Sniper1010
Hello hardwaredeluxx members,
I came here for good advise since you where very helpfull in the watercooling topic, the watercooling components wich i already ordered. I already ordered my pc components still waiting and if needed i can still change components...
These are my pc components:
Lian Li Tyr PCX-500 case
Be Quiet! Dark Power Pro 650W or 750W or Corsair brand psu?
Intel Core i7 920 (do) overclocked to 3.0 or 3.2ghz
Intel Postville ssd 80gb (G2)
EVGA X58 SLI LE motherboard
EVGA GTX260 super clocked
Mushkin XP3-12800, 6GB, PC3-12800, 1600 MHz, cas 7-8-7-20.
Western Digital Caviar Black 500 GB, 7200 Rpm, 32 MB
Sony Optiarc dvd burner
Cherry G80-3000 keyboard black
Razer Salmossa mouse
6 or 7 case fans 3 for radiator the rest for the case (Noiseblocker NB-Blacksilent XL1 Rev.3 120mm)
Pump itself aquastream XT uses 5watt
What PSU do you recommend me?
The psu can handle all these components i know that....
But i heard that its best to have some "headroom" with the psu this headroom is not ment to be used for future upgrades like SLI wich i never do, perhaps in the future an upgrade to a new generation GT300 gpu 40nm wich hopefully is more energy efficient and uses less WATTS then the gtx260.
I heard that if your components use say 400wat you generaly buy a 500watt quality psu. But its better to have a 600watt psu not for upgrade like sli but for BETTER STABILITY (the bigger the psu the more AMPS i have and the less stress on the psu for more stability...i think) so the psu is not working at its max output. I hope you understand me...
Als il be using 6 or 7 case fans 3 for radiator and 3 or 4 for the case itself, so please consider that to. And also i little OC cpu 3.0 or 3.2ghz
Ok now comes the important question wich brand of psu should i buy that is QUALITY ROCK SOLID and STABLE and offcourse sillent!
I got 2 options here Bequiet dark power pro 650 or 750w
or Corsair HX750 750 Watt? I heard Corsair uses top quality parts in their psu like japanese solid capacitators. But i do think Bequiet psu are of high quality to. Since Bequiet is a GERMAN brand i think i'm at the right place for advise
(I will not use SLI)
So what psu to get 650 or 750watt? and wich brand Bequiet or Corsair?
Please help
Thanks in advance help is much appreciated
Please help
