Sniper1010
Greetings to all of you,
I was wondering if there is a suitible waterblock for the Zotac GTX 260 Amp2!??
its a 65nm based design.
Here is a link for more info:
http://www.techpowerup.com/reviews/Zotac/GeForce_GTX_260_Amp2_Edition/
I was thinking to get a Aquacomputer aquagrfx link:
http://www.aquatuning.de/product_in...quagraFX-for-GTX-280-GTX-260--G200--G1-4.html
Will this fit on a zotac gtx 260 amp2? Because the gpu block needs a reference pcb in order to be compatible. Or do you guys have other gpu blocks that will fitt on this Zotac gpu?
Thanks in advance
Thanks in advance
