Asrock Conroe865PE Erfahrungen?
Hi, HarlockP4, welcome in this thread.
My problem is that I cannot have a stable system just raising up FSB from 266Mhz to 270Mhz, somebody in the past told me that perhaps my MB is defective, what do you think about that?
I don´t think, that your board is defective.
I have the same problem with my Q6700.
Our board is not so good for oc.
I think, the chipset is too old for this cpus.
Sorry, for my bad english.
Ich werd bis dahin nur die nötigsten Altspiele auf dem kleinen Rechner ganz gemütlich nachholen.
Wieso nur Altspiele?
Z.Z. spiel ich "Crysis-WH" mit den Einstellungen"Gamer" auf 1280x1024 und es läuft einwandfrei.
ablev
Normally the i865pe does 200Mhz FSB, so I think 266Mhz is quite good for such an old chipset.
The 865 Chipset was originally designed to run 200 MHz FSB !
It is only to ASROCK that they made this Mainboard to run 266 MHz. It is a factory overclocked Chipset. !
You shold´nt be concrened about not coming farhter than 266 MHz. :wink:
Dont be sorry, it is just the end of the Signpost, Flagmast ... whatever. :)
EDIT:
AND WELCOME TO THE FORUM !!! :wink: (for 1st post)
(I almost forgot about it !)
@ Ablev
Ich will damit nur sagen, dass ich alle Spiele immer in nativer Aulfösung spiele. Die ATI Karte erlaubt mir das mit der Skalierung eben egal von dem Bildschirm den ich verwende.
Ich kann so auch ein furztrockenes alres Adventure Game in nativer Auflösung geniessen.
So sitze ich im Wohnzimmer immer in der ersten Reihe ! :d
Broken Sword ( Baphomets Flucht ) Teil 1- 4 machen so wieder richtig Spass ! :)
@Ablev
Thank you for your welcome and your English it's not so bad
Try to read this :
http://www.pctreiber.net/beitrag5798,threadview,0,hilight,3,hilightuser,0,seite4.html
The user Lemonadesoda is able to use FSB300 on Q6600
However I think that it's impossible that we got a problem just with +4Mhz
Perhaps there is to Vmod something on MB as Shaguar spoke below.
For Example with a Boot cd of Memtest86+ I got all test works at 293Mhz but windows doesn't start, really strange and now I loose the 2nd HD ide I lost the 1st one few months ago.
Tomorrow I will try an identical moderboard and I think that if in the BIOS we can raise up to 300Mhz then there is a way to do so.
And another thing if I leave the FSB to auto instead of manual I got 260Mhz
Actually I use x12 multiplier and I'm stable with 3,2Ghz and 2-3-3-5 but 3:2 divider it's not good I would like to have a 1:1 Bios to use the power of my 2GB of DDR600Mhz
So any similar situation here?
I didnt mean a Vmod to the mobo ! I meant to chachge the Vid of the Processor, as ist is described in this trhread.
I ´ll go and search again.....
EDIT:
If you are hapy whith the Stuff and you are runing Exxel (MS) you can juse this. (LINK below)
sorry , will change link soon -.....
698
This is the one .. :)
EDIT2: !!!!
Und Dank der BESCHISSENEN Standard NO NAME PSU sitz ich hier mit 2000 MHz fest. ! ÄRGER
Allerdings weiss ich auch nicht, was ich mit mehr als 2 GHz anfangen soll.
E4700
Hi ich will ja jetzt VID mod machen was glaubt ihr was ich meiner CPU an Spannung zumuten kann?
Kühlung sollte kein Problem darstellen.
Gruß Marc
Um welchen handelt es sich denn?
@ Dracal 2002
Ich hab im Hauptrechner eine E6600 mit 1.53xx V seit zwei Jahren unter Wasser laufen. !
Es ist den core 2 duo Dingern fast völlig egal ! Hauptsache die Kühlung stimmt !
Das ist gut zu wissen meiner läuft im moment bei vollem Load bei 38°C pro core also dürfte da schon noch was gehen an Spannung. Werd mal so 1.45 probieren.
Welche Temp sollte er nicht überschreiten für Dauerload?
Hi Guys,
I got a news, I have just changed the MB with another equal one, and now I can run at 300Mhz FSB and x11 multiplier. So I used a faulty one.
Now I have just to tweak a little windows xp couse is not stable
I would like to have a 1:1 Bios now I'm using the very last one 1.71a
Any suggestion?
I don't think that the board was faulty. I think chipsets are like processors: One can run at very high clocks, another one not.
What do you mean with "1:1 Bios"?
Ok, I 've performed 2 passes of Memtest86+ with no error with FSB 300Mhz x11 multiplier and 2,5-4-4-8, but Windowsxp is not stable. Any suggestion please?
Ok yesterday I reached 12054 points at 3Dmarks06
FSB = 294Mhz
Multiplier = 11
RAM = 2 - 3 - 3 - 6
In Bios I've activated Spread Spectrum or 3Dmarks06 crash
Enhalt ...........
Virtualization ..............
All the rest in the same screen disabled
I also overclock my 3850 to 802/1002
I think I can get a little more, any suggestion?
Guys new record 12341!!! by overclocking a little more my HIS, WOW :banana:
I had to repeat the test to grab also the details and ...........
Same config.
x11 Multiplier
294Mhz FSB
His 3850Agp @824/1035
12349 points!!!! New Record :banana:
Quote:
Originally Posted by HarlockP4 View Post
12349 points!!!!
Cool, very nice result for AGP and DDR1.
ablev
You should be able to do the same, you have my same stuff, what Bios do you use on Conroe865PE? And what for HIS?
Oh no, our systems are different.
My ram is not so good like yours and you have a qx6700 with free multiplier.
I have a q6700 and my multi is fixed to 10.
I can only oc with fsb.
When i set CPU:Ram to 3:2, i can oc to 280 FSB, but not stable.
I don´t understand your question about my HIS.
It´s the same like yours.
My Conroe bios is also like yours. 1.71
Edit: The HIS bios is original.
ablev
@ablev
Ich schätz mal er will wissen welche Firmware/Bios Version deine HIS Karte hat.
Guys I've got a problem this MB is equal to other that I use, but it seems that I cannot use any USB external HD, it seems that it's not totally compatible with my Promise FastTrak TX4310, can you help me please ?
C2D E4700 vs. Pentium DC E5200
Hallo liebe ASRock Conroe Gemeinde,
im Moment spiele ich mit dem Gedanken, meinen E4300 durch einen C2D E4700 oder Pentium DC E5200 zu ersetzen.
Für den C2D E4700 spricht der etwas höhere Grundtakt durch den Multiplikator von 13. Für den Pentium DC E5200 - sofern er überhaupt auf unserem Board läuft (Multiplikator 12,5!) - spricht die modernere Architektur.
Was meint Ihr dazu?
Gruss Andi
Hmm, schwierige Frage.
Hier im Thread hat ja schon Einer oder Zwei den 4700 und scheint ja zufrieden damit zu sein.
Also machst Du sicher nichts falsch mit dem 4700.
Ich würde mich, allerdings, für den 5200 entscheiden, weil´s für mich interessanter wäre zu testen, wie Der auf unserem Board läuft.
@HarlockP4, I have no experience with your FastTrak TX4310, i´ve been using this simple controler:
http://www3.avitos.com/shop/info.as...ros_search.asp&from=&cnet_catid=&avalibility=
and it works very good with my 3 int.SataHD´s.
With jumper, i can set 2 int.HD´s, 2 ext.HD´s( eSata) or 1 int. and 1 ext.HD.
In the near time, i would like to buy an ext. 500 Gb HD for backup and hope it works equally well.
ablev
And the winner is: INTEL DualCore E5200
@ablev
Ich würde mich, allerdings, für den 5200 entscheiden, weil´s für mich interessanter wäre zu testen, wie Der auf unserem Board läuft. ablev
Hallo ablev,
Du hast Recht - no risk no fun. Habe mir gerade für 66,-- Euro + Versand den INTEL DualCore E5200 bei ALTERNATE bestellt.
Bin schon mal gespannt, was unser Board dazu meint... :rolleyes:
Gruss Andi
@ andilist
http://uneit.com/2008/07/06/intel-e5200-performance-in-overclocking/
Silberlack solltest schon mal in der Hand halten. Schon erstaunlich was die aus dem Dingen rausholen . Die 288 Bus schaffste vielleicht auch.Wären dann mit 3,6 Ghz
Nur die Temp dabei wird für dich eine neue Erfahrung sein . Abei 78 pro Core geht ja noch, darf ja immerhin 105 erreichen. Schaut zumindest auf den Bildern so aus.
Mal´ne ganz andere Frage.
Ich habe ja weiter oben geschrieben, dass ich im Bios "DRAM Voltage" and "CPUs FSB Voltage" auf " high" gesetzt habe, aber für welche Voltzahlen steht, eigendlich, "High" und "Low" ?
Everest und CPU-Z zeigen mir immer die gleichen Voltzahlen, egal ob ich "High" oder "Low" einstelle.
Gibt´s ein Proggi, mit Dem ich das auslesen kann?
ablev
