,diese zwei Geräte als nicht installiert vorfindet:
muss einmal zusätzlich eine ältere Inf-Version (http://www.mwirths.de/biostar/IntelChipsetDeviceSoftware9.1.1.1020.7z) installieren und dazu die Intel Management Engine (http://www.mwirths.de/biostar/IntelManagementEngine6.0.30.1203.7z)
Inhaltsverzeichnis
- aktueller Preis
- Allgemeine Informationen/Highlights
- Spezifikationen
- Bilder zum Board
- Das Bios
- Overclocking
- Biosupdates
-  Treiberdownload
- Supports the Intel Core i7 / i5 / i3 / Pentium Processors in the LGA1156 Package
- Intel H55 single chip architecture
- 7 Phases Power Design
- Support 4-DIMM DDR3-2000+(OC)/1800(OC)/1600/1333 up to 16G maximum capacity
- 100% X.D.C Japanese solid capacitor
- Integrated HDMI/DVI interface with HDCP Supporting all HD formats including 720P, 1080i, 1080P. ( Required processors with Intel HD Graphics )
- CPU integrated Graphics performance tunable via BIOS
- BIOSTAR Dura-MAX Technology
- BIOSTAR G.P.U (Green Power Utility) Technology for Energy Saving
- BIOSTAR Toverclocker utility
-  Optimized to deliver full windows 7 Experience
Highlights
- Raise your system maximum Overclocking performance by Biostar engineering
- Low Distortion audio design let SNR over 95dB
- Preset locking modes in BIOS enhanced MB performance
- Quick Power ON/OFF and Reset buttons
- Immediately watch your H/W error message
- Convenient update BIOS via USB Flash Driver
- Resume Crashed BIOS from USB Flash Driver
-  Windows Based utility for Motherboard Overclocking
Exclusive Features
7 Phase Power Phase Design
Dura-MAX
BIOSTAR "GPU" Technology
G.P.U. Power Indicator LED
GAME Boost
Chipset-CPU Features
Intel H55 chipset
Intel LGA 1156 Core™ i7/Core™ i5 Processor support
Dual Channel DDR3
eSATA
IEEE1394 on board
S/P DIF Output on board
BIOS-Software Features
BIO-V(BIOSTAR Voltage Point)
O.M.G (OverClocking Matrix Genie)
BIO-Flasher
BIO-ReLife
T-Overclocker
Rapid Switch
Rapid Debug
Tweak Tech
Chipsatz
-  Intel H55
CPU Support
- Intel® Core™ i7 LGA 1156 Processor
- Intel® Core™ i5 LGA 1156 Processor
- Intel® Core™ i3 LGA 1156 Processor
-  Intel® Pentium® LGA 1156 Processor
Speicher
- Support Dual Channel DDR3 800/1066/1333/1600(OC)/1800(OC)/2000(OC) MHz
- 4 x DDR3 DIMM Memory Slot
-  Max. Supports up to 16GB Memory
Erweiterungsslots
- 2 x PCI Slots
- 1 x PCI-E x4 2.0 Slot
-  1 x PCI-E x16 2.0 Slot
Storage
- 5 x SATA2 3Gb/s Connector
-  1 x IDE Connector
USB
- 4 x USB 2.0 Port
-  3 x USB 2.0 Header
Firewire
- LSI FW322
- 1 x IEEE 1394a Port
-  1 x IEEE 1394a Header
Netzwerk
-  Realtek RTL8111DL - 10/100/1000 Controller
Integrierter Grafikcontroller
-  By CPU model
Audio
-  Realtek ALC888 8+2 Channel HD Audio
Anschlüsse auf der Rückseite
- 1 x PS/2 Mouse
- 1 x PS/2 Keyboard
- 1 x eSATA2 3Gb/s Connector
- 1 x FireWire IEEE 1394a Port
- 4 x USB 2.0 Port
- 1 x HDMI Connector
- 1 x DVI Connector
- 1 x VGA Port
- 1 x RJ-45 Port
- 6 x Audio Connector
-  1 x S/PDIF Out Port
Anschlüsse intern
- 1 x Printer Header
- 1 x IDE Connector
- 1 x Front Audio Header
- 1 x Front Panel Header
- 1 x CPU FAN Header
- 2 x System FAN Header
- 1 x Serial Header
- 1 x FireWire IEEE 1394 Header
-  1 x CIR Header
Abmessungen
-  Micro ATX Form Factor Dimension: 24.4 cm X 24.4 cm ( W x L )
Betriebssystemunterstützung
-  Windows XP / Vista / 7
Packungsinhalt
- 1 x IDE Cable
- 3 x SATA Cable
- 1 x SATA Power Cable
- 1 x I/O Shield
- 1 x CD Driver
-  1 x User Manual
Version: H55AAC15
Update Description:
Version: H55AAC28
Update Description:
Version: H55AA107
Update Description:
