[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Erster ^^
Jo danke für den Thread ^^
Lasst das Board aufleben, so dass es uns gute dienste erweisen wird.
Stimmt es eigentlich das die Gründer der firma ehemalige miarbeiter von Abit sind?
Finde das Layout mehr als gelungen.
@ Lochabstand
Könnte den einer von euch beiden messen?
Also ich bräuchte Die der mosfet kühlung, von loch zu loch.
Na ja, so teuer ist es dann auch nicht, gehobene mittelklasse...dafür hat es nicht jeder ;)
Wenn man überlegt wieviel Geld mache für Modding ausgeben....also optisch ist das Board erste Sahne, und die OC Eigenschaften sprechen für sich, hat mein altes M2N 32 SLI Deluxe 1std nach Einbau schon getoppt was x2 OC angeht, und das war ja nicht das schlechteste x2 Board ;)
die sonstigen Ergebnisse die man im Netz findet sprechen für sich. Werde alle Links die etwas über das Board aussagen bei Gelegenheit in den Startpost integrieren.
Jo des is super.
Freu mich auch schon...
aber du hast vorhinw as gesagt wegen kollidieren an der NB... NB werde ich mit der Spawa kühlung entfernen und Thermalright draufbauen... in kombination mit einem Ninja 2
Dürfte des passen`? weil ich hab keine lust auf noch einen Luftkühler, hab den Ninja ja schon.
Könnte klappen, garantieren kann ich es aber nicht ;)
ENDLICH wurde mal Zeit, interessiere mich auch sehr für das Board^^
jop...bestes Board,
wenn man überlegt, für den Preis erhält man ein schlechteres DFI!
Wir könnten mal zusammentragen wo es im Moment beim Board hakt, vor allem was den Deneb angeht. Ich weiss nur das sich der Multi und der NB Teiler nicht einstellen lässt, 4ghz sind trotzdem drinn siehe Screen im Startpost. Bin mal gespannt wie das Board dann mit dem kommenden Bios abgeht :p
Was meinst Du mit man kann den Multi nicht einstellen?
Den Multi der CPU? Hab auch Interesse an dem Board, aber wenn das so schon anfängt?!
Wie hoch geht denn die VCore?
find das board auch durchaus interessant und wenn das prob mit dem multi mit dem nächsten bios gelöst wird is das board noch attraktiver.
meine frage: hat mal jemand gemessen wie stabil die vcore unter last bleibt?
chef_lux
Also...
ich habe den 9950er...
Bei mir geht der Multi NUR bis 13 - Also 2,6Ghz !
EDIT/// Bilder von Bios und so FOLGEN
EDIT2// Leider wird meine Canon nicht erkannt :(
ja also das mit dem multi müssen se in griff bekommen...
wie ist des denn bei nem 3ghz phenom II?? läuft der nur mit 2,6 ghz? standartmulti müsste doch bei 15 liegen oder?
hat schon jemand probiert die nb zu übertakten?
Hallo zusammen :wink:
Ich würd gern seit langem auf AMD wieder umsteigen und hätte paar fragen an die besitzer dieses Board.
1. Wie siehts aus mit Bios updaten, geht das mit USB Stick oder in Win. weil ich hab kein Floppy :d
2. Kann mir jemand sagen oder der Noctua NH-U12P drauf passt?
3. Woher kommt denn J&W? Das ist aber net zufällig Jetway?
So genau weiss ich das auch nicht mit dem Multi, hab ja keine Black edition momentan, deneb kommt jetzt die Woche. Geht wohl nur über AOD mit dem Multi und ( noch ) nicht im Bios, genau weiss ich es jedoch nicht.
Hab nen X2 eingebaut, die Vcore geht im Bios bis 1.55v, könnte aber auch CPU abhängig sein, vielleicht kann Octa da nochmal gucken. Ich hab ausserdem noch Bios 1.0 drauf.
chef_lux
Mit dem x2 4800 @ 3ghz ist der drop 0,0125v. von dem ausgehend was im Bios eingestellt wird, unter Last nähert sich der wert bis auf 0,0095v. dem Wert im Bios. Anstatt zu droopen übervoltet das Board leicht aber nicht über den bios wert. Zb. : Bios 1.375 - CPUZ 1.360v. / Last = 1,368v.
Er wird wohl momentan mit seinem Standardmulti laufen, um die 3ghz brauchst du da keine Angst haben.
wie isen das eigentlich wenn ich auf das board nen athlon x2 setzt und dazu ddr2-1066 nehm? läuft der ram halt nur mit 800 oder? den speichercontroler schrott ich deshalb nicht oder?
dann wird nämlich das J&W zusammen mit nem Corsair Dominator bestellt und später dann nen AM3 Deneb (wegen des bessern Steppings) draufgeschnallt
Mein 9600er OCZ wurde auf 800er gesetzt, die Bezeichnungen im Bios sind anders als bei den Boards die ich vorher hatte deswegen komm ich mit den Biosoptionen noch nicht richtig klar, hab das Board ja erst seit heut Mittag in Betrieb.
mit OC kannst du auch mehr als 800 fahren.
Sicher, momentan läuft er als 1000er mit 4er Timings, HT 250. Werde morgen mal testen wie hoch HT und Ram gehen :d
@ Octa
Wie meinste das mit Slot 4 ? Liegt dann am Kühler denn mit meinem klitzekleinen Nexxos XP hab ich genug Platz :shot:
meint er wegem cpu kühler?
€dit: hat sich ja erledigt ;)
ich werd mal schauen wir die dominator mit meinem Noctua auf das board passen.
ach du meinst den ersten slot, net den vierten... hm naja gut damit kann man leben.
solang aber alles auch stabil ist wenn man slot 2 und 4 benutzt ist es ja den meisten egal.
ich hatte auch schon boards die sich weigerten ram auf slot 2 und 4 zu akzeptieren wenn slot 1 und 3 leer waren...
solang aber alles auch stabil ist wenn man slot 2 und 4 benutzt ist ja egal.
ja aber es gibt den unterschied, ob das Board streikt wegen den RAMs,
oder das die RAMs aufgrund des verbauten Kühlers nicht passen!
Ähnliche Themen
