[Sammelthread] Asus P6X58D Premium (Intel X58)
P6X58D Premium
Best Choice for Extreme Overclocking and Future Transfer Technology!
•Intel® LGA1366 Platform & Intel® X58/CH10R chipset
•Next Gen 32nm 6-Core Processor Ready!
•True USB3.0 and SATA 6Gb/s Support!
•ASUS True 16+2 Phase Power Design
•3-Way SLI & Quad-GPU CrossFireX Support!
•MemOK!
CPU, Chipset and Graphics features
LGA1366 Intel® Bloomfield Processor Ready
This motherboard supports the latest Intel® Core™ i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. Supports Intel® QuickPath Interconnect (QPI) with a system bus of up to 6.4 GT/s and a max bandwidth of up to 25.6 GB/s. Intel® Core™ i7 processor is one of the most powerful and energy efficient CPUs in the world.
3-Way SLI and Quad-GPU CrossFireX Support!
Flexible Multi-GPU solutions, Your Weapon of Choice!
The P6X58D Premium breaks the boundaries to bring you the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you’ve never experienced before!
Intel X58
The Intel® X58 Express Chipset is one of the most powerful chipset designed to support the Intel® Core™ i7 Processors with LGA1366 package and Intel® next generation system interconnect interface, Intel® QuickPath Interconnect (QPI), providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance.
PCIe 2.0
Double Speed; Double Bandwidth
This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
.Future Transfer Technology
True SATA 6Gb/s Support
Experience the Future of Storage!
Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems.
True USB 3.0 Support
10X Faster Date Rates!
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0—the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components.
Memory Feature
Triple-Channel DDR3 2000(O.C.) / 1333 / 1066 support
The motherboard supports DDR3 memory that features data transfer rates of 2000(O.C.) / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
ASUS Xtreme Phase
True ASUS 16+2 Phase Power Design
Unprecedented Innovation with the Best Quality Component for Best Performance
The groundbreaking 16+2 phase VRM design is brrought to the ASUS motherboards. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability. With the high quality power components such as low RDS (on) MOSFETs, Ferrite core chokes with lower hysteresis loss and 100% Japan-made high quality conductive polymer capacitors, ASUS 16+2 phase VRM design also ensure longer component life and minimum power loss.
ASUS Exclusive Overclocking Feature
ASUS TurboV
New OC Records with Real-Time Super-precise Tunings
Feel the adrenaline rush of real-time OC - now a reality with the ASUS TurboV. This extreme OC tool lets you set new ambitions on the OC stage with an advanced and easy-to-use interface - allowing you to overclock without exiting or rebooting the OS. With micro adjustments of the CPU PLL, NB, NB-PCIe, and DRAM voltages in 0.02v intervals, there are no limits - only extreme results to break new OC records!
ASUS Exclusive Features
ASUS EPU
System Level Energy Saving
The new ASUS EPU - the world´s first power saving engine, has been upgraded to a new six engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. With auto phase switching for components (which includes the CPU, VGA card, memory, chipset, drives and system fan), the EPU automatically provides the most appropriate power usage via intelligent acceleration and overclocking - helping save power and money.
ASUS Express Gate SSD
0 to Internet in Seconds!
Express Gate™ is an ASUS exclusive OS that provides you with quick access to the Internet and key applications before entering Windows®.
MemOK!
Any Memory is A-OK!
MemOK! quickly ensures memory boot compatibility. This remarkable memory rescue tool requires a mere push of a button to patch memory issues. MemOK! determines failsafe settings and dramatically improves your system boot success. Get your system up and running in no time!
.ASUS Quiet Thermal Solution
ASUS Fanless Design - Heat-pipe solution
The Heat Pipe design effectively directs the heat generated by the chipsets to the heatsink near the back IO ports, where it can be carried away by existing airflow from CPU fan or bundled optional fan. The purpose of the innovative heat pipe design on this motherboard is that the groundbreaking fanless design does not have lifetime problems as a chipset fan does. Furthermore, it provides options for users to install side-flow fan or passive cooler. The Heat Pipe design is the most reliable fanless thermal solution to date.
Fan Xpert
Active Quiet & Cool
ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature , which is caused by different climate conditions in different geographic regions and system loading.Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment.
Up to 20°C(36°F) Cooler - Stack Cool 3+
Effective Fanless Heat Dissipation at 0dB
Stack Cool 3+ is a fanless cooling solution offered exclusively by ASUS. It effectively and noiselessly transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for effective heat dissipation - making temperatures cooler by up to 20°C.
.ASUS Crystal Sound
DTS Surround Sensation UltraPC
DTS Surround Sensation UltraPC delivers exceptional 5.1 surround experience through the most common PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, “Bass enhancement” provides stronger low frequency bass sound, and “Voice clarification” provides clear human dialogue even with loud background sound. With these technologies, you may experience a better home-theater audio with ease.
Noise Filter
Eliminate background noise while recording
This feature detects repetitive and stationary noises like computer fans, air conditioners, and other background noises then eliminates it in the incoming audio stream while recording.
.ASUS EZ DIY
ASUS Onboard Switch
With an easy press during overclock, this exclusive onboard switch allows gamer to effortless fine-tune the performance without having to short the pins!
Q- Shield
Easy and Comfortable Installations
The specially designed ASUS Q-Shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI).
EZ-Flash 2
Simply update BIOS from a USB flash disk before entering the OS
EZ Flash 2 is a user-friendly BIOS update utility. Simply launch this tool and update BIOS from a USB flash disk before entering the OS. You can update your BIOS only in a few clicks without preparing an additional floppy diskette or using an OS-based flash utility.
ASUS Q-Design
DIY quickly, DIY easily!
ASUS Q-Design enhances your DIY experience. All of Q-LED, Q-Slot and Q-DIMM design speed up and simplify the DIY process!
Q-Connector
Make connection quick and accurate!
The ASUS Q-Connector allows you to connect or disconnect chassis front panel cables in one easy step with one complete module. This unique adapter eliminates the trouble of plugging in one cable at a time, making connection quick and accurate.
O.C. Profile
Conveniently store or load multiple BIOS settings
Freely share and distribute favorite overclocking settings The motherboard features the ASUS O.C. Profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite overclocking settings.
.Industry Standard
IEEE 1394a interface
IEEE 1394a interface provides high speed digital interface for audio/video appliances such as digital television, digital video camcorders, storage peripherals & other PC portable devices.
S/PDIF-out on Back I/O Port
This motherboard provides convenient connectivity to external home theater audio systems via coaxial and optical S/PDIF-out (SONY-PHILIPS Digital Interface) jacks. It allows to transfer digital audio without converting to analog format and keeps the best signal quality.
.RoHS
GreenASUS
The motherboard and its packaging comply with the European Union´s Restriction on the use of Hazardous Substances (RoHS). This is in line with the ASUS vision of creating environment-friendly and recyclable products and packaging to safeguard consumers´ health while minimizing the impact on the environment.
Geizhals Link
http://preisvergleich.hardwareluxx.de/a495774.html
Treiber&Tools
http://support.asus.de/download/download.aspx?SLanguage=de-de
Bios Downloadlink
ftp://ftp.asus.com.tw/pub/asus/mb/lga1366/P6X58D_Premium/
Bios History
[ 0703 ]
1. Improve system stability
2. Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
[ 0702 ]
Support new CPUs. Please refer to our website at:http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
[ 0604 ]
Fix DRAM Voltage is abnormal in TurboV
[ 0506 ]
[ 0402 ]
1.Enhance OC Profile storage space from 2 to 8 slots.
2.Enable instant display of Target CPU & DRAM Frequency under Ai Tweaker
[ 0301 ]
First release Bios
CPU Support Liste
Core i7 920(2.66G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 920(2.66G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 940(2.93G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 950(3.06G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 960(3.2G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Core i7 Extreme Edition 965(3.20G,L2:4x256KB,L3:8M, rev.C0,130W) ALL 0301
Core i7 Extreme Edition 975(3.33G,L2:4x256KB,L3:8M, rev.D0,130W) ALL 0301
Bilder des Boards
Schönes Teil. aber ich warte schon noch ein wenig. Meins ist erst 1 1/4 Jahre alt, schon wir mal in einem Jahr.
Gruss
Frank
Danke für den Sammelthread.:) Werde den jetzt weiter verfolgen.
Das ist mein absolutes Favouriten-Board, nachdem ich P55 verworfen habe.:love: Ich finde das auch komisch. In USA dillern die schon seit Dezember auf diesen Boards rum und hier hats keiner. Ich habe auch noch kein richtiges Review gesehen. Gibt nur bei youtube ein paar Trailer/Einbauanleitungen. In CH gibts das noch nicht, aber bei Geizhals in D ist es schon lieferbar gelistet - also ran!
Ich finde das Board nahezu perfekt. Es hat jedoch drei Nachteile:
- kein eSata
- für SLI/CF sind die Grakas bei dem Layout etwas eng zusammen
- welcher Sack hat dem einen weissen 3. PCIe x16-Slot verpasst.:motz:
Ansonsten ist das absolutes High-End und Konkurrenz bekommt es nur vom Gigabyte X58A-UD7. Klar kommt noch das Rampage III, aber das ist rot - rot will ich nicht.:fresse: Mein einziges Problem ist, dass ich da eigentlich keinen alten 45nm 920 draufschnallen will, der Gulftown aber so sauteuer wird...
Sind auf dem Board jetzt USB3 und Sata3 gleichzeitig nutzbar, ohne dass man PCIe-Lanes für die Grakas einbüsst? (Hat es den PLX-Chip?)
Wann wird HWLuxx es testen?
Jo, das Board gefällt mir auch super gut und ich kämpf gerade mit meinem Gewissen welches ich nun nehmen soll, ob doch weiter 1156 oder wieder 1366.
Was mir bei dem Board net ganz passt is, dass meine Xonar D1 wohl nimmer passt mit ner HD5870 + MK-13 :-[..........
Und der 3. PCIe Slot is weiß, weil er keine 16 Lanes hat. ASUS macht die Slots mit 16 Lanes dunkelblau, die mit 8 hellblau und die mit 4 weiß ;)
Ja doof ist das. Meine P55 Alternative wäre ein MSI-Trinergy - das Board hat mal ne solide Optik.:hail: Das fehlt mir am Asus leider etwas. Hab das Trinergy aber verworfen, da es mehr kostet, als das P6X58D.
Also ich find die MSI Boards nicht sooo hübsch. Finde die ASUS mit den verschiedenen Blautönen etwas schicker und nicht so langweilig ^^
Ja, meine Frau auch.:fresse: Aber die Corsair Dominator 8GB/12GB-Kits harmonieren besser mit MSI, wegen den blauen Finnen - OK ist Haarspalterei, aber über sowas zerbreche ich mir bei meinem neuen Build den Kopf.:shot:
PS: Hab seit 8 Jahren keinen PC mehr übertaktet - hoffe das geht mit dem Board halbwegs unkompliziert.
Die Slots können entweder 16/8/8 oder 16/16/1 konfiguriert werden (per BIOS-Schalter).
Unabhängig von der Nutzung von Sata3/USB3? Meine gelesen zu haben, das einige Boards die Grakas auf 8x/8x runterziehen, wenn USB3 und Sata3 aktiv sind.
für was benutzt ihr usb 3.0 und sata 3?
ich will es wirklich hören :d
ich sehe diese features als "zukunftssicher" und sinnvoll an
SATA3 und USB3 funktionieren unabhängig von den Grafikkarten und auch gleichzeitig problemlos. Die Chips sind an den zusätzlichen 4 PCIe 2.0-Lanes der Northbridge dran. Es bleiben dann noch 32 Lanes für die GPUs. Von daher kein Problem. Nur bei den P55A-Boards im "Turbo"-Modus werden die 16 Lanes aufgeteilt und 8 gehen an die Grafikkarte und 8 an die Zusatzchips. Dank X58-Chipsatz ist das hier aber nicht nötig.
Für den Preis würde ich mir aber eher das UD7 holen. Das hat eine bessere Ausstattung und passt vom Layout her besser in mein Konzept.
warum bekommen dann die p55er den plx chip und der x58 nicht?
warum weisst du das,und asus nicht?
bitte nicht böse bzw falsch verstehen ich wills nur kapieren
Ich baue nicht jedes Jahr nen neuen PC und wenn dieses Jahr noch externe Festplatten kommen mit USB 3.0 dann kauf ich eine. Und die kommen garantiert.;)
Ausserdem können schon zur Cebit Sata 3 SSD kommen, die Sata3 für maximale Performance auch brauchen.
@craxity
Was ist an dem UD7 besser? Ich sehe nur den Waküanschluss und den brauch ich nicht.
@RiMaBo: Beim P55 gibt es 16 PCIe 2.0-Lanes vom Prozessor direkt und 8 PCIe 1.0-Lanes von der Southbridge. ASUS bündelt mit dem PLX-Chip vier PCIe 1.0-Lanes von der Southbridge zu 2 PCIe 2.0-Lanes und vernidet den USB3- und SATA3-Chip mit je einer sieser Lanes.
Bei Gigabyte-Boards mit P55-Chip sind zwei andere Möglichkeiten vorgesehen: Antweder werden die Zusatzchips mit jeweils nur einer PCIe 1.0-Lane der Southbridge angebunden und sind dann langsamer. Oder mann nutzt den "Turbo"-Modus. Dabei werden die 16 PCIe 2.0-Lanes des Prozessors in 2 mal 8 Lanes aufgeteilt. 8 Lanes bekommt dann die Grafikkarte und je einen die Zusatzchips. Dadurch sind diese schneller, aber die Grafikkarte uU langsamer und CrossFire bzw. SLI funktioniert nicht mehr.
Beim X58-Chipsatz kommen 36 PCIe 2.0-Lanes von der Northbridge und 6 PCIe 1.0-Lanes von der Southbridge. Die 36 können Grafikkarten mit 32 Lanes anbinden und es bleiben noch 4 lanes übrig. An je einer Lane kann man dann die Zusatzchips mit voller Geswchwindigkeit anbinden ohne PLX-Chip.
Ich hoffe jetzt ist alles klar;) Wenn nicht, weiterfragen.
@bassmecke: Das UD7 hat eSATA und insgesamt mehr SATA-Ports. Den Wasserkühler brauche ich auch nicht.
OK, mit USB 3.0 brauche ich kein eSata mehr und ich habe maximal 4 SSDs im System, mehr nicht. Dachte da wären noch andere Vorteile. Denke sonst sind die Boards gleichwertig, bis auf das die Optik des Asus sehr viel besser ist. War bisher eher Gigabyte-Freund aber jetzt werde ich wohl mal ein Asus testen.:)
Optik muss jeder für sich entscheiden. Aber bei mir passt das UD7 besser. Außerdem müssen bei mir neben der Grafikkarte noch 3 PCiex1-Karten rein. Das geht auf dem ASUS nicht.
danke für die tolle antwort
warum weisst du das alles und die offiziellen von ASUS nicht?
komisch,hoffe es ist so wie du sagst da ich kein bock habe wenn ich mal ne externe hdd usb3 habe oder en stick das meine graka dann nur noch 8x rummdümpelt auch wenns nicht viel ausmachen würde vom Speed her
In die alphabetische Übersicht aufgenommen und ins Sammelthread Unterforum verschoben :wink:
Mir ist noch was eingefallen, das eher für das UD7 spricht: Gigabyte-Boards liefern bessere Übertragungsraten bei eSATA, FireWire und USB.
kann man das grundsätzlich sagen?
Wenn ja würde es mich doch sehr wundern
Um wieviel besser? eSata wäre beim ASUS ja egal.:fresse: Technisch finde ich Gigabyte auch besser, aber die Bretter sehen einfach hässlich aus. Mein nächster Build wird eben auch was fürs Auge.
Als c't-Leser kann ich da eine eindeutige Tendenz erkennen. Wenn man die Tests der MAinboards mit Intel-Chipsatz seit dem 3-Serie betrachtet, schneidet Gigabyte-Boards was Übertragungsraten angeht immer am besten ab.
Das gilt für LAN, eSATA, Firewire und USB. Und da es immernoch die gleichen Chips sind (JMicrob, Realtek, VIA) bleiben die Lesitungden konstant.
Einzig die RAID0-Performance beim Schreiben sind beim JMicron-Chip nicht perfekt, aber die sind vernachlässigbar.
Bei den neuen USB3- und SATA3-Lösungen bekommt die volle Leistung aber nur über die PCIe 2.0-Lanes des X58 oder der CPU selbst beim P55. Also beim P55 nur im "Turbo"-Moddus.
ich war noch nie ein freund von GB boards.
Das Bios (Aufbau) gefällt mir nicht,ich lege wert auf umstellen der sprache im bios usw
das kann asus besser und das schon seid jahren,auch die features die asus bringt ob sinnig oder unsinnig sei mal dahingestellt sind einfach der knaller
