kann mir hier jemand im Festplatten-Forum, 4 Fehler im S.M.A.R.T. Error Log meiner neuen WD30EZRX erklären bzw. was diese bedeuten?
Danke!
smartctl 5.41 2011-06-09 r3365 [i686-w64-mingw32-win7(64)-sp1] (sf-win32-5.41-1)
Copyright (C) 2002-11 by Bruce Allen
=== START OF INFORMATION SECTION ===
Device Model: WDC WD30EZRX-00MMMB0
Serial Number: WD-************
LU WWN Device Id: 5 0014ee 0585cba3d
Firmware Version: 80.00A80
User Capacity: 3.000.592.982.016 bytes [3,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sun Feb 19 23:03:49 2012 MZ
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (51480) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 202 170 021 Pre-fail Always - 6858
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 21
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 7
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 12
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 33
194 Temperature_Celsius 0x0022 125 121 000 Old_age Always - 27
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 4
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 4 occurred at disk power-on lifetime: 2 hours (0 days + 2 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 51 01 30 4f c2 e0 Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d6 01 be 4f c2 e0 00 00:07:54.275 SMART WRITE LOG
b0 da 01 00 4f c2 e0 00 00:07:54.212 SMART RETURN STATUS
80 44 00 00 44 57 e0 00 00:07:54.212 [VENDOR SPECIFIC]
b0 d6 01 be 4f c2 e0 00 00:07:54.182 SMART WRITE LOG
80 45 00 00 44 57 e0 00 00:07:54.182 [VENDOR SPECIFIC]
Error 3 occurred at disk power-on lifetime: 2 hours (0 days + 2 hours)
04 51 01 30 4f c2 a0 Error: ABRT
b0 d6 01 be 4f c2 a0 00 00:04:37.982 SMART WRITE LOG
b0 da 01 00 4f c2 a0 00 00:04:37.918 SMART RETURN STATUS
80 44 00 00 44 57 a0 00 00:04:37.918 [VENDOR SPECIFIC]
b0 d6 01 be 4f c2 a0 00 00:04:37.884 SMART WRITE LOG
80 45 00 01 44 57 a0 00 00:04:37.884 [VENDOR SPECIFIC]
Error 2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
b0 d6 01 be 4f c2 e0 00 00:09:37.235 SMART WRITE LOG
b0 da 01 00 4f c2 e0 00 00:09:37.172 SMART RETURN STATUS
80 44 00 00 44 57 e0 00 00:09:37.172 [VENDOR SPECIFIC]
b0 d6 01 be 4f c2 e0 00 00:09:36.709 SMART WRITE LOG
80 45 00 00 44 57 e0 00 00:09:36.709 [VENDOR SPECIFIC]
Error 1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
b0 d6 01 be 4f c2 a0 00 00:06:20.542 SMART WRITE LOG
b0 da 01 00 4f c2 a0 00 00:06:20.479 SMART RETURN STATUS
80 44 00 00 44 57 a0 00 00:06:20.479 [VENDOR SPECIFIC]
b0 d6 01 be 4f c2 a0 00 00:06:20.444 SMART WRITE LOG
80 45 00 01 44 57 a0 00 00:06:20.444 [VENDOR SPECIFIC]
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Conveyance offline Completed without error 00% 2 -
# 2 Conveyance offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Danke!
