Webforhunter
- Ort
- Erde
- Desktop System
- AsusRyzen 7 Power
- Ryzen 7 5700x
- ASUS TUF GAMING B550M-PLUS
- bequiet DarkRock 4
- 2x16Gb DDR4 CL18 Corsair 3600
- MSI RTX 5060ti 16Gb GDDR7
- AOC 32Zoll
- 500Gb SSD, 1.4Tb SSD extern, 2Tb M.2 NVMe
- HDD
- 4Tb
- Soundkarte
- Realtec
- MidiTower
- 650W
- Keyboard
- Logitech
- Mouse
- LogiTech
- Win10 Home
- Webbrowser
- MS
- Sonstiges
- Samsung Handy
- Internet
- ▼150 MBit ▲80 MBit
habe ein Problem mit der Garantieabwicklung über Intel. Die Konversation ist von Intel leider nur in English, mein English ist nicht so gut das ich Alles verstehe was Intel jetzt von mir möchte!
Also ich habe meine Systemconfiguration an Intel gesendet wie sie mir gesagt haben.
Hier ein Auszug:
ATTENTION
All system tests should be performed by a professional technician. Intel takes no responsibility for equipment damaged by inappropriate testing.
Please help us to help you. The more information you supply, the quicker we will be in identifying the issue.
Motherboard
Manufacturer: Asus
Model: Rampage Extreme
AA number:
Revision: 1.01
Serial Number: 117816632
BIOS version: 1001
Processor
Processor name: Intel Core 2 Extreme
Processor manufacturer:
Intel
SL Number: SLAN3
FPO Number: N373607
ATPO Number: 5A0683
Serial Number: L739B880
FAN Manufacturer: Delta
FAN serial number E19409-002
If you believe the CPU to be faulty please write here all the marks written in to top of the CPU Intel 06 QX9650
SLAN3 Malay
3.00GHZ/12M/1333/05B
L739B880
Memory
Manufacturer: OCZ
Model: Intel Extreme
Serial Number: 117830974
Type:
(E.g.: DDR3) PC3-12800
Capacity: DDR3
Power Supply
Manufacturer: Enermax
Model: ELT500AWT
Form factor: (E.g.: BTX) ATX
Serial Number: 801013964300
Watts: 500
Hard Disk (Please, add all hard disks)
Manufacturer: Maxtor
Model: 7V300F0
Firmware version: Maxline 3
Serial Number: V60KB86G
Interface:
(E.g.: SATA) SATA
Graphics Card
Manufacturer: Leadtek
Model: Lead 1GB D3 X GTX280
Interface: PCI-e
Serial number: L8060011273
Other PCI / PCI-x / PCI-e cards (Please, add all cards.)
Manufacturer:
Model:
Interface:
Serial number:
Operating System
Manufacturer: Microsoft Windows
Name: (E.g.: Windows XP Professional) Vista 64
Operating System Language: german
Patch: (E.g.: SP2)
Problem Description
Please enter as much information about the problem as possible:
The computer run only 5 secunds than goes off.
CROSS TESTED EQUIP.
Cross MBD: Asus Maximus Extreme
Compatible with CPU?: yes
Web site:
BIOS version required?:
Actual BIOS version:
Results: processor runs only 5 secunds than goes off.
Cross CPU: Intel Core 2 Extreme 3.2GHZ
SL#:AN3
Compatible with MBD?: yes
Web site:
Results: ok
Jetzt kam eine Antwort von Intel:
Dear Mr. Winfred Schoefzig, Thank you for contacting Intel® Technical Support. We are pleased to assist you within the scope of Intel® limited warranty.
I have analyzed your system configuration, first of all your original motherboard is not compatible with your QX9650 processor. Other than this, the cross tested motherboard Asus Maximus Extreme requires a minimum BIOS of 0602.
You have not provided the BIOS version of this motherboard. Please understand that we will need to be 100 percent sure that our CPU is faulty before we can replace it.
Please check the details I have stated above and make sure you are using compatible configuration. If you have any further queries regarding this or any other issue, please do not hesitate to contact us.
Kind regards Cemal C.
Was soll ich jetzt machen?
Bitte um Vorschläge!!
Web
Hier ein Auszug:
ATTENTION
Motherboard
Manufacturer: Asus
AA number:
Revision: 1.01
BIOS version: 1001
Processor
Intel
SL Number: SLAN3
FPO Number: N373607
ATPO Number: 5A0683
SLAN3 Malay
L739B880
Memory
Manufacturer: OCZ
Type:
Capacity: DDR3
Power Supply
Model: ELT500AWT
Watts: 500
Model: 7V300F0
Interface:
(E.g.: SATA) SATA
Graphics Card
Interface: PCI-e
Manufacturer:
Model:
Interface:
Serial number:
Operating System
Patch: (E.g.: SP2)
Problem Description
CROSS TESTED EQUIP.
Web site:
SL#:AN3
Web site:
Results: ok
Web
