time dd if=/dev/zero of=/Volumes/SOMEDISK/testfile bs=1024k count=2048
time dd of=/dev/null if=/Volumes/SOMEDISK/testfile bs=1024k
time dd if=/dev/zero of=/Volumes/OS-X/testfile bs=[B]4k[/B] count=2048000
2048000+0 records in
2048000+0 records out
8388608000 bytes transferred in 152.481497 secs ([B]55013940 bytes/sec[/B])
real 2m32.587s
user 0m4.235s
sys 0m44.268s
time dd if=/dev/zero of=/Volumes/OS-X/testfile bs=[B]64k[/B] count=50000
50000+0 records in
50000+0 records out
3276800000 bytes transferred in 40.938386 secs ([B]80042237 bytes/sec[/B])
real 0m40.988s
user 0m0.129s
sys 0m4.621s
time dd if=/dev/zero of=/Volumes/OS-X/testfile bs=[B]1024k[/B] count=4096
4096+0 records in
4096+0 records out
4294967296 bytes transferred in 52.265865 secs ([B]82175380 bytes/sec[/B])
real 0m52.868s
user 0m0.025s
sys 0m6.187s
time dd of=/dev/null if=/Volumes/OS-X/testfile bs=[B]4k[/B]
8388608000 bytes transferred in 97.728273 secs ([B]85836040 bytes/sec[/B])
real 1m37.732s
user 0m3.943s
sys 0m16.933s
time dd of=/dev/null if=/Volumes/OS-X/testfile bs=[B]1024k[/B]
4096+0 records in
4096+0 records out
4294967296 bytes transferred in 48.991758 secs ([B]87667140 bytes/sec[/B])
real 0m48.996s
user 0m0.028s
sys 0m4.311s
time dd if=/dev/zero of=/Volumes/Mobi/testfile bs=4k count=100000
100000+0 records in
100000+0 records out
409600000 bytes transferred in 7.656719 secs (53495499 bytes/sec)
real 0m7.672s
user 0m0.341s
sys 0m6.289s
time dd if=/dev/zero of=/Volumes/Mobi/testfile bs=64k count=50000
50000+0 records in
50000+0 records out
3276800000 bytes transferred in 45.960803 secs (71295534 bytes/sec)
real 0m46.117s
user 0m0.201s
sys 0m12.750s
time dd if=/dev/zero of=/Volumes/Mobi/testfile bs=512k count=8192
8192+0 records in
8192+0 records out
4294967296 bytes transferred in 59.004172 secs (72790909 bytes/sec)
real 0m59.370s
user 0m0.053s
sys 0m13.808s
time dd if=/dev/zero of=/Volumes/Mobi/testfile bs=1024k count=8192
8192+0 records in
8192+0 records out
8589934592 bytes transferred in 128.928569 secs (66625533 bytes/sec)
real 2m9.344s
user 0m0.072s
sys 0m29.715s
time dd if=/dev/zero of=/Volumes/Mobi/testfile bs=1024k count=4096
4096+0 records in
4096+0 records out
4294967296 bytes transferred in 64.909436 secs (66168612 bytes/sec)
real 1m5.573s
user 0m0.037s
sys 0m16.665s
time dd of=/dev/null if=/Volumes/Mobi/testfile bs=4k
2097152+0 records in
2097152+0 records out
8589934592 bytes transferred in 110.297992 secs (77879338 bytes/sec)
real 1m50.311s
user 0m6.600s
sys 0m32.500s
time dd of=/dev/null if=/Volumes/Mobi/testfile bs=64k
131072+0 records in
131072+0 records out
8589934592 bytes transferred in 105.714398 secs (81256052 bytes/sec)
real 1m45.728s
user 0m0.498s
sys 0m17.476s
time dd of=/dev/null if=/Volumes/Mobi/testfile bs=512k
16384+0 records in
16384+0 records out
8589934592 bytes transferred in 106.586584 secs (80591143 bytes/sec)
real 1m46.600s
user 0m0.116s
sys 0m18.007s
time dd of=/dev/null if=/Volumes/Mobi/testfile bs=1024k
8192+0 records in
8192+0 records out
8589934592 bytes transferred in 98.903258 secs (86851887 bytes/sec)
real 1m38.918s
user 0m0.071s
sys 0m18.283s
time dd if=/dev/zero of=/Volumes/Macintosh\ HD/testfile bs=4k count=100000
100000+0 records in
409600000 bytes transferred in 15.222981 secs (26906688 bytes/sec)
real 0m15.573s
user 0m0.363s
sys 0m4.008s
time dd if=/dev/zero of=/Volumes/Macintosh\ HD/testfile bs=64k count=50000
50000+0 records in
50000+0 records out
3276800000 bytes transferred in 98.372665 secs (33310066 bytes/sec)
real 1m38.454s
user 0m0.253s
sys 0m9.285s
time dd if=/dev/zero of=/Volumes/Macintosh\ HD/testfile bs=512k count=8192
8192+0 records in
8192+0 records out
4294967296 bytes transferred in 140.600015 secs (30547417 bytes/sec)
real 2m21.596s
user 0m0.058s
sys 0m11.056s
time dd if=/dev/zero of=/Volumes/Macintosh\ HD/testfile bs=1024k count=8192
8192+0 records in
8192+0 records out
8589934592 bytes transferred in 301.296412 secs (28509913 bytes/sec)
real 5m1.916s
user 0m0.076s
sys 0m22.589s
time dd of=/dev/null if=/Volumes/Macintosh\ HD/testfile bs=4k
8589934592 bytes transferred in 294.551889 secs (29162721 bytes/sec)
real 4m54.558s
user 0m8.358s
sys 0m36.710s
time dd of=/dev/null if=/Volumes/Macintosh\ HD/testfile bs=64k
131072+0 records in
8589934592 bytes transferred in 327.150406 secs (26256836 bytes/sec)
real 5m27.228s
user 0m0.699s
sys 0m17.615s
time dd of=/dev/null if=/Volumes/Macintosh\ HD/testfile bs=512k
16384+0 records in
16384+0 records out
8589934592 bytes transferred in 319.211470 secs (26909856 bytes/sec)
real 5m19.271s
user 0m0.125s
sys 0m17.039s
time dd of=/dev/null if=/Volumes/Macintosh\ HD/testfile bs=1024k
8192+0 records in
8192+0 records out
8589934592 bytes transferred in 301.185141 secs (28520446 bytes/sec)
real 5m1.233s
user 0m0.069s
sys 0m17.606s
Bei der Vertex muss man erstmal Ergebnisse abwarten. Der Controller könnte die meisten MLC-typischen Probleme lösen. Vielleicht solltest du aber anstatt zur OCZ zur SuperTalent Ultradrive greifenIst ein gutes Stück günstiger aber vermutlich vom gleichen OEM-Hersteller, nur die Firmware wird sich mit Sicherheit unterscheiden.
Die Intel ist sehr gut, hat schon seinen Grund warum die viele kaufen, ABER für eine OS-Platte würde ich dennoch zur Mtron Mobi greifen. Die IOPS und die paar MB/s mehr im lesen machen den Kohl net fettWirst du vermutlich nicht mal merken.
Japp, ist SATA150.
Übrigens hat Journaling eher weniger mit der Geschwindigkeit zu tun. Journaling steht dafür, dass sich das Dateisystem selbst defragmentiert. Das ist eben die Frage ob das bei MLC-SSDs gut ist.
http://de.wikipedia.org/wiki/Journaling-DateisystemWiki schrieb:Ein Journaling-Dateisystem ist ein Dateisystem, welches alle Änderungen vor dem eigentlichen Schreiben in einem dafür reservierten Speicherbereich, dem Journal, aufzeichnet. Damit ist es zu jedem Zeitpunkt möglich, einen konsistenten Zustand der Daten zu rekonstruieren, auch wenn ein Schreibvorgang an beliebiger Stelle abgebrochen wurde. Diese Eigenschaft ist im Fall von Systemabstürzen oder Stromausfällen von Vorteil.
