Ui ui, ich sollte wirklich mal über eine neue Graka nachdenken... Meine 8800gtx bäst mindestens 40 Watt mehr raus. Und dabei habe ich seit Monaten nicht mehr gezockt...Bei mir siehts bei 3600Mhz so aus:
IDLE @ 121,5W
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 8x
Fine CPU Clock Ratio...................:.+0.5
CPU Frequency .........................: 4.00 Ghz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 471MHz
PCI Express Frequency (Mhz) .........: Auto
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive.......................: 800mv
PCI Express Clock Drive...............: 900mv
CPU Clock Skew (ps)...................: 0ps
MCH Clock Skew (ps)...................: 0ps
DRAM Performance Control
Performance Enhance....................: [Standard]
Extreme Memory Profile (X.M.P.)........: disabled
(G)MCH Frequency Latch.................: 400
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ................: 942 Mhz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time..............................: 5
tRCD .........................................: 5
tRP'..........................................: 5
tRAS..........................................: 15
Advanced Timing Control [Press Enter]
tRRD...................................: Auto
tWTR...................................: Auto
tWR....................................: Auto
tRFC...................................: Auto
tRTP...................................: Auto
Command Rate (CMD) ....................: Auto
Channel A
Channel A Timings Settings [Press Enter]
Static tRead Value.....................: 10
tRD Phase0 Adjustmen...................: Auto
tRD Phase1 Adjustment..................: Auto
tRD Phase2 Adjustment .................: Auto
tRD Phase3 Adjustment..................: Auto
Trd2rd(Different Rank).................: Auto
Twr2wr(Different Rank).................: Auto
Twr2rd(Different Rank).................: Auto
Trd2wr(Same/Diff Rank).................: Auto
Dimm1 Clock Skew Control...............: Auto
Dimm2 Clock Skew Control...............: Auto
DDR2 Write Training......................: Auto
Channel A Driving Settings [Press Enter]
Driving Strength Profile.................: Auto
Data Driving Pull-Up Level.............: Auto
Cmd Driving Pull-Up Level..............: Auto
Ctrl Driving Pull-Up Level.............: Auto
Clk Driving Pull-Up Level..............: Auto
Data Driving Pull-Down Level..........: Auto
Cmd Driving Pull-Down Level...........: Auto
Ctrl Driving Pull-Down Level..........: Auto
Clk Driving Pull-Down Level...........: Auto
Channel B
Channel B Timings Settings [Press Enter]
Static tRead Value......................: 10
tRD Phase0 Adjustmen....................: Auto
tRD Phase1 Adjustment...................: Auto
tRD Phase2 Adjustment ..................: Auto
DDR2 Write Training....................: Auto
Channel B Driving Settings [Press Enter]
Driving Strength Profile................: Auto
Data Driving Pull-Up Level..............: Auto
Cmd Driving Pull-Up Level...............: Auto
Ctrl Driving Pull-Up Level..............: Auto
Clk Driving Pull-Up Level...............: Auto
Data Driving Pull-Down Level...........: Auto
Cmd Driving Pull-Down Level............: Auto
Ctrl Driving Pull-Down Level...........: Auto
Clk Driving Pull-Down Level.............: Auto
{U]Motherboard Voltage Control{/U]
Loadline Calibration.………...........: Disabled
CPU Vcore….……….....................: 1,38125V
CPU Termination…..... 1.200V*......: 1,32V
CPU PLL…………………....1.500V*..........: 1,50V
CPU Referen.…………....0.76V*.........: Auto
MCH/ICH
MCH termination...1.100V...........: 1,3V
MCH Reference….…….0.760V...........: Auto
MCH/DRAM Ref.…......0.900V.........: Auto
ICH I/O……………….....1.50V............: 1,5V
ICH Core…………...……1.100V............: 1,1V
DRAM
DRAM Voltage ……....1.800V.............: 2,1V
DRAM Termination .…0.900V.............: Normal
Channel A Reference 0.900V............: Normal
Channel B Reference 0.900V............: Normal
Wieso? Die 4870 frisst nahezu genau soviel wie eine G80 GTX
http://www.computerbase.de/artikel/...60_216_shader/25/#abschnitt_leistungsaufnahme
Wenn du sparen willst hol dir eine 260 GTX oder meine G92 (*werbung* steht zum Verkauf *werbung*, so nun aber bitte wieder ontopic![]()
@ http://www.forumdeluxx.de/forum/member.php?u=29747schnarx, als ich die 4000MHz (die mit Prime über 13 Std. stabil lief) mit IBT überprüfte, wars vorbei mit der Herrlichkeit. Da war nix zu wollen, immer wieder Fehler. Hatte es aber auch schon anders rum, IBT lief 60 Runs und der PC ist bei Prime einfach eingefroren...
Danke schonmal für die Infos!
---------- Beitrag hinzugefügt um 16:22 ---------- Vorheriger Beitrag war um 16:21 ----------
Richtig!
---------- Beitrag hinzugefügt um 16:32 ---------- Vorheriger Beitrag war um 16:22 ----------
Falsch, DVI überträgt 0,00 Sound, HDCP hat damit nix zu tun.
dvi = digital video interface.
Screen von der Fehlermeldung und Version von prime + ET 6 mit CPU z allem drum und dran bitte.Ich habe mich da nicht sonderlich verständlich ausgedrückt.
Ich bin gerade erst dabei 4 GHZ stabil zum laufen zu bekommen, nicht zu testen ob noch mehr Spielraum besteht. 4 GHZ sind mein Ziel, mehr brauchts nicht. Vor allem weil schon abzusehen ist das für wenige MHZ viel Leistung verbraten werden muss.
Wie geschrieben steigen bei Prime nicht einzelne Cores aus - das Programm steigt aus (schliest sich oder bringt einen Anwendungsfehler).
Jemand Erfahrungen diesbezüglich? Liegt hier bei "small" auch eine zu niedrige Vcpore zugrunde?
