Wasserkühlung
Zboy
Hi guys sorry to write in english but my german is not perfect.
So im thinking about but Wasserkühlung on my computer.
Can you tell me what i need o-rings and all that thing.
can you tell me the things i need?
thanks alot
If you're an absolute beginner in watercooling, you should study some guides und general Information first!
Especially, there are some helpful Videos on YT, e.g. https://www.google.de/#q=Guide+to+Water+Cooling&tbm=vid This is one which is nice made: The Complete Beginners How Guide Watercool your PC - YouTube (in English language!)
If you can understand german, there is also a couple of Videos from the german reseller Caseking, where the Basic parts of an watercooling Loop ar explained: Wasserkühlung Caseking - YouTube
These are the parts you always need:
- Pump
- Water Reservoir
- Water block for CPU and, if wanted, GPU too (in most cases, you don't need blocks for other components like Mainboard, RAM etc.)
- Radiator(s) with fans (Radiators can be mounted inside the case, if it's suited, and/or outside. The more/bigger you choose the radiators, the better is the cooling result!)
- Tubing
- Fittings (generally, you need two fittings for each part; therefore, for a simple loop only for CPU-cooling, you Need 8 fittings in total: two each for pump, reservoir, water block and Radiator. However, there are combinated offers with pump and reservor already built together, e.g. this one: http://geizhals.at/eu/ek-water-blocks-ek-xres-140-d5-pwm-a1190087.html: for these ones, you need only 2 instead of 4 Fittings, namely in- and outlet)
- Coolant
There are some additional options like adjustment stuff etc., but these are not really necessary for a working cooling loop, more something like "luxury" ;)
Greez N.
ok thanks alot mate.
i will check date i i will buy some.
But first i need buy a new CPU case mine is to little
- - - Updated - - -
do you know any good site here in germany with good prices?
In my opinion is Aquatunig.de one of the best.
Good prices and fast delivery.
Can you tell us more about your system?
Case, CPU, GPU...
How much money you want to spend?
Greetings
CPU block: Phobya CPU-Cooler UC-2 LT Intel 775,1155,1156,1366,2011 - Silver Nickel Black Edition | CPU - Wasserkühler | CPU - Kühler | Wasserkühlung | Aquatuning Germany
Phobya CPU Mainboard Backplate 775/1366/1150/1155/1156/2011 | CPU - Backplates | CPU - Kühler | Wasserkühlung | Aquatuning Germany
PUmp: pls help me here what i need choose: Pumpen | Wasserkühlung | Aquatuning Germany
Water Reservoir: help me here pls : Ausgleichsbehälter | Wasserkühlung | Aquatuning Germany
Radiator: Aquacomputer airplex radical 2/360, Alu-Lamellen | Radiatoren aktiv | Radiatoren | Wasserkühlung | Aquatuning Germany
so i will tell you what amterial i have in my computer.
Asrock X79 Extreme3 ​​Motherboard LGA 2011
Intel Sandy Bridge Core i7-3820 E (3.6 GHz, LGA 2011)
Zalman CNPS12X Cooler ( at the moment)
MSI N660 GTX placa gráfica NVIDIA
Corsair Vengeance RAM (PC1600, 8GB, CL9
HyperZ 4 GB
Pure Power CM BQT L8-CM-630W PC Netzteil (630 Watt)
I would recommend an Aquastream XT - maybe the Ultra-Version, so you can control the fans(up to 3).
For the Aquastream you will need an inlet- and an outlet-adaptor.
As reservoir I would recommend an Aqualis reservoir because they are made of borosilicate glass instead of acrylic glass.
Are you sure that you can install a 360mm radiator in your case?
Greetings
Hier sind doch bestimmt noch mehr fähige Leute, deren englisch (etwas) besser ist als meins, oder? ^^
im thinking about buy a new tower.
but i still dont know if i stay with this tower .
she is black with fan blue, if i stay with this i will put the water color blue. Or i change the fans and i will put red.
what do you think?
- - - Updated - - -
guys here is my list
http://prntscr.com/5bnclh
http://prntscr.com/5bncvd
so just tell me if i need buy more anything,
ahhh and other thing it's possible to buy the cables who connecte the graphic to the power supply, to the HHD and to the motherboard, dvd reader, in UV color? because i want put all red. it's possible
thanks alot for all the help
