hi
habe eine wd250js (sata)
habe 2 patitionen drauf, und auf eine kann ich ned zurückgreifen.
eine formation ist auch ned möglich mit partion magic da eine fehler meldung kommt.
General System Information:
Total Physical Memory (bytes): 1,073,201,152
Used Physical Memory: (bytes): 301,367,296
Maximum Page File Size: (bytes): 2,581,155,840
Current Page File Size: (bytes): 242,114,560
Disk Geometry Information for Disk 1: 30401 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
0 0 80 0 1 1 07 1023 254 63 63 126,849,177
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 0 80 0 1 1 07 7895 254 63 63 126849177
0 1 00 1023 0 1 0F 1023 254 63 126,849,240 361,542,825
Info: Begin C,H,S values were large drive placeholders.
Actual values are:
0 1 00 7896 0 1 0F 30400 254 63 126849240 361542825
126,849,240 0 00 1023 1 1 07 1023 254 63 126,849,303 361,542,762
Actual values are:
126849240 0 00 7896 1 1 07 30400 254 63 126849303 361542762
Disk Geometry Information for Disk 2: 484406 Cylinders, 16 Heads, 63 Sectors/Track
DellUtility 0 0 00 0 1 1 DE 6 254 63 63 112,392
Info: Partition didn't end on cylinder boundary.
ucEndHead expected to be 15, not 254.
Error #110: Number of sectors in partition is inconsistent.
ucSectors = 112392
end - begin = 22050
0 1 80 7 0 1 17 1023 254 63 112,455 356,369,895
Actual values are:
0 1 80 7 0 1 17 353653 1 63 112455 356369895
Error #108: Partition didn't end on cylinder boundary.
ucEndHead expected to be 15, not 1.
Error #116: Starting sector of partition is inconsistent.
ulStartSect = 112455
Begin C,H,S = 7056
ucSectors = 356369895
end - begin = 356475294
0 2 00 1023 0 1 0F 1023 254 63 356,498,415 122,029,740
Actual values are:
0 2 00 353669 1 1 0F 474730 4 63 356498415 122029740
ucEndHead expected to be 15, not 4.
0 3 00 1023 0 1 DB 1023 254 63 478,528,155 9,735,390
Actual values are:
0 3 00 474730 5 1 DB 484388 6 63 478528155 9735390
Info: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 5.
ucEndHead expected to be 15, not 6.
356,498,415 0 00 1023 1 1 07 1023 254 63 356,498,478 122,029,677
Actual values are:
356498415 0 00 353669 2 1 07 474730 4 63 356498478 122029677
Error #105: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 2.
Partition Information for Disk 2: 238,418.6 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects
ellUtility Dell Pri 54.9 0 0 63 112,392
Hidden NTFS Pri,Boot 174,008.7 0 1 112,455 356,369,895
Unallocated Pri 7.4 None -- 356,483,232 15,120
ExtendedX Pri 59,584.8 0 2 356,498,415 122,029,740
EPBR Log 59,584.8 None -- 356,498,415 122,029,740
E: NTFS Log 59,584.8 356,498,415 0 356,498,478 122,029,677
CP/M, Concurrent DOS, CTOSPri 4,753.6 0 3 478,528,155 9,735,390
Unallocated Pri 8.4 None -- 488,264,112 17,136
Actual values are:
Actual values are:
Actual values are:
ucSectors = 112392
end - begin = 22050
Actual values are:
Begin C,H,S = 7056
Actual values are:
Actual values are:
Actual values are:
