alles was ich hab
(MSI MS-7366) Da unten steht alles BIOs usw...
CPU-Z TXT Report
Binaries
CPU-Z version 1.52.2
Processors
Number of processors 1
Number of threads 2
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium E5200
Codename Wolfdale
Specification Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.7.6
Extended CPUID 6.17
Core Stepping M0
Technology 45 nm
Core Speed 1200.0 MHz
Multiplier x FSB 6.0 x 200.0 MHz
Rated Bus speed 800.0 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 12.5x
Max VID 1.225 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008006h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
CPUID
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00010676 0x00020800 0x0000E39D 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB4307D
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x04000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04004143 0x01C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00022220
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000503
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20100800
0x80000002 0x746E6550 0x286D7569 0x44202952 0x2D6C6175
0x80000003 0x65726F43 0x50432020 0x20202055 0x45202020
0x80000004 0x30303235 0x20402020 0x30352E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x08006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x00000017 0x04000000 0xAE84CC20
MSR 0x000000CD 0x00000000 0x00000802
MSR 0x0000003F 0x00000000 0x00000000
MSR 0x000000CE 0x001A4C20 0x19190716
MSR 0x000001A0 0x00000040 0x62972489
MSR 0x000000EE 0x00000000 0x867D0300
MSR 0x0000011E 0x00000000 0xBE702107
MSR 0x0000019C 0x00000000 0x883B0000
MSR 0x00000198 0x061A4C20 0x0600061A
MSR 0x00000199 0x00000000 0x0000061A
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008006h
CPUID
0x00000001 0x00010676 0x01020800 0x0000E39D 0xBFEBFBFF
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x0000019C 0x00000000 0x883A0000
Chipset
Northbridge NVIDIA GeForce 7100 rev. A2
Southbridge NVIDIA nForce 630i rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 4096 MBytes
Channels Single
Memory Frequency 400.0 MHz (1:2)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 4
RAS# Precharge (tRP) 4
Cycle Time (tRAS) 14
Bank Cycle Time (tRC) 24
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) OCZ (7F7F7F7FB0000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number OCZ2RPR10662G
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP yes (1 profiles)
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-4-4-10-16 @ 266 MHz
JEDEC #2 4.0-5-5-13-20 @ 333 MHz
JEDEC #3 5.0-5-5-15-24 @ 400 MHz
EPP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
EPP profile #1 (full) 5.0-5-5-15-26-2T @ 533 MHz (2.200 Volts)
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 08 38 01 02 00 07 30 50 3D 60 32 1E 32 25 01
20 17 25 05 12 3C 1E 1E 00 02 3C 85 80 14 1E 00 00
30 00 03 00 00 00 00 00 00 00 00 00 00 00 00 10 AB
40 7F 7F 7F 7F B0 00 00 00 02 4F 43 5A 32 52 50 52
50 31 30 36 36 32 47 20 20 20 20 20 02 AB 00 00 00
60 00 00 00 6D 56 4E B1 21 00 00 00 00 00 00 00 00
70 00 00 00 00 90 50 01 20 25 1E 20 25 25 1C 2D 30
80 08 0C 1B 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 2048 MBytes
Number of banks 2
Data width 64 bits
Correction None
XMP no
SPD registers
Monitoring
Mainboard Model MS-7366 (0x000001A3 - 0x005F1CF6)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71882F
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x541
Config Mode I/O address 0x4E
Config Mode LDN 0x4
Config Mode registers
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 05 41 20 19 34 00 80 5F 00 00 40 60 08 00 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A00
Hardware Monitors
Hardware monitor Fintek F71882F
Voltage 0 3.39 Volts [0xD4] (+3.3V)
Voltage 1 1.14 Volts [0x8F] (CPU VCORE)
Voltage 2 1.89 Volts [0x76] (VIN2)
Voltage 3 1.14 Volts [0x61] (VIN3)
Voltage 4 5.13 Volts [0x7A] (+5V)
Voltage 5 12.32 Volts [0x8C] (+12V)
Voltage 6 1.82 Volts [0x72] (VIN6)
Voltage 7 3.39 Volts [0xD4] (VSB3V)
Voltage 8 3.09 Volts [0xC1] (VBAT)
Temperature 0 36°C (96°F) [0x24] (TMPIN0)
Temperature 1 38°C (100°F) [0x26] (TMPIN1)
Fan 0 874 RPM [0x6B5] (FANIN0)
Fan PWM 0 38 pc [0x60] (CPU)
Fan PWM 1 100 pc [0xFF] (System Fan 1)
Fan PWM 2 100 pc [0xFF] (System Fan 2)
Fan PWM 3 50 pc [0x80] (System Fan 3)
00 FF 03 00 00 FF FF FF FF FF FF 00 00 55 4C 00 00
10 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
20 D4 8F 76 61 7A 8C 72 D4 C1 FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 00 00 FF FF 02 00 00 00 FF 0E 40 24 FF 08
70 FF FF 24 FF 26 FF 80 FF FF FF FF FF FF FF FF FF
80 FF FF 64 55 64 55 55 46 FF FF FF FF FF FF A8 FF
90 00 0E 0E 00 06 FF 7D FF 42 24 FF AA 55 55 FF 0A
A0 06 B5 00 60 01 53 3E 3A 36 32 FF D5 AE 87 60 0D
B0 0F FF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0E
C0 0F FF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 00 00 00 00 00 00 3F FF 01 00 FF 00 FF FF FF FF
Hardware monitor Intel Pentium E5200
Temperature 0 41°C (105°F) [0x3B] (Core #0)
Temperature 1 42°C (107°F) [0x3A] (Core #1)
Hardware monitor NVIDIA GeForce GTX 260
Temperature 0 50°C (122°F) (GPU Core)
PCI Device
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07C1
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 C1 07 06 00 A0 00 A2 00 00 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 6B 73
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 21 49 44 44 13 01 00 00 00 00 00 00 10 00 00 00
70 07 75 02 04 1D 15 00 00 81 01 85 01 00 00 00 00
80 00 00 00 00 00 00 00 00 70 00 00 80 00 00 00 00
90 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 CB 10 00 02 F0 FF 00 00 00 00 00 00 00 00 00 00
C0 11 11 00 00 00 30 33 13 03 00 00 00 00 50 07 00
D0 01 0A 00 00 00 00 00 00 FF FF 71 07 10 CF 30 06
F0 00 E4 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
Description RAM Memory Controller
Location bus 0 (0x00), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x07CB
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 CB 07 04 00 A0 00 A2 00 00 05 00 00 80 00
40 00 00 21 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07CD
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 CD 07 00 00 20 00 A1 00 00 05 00 00 80 00
40 00 01 00 00 3B 44 04 00 00 00 00 00 00 00 00 00
50 60 F8 F0 A0 0C 0C 04 7E 0C 00 00 00 04 10 7F 04
60 55 00 55 00 00 00 00 00 00 00 00 00 32 00 20 00
70 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 3F 43 00 00 00 01 00 00 00 00 00 00 00 35 0E 44
90 46 DA 44 31 53 A5 94 45 0D 3A 22 98 03 14 55 0D
A0 00 00 18 18 F0 11 03 00 20 00 27 00 00 00 00 00
B0 00 80 00 80 00 80 00 80 00 80 00 80 00 80 00 80
D0 31 26 61 24 31 26 61 24 31 26 61 24 31 26 61 24
E0 03 00 00 00 10 08 71 0F F1 01 00 00 00 00 00 00
F0 10 98 FF 08 08 10 03 E0 01 00 00 00 63 03 77 40
Location bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x07CE
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 CE 07 00 00 20 00 A1 00 00 05 00 00 80 00
60 0C 0C 03 03 00 00 00 00 0C 0C 03 03 00 00 00 00
70 01 10 A0 EE 01 10 A0 EE 00 00 B0 6E 00 00 B0 6E
80 08 08 00 13 23 40 F0 03 18 28 80 00 20 60 70 00
90 01 00 00 10 05 10 00 08 05 20 00 08 00 00 00 00
B0 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
C0 00 00 00 00 1B 06 82 81 10 00 00 00 01 01 00 00
D0 5B 0A 00 01 44 00 10 00 00 00 20 00 00 00 30 00
E0 FC DE 73 BB DF BD FA FA 03 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x07CF
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 CF 07 00 00 20 00 A1 00 00 05 00 00 80 00
40 D0 00 00 00 00 00 00 00 98 26 4C 84 4E 02 00 06
50 24 00 00 00 70 00 08 03 FF 7F 7F 7F 7F 7F 7F 7F
60 0F 00 00 00 0E 00 00 00 26 80 30 01 00 00 00 00
90 08 00 3F 70 08 00 07 0C 00 00 00 00 00 00 00 00
A0 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 FF FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 3 (0x03)
Common header
Vendor ID 0x10DE
Model ID 0x07D0
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D0 07 00 00 20 00 A1 00 00 05 00 00 80 00
50 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 D1 00 00 00 55 00 00 00 24 00 00 00 33 00 00 00
70 55 00 00 00 24 00 00 00 33 00 00 00 05 00 05 00
80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 11 21 12 11 00 00 00 00 99 99 99 99
A0 00 00 00 00 EE 0E E4 04 4B 4B 4B 4D 4B 4C 4B 4C
B0 00 00 00 00 00 00 00 00 FF 00 00 00 00 07 00 00
C0 00 00 00 00 00 07 00 00 00 00 00 00 00 07 00 00
D0 00 00 00 00 00 07 00 00 00 00 00 00 00 07 00 00
E0 00 00 00 00 00 07 00 00 00 00 00 00 00 07 00 00
F0 00 00 00 00 00 07 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 4 (0x04)
Common header
Vendor ID 0x10DE
Model ID 0x07D1
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D1 07 00 00 20 00 A1 00 00 05 00 00 80 00
40 50 3F 00 00 FF 00 00 00 98 3A 30 80 80 01 00 02
50 00 00 00 00 1F 1F 00 00 0F 0F 00 00 A0 F1 F1 00
60 0F 0F 00 00 0F 00 0F 00 0F 0F 00 00 90 F1 F1 00
70 0F 0F 00 00 0F 00 0F 00 03 00 00 00 0F 00 00 00
80 0F 00 00 00 00 00 00 00 0F 00 0F 00 0F 00 0F 00
90 0F 0F 00 00 0F 00 0F 00 0F 0F 00 00 0F 00 0F 00
A0 0F 0F 00 00 00 00 00 02 0F 0F 00 00 0F 00 0F 00
B0 03 08 00 00 44 45 54 11 44 44 44 44 44 44 44 00
C0 06 00 00 04 06 00 00 04 00 00 00 00 00 00 00 00
D0 00 00 00 00 0F 00 00 00 0F 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 44 00 00 00 44 00 00 00
F0 FF FF 00 02 00 00 00 00 0F 00 0F 00 0F 00 0F 00
Location bus 0 (0x00), device 1 (0x01), function 5 (0x05)
Common header
Vendor ID 0x10DE
Model ID 0x07D2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D2 07 00 00 20 00 A1 00 00 05 00 00 80 00
40 F9 01 A0 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 1 (0x01), function 6 (0x06)
Common header
Vendor ID 0x10DE
Model ID 0x07D3
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D3 07 00 00 20 00 A1 00 00 05 00 00 80 00
40 00 00 00 00 33 43 34 33 00 00 00 00 00 00 00 00
C0 00 00 00 00 07 07 00 00 99 99 99 99 00 00 00 00
D0 00 00 00 00 00 00 00 00 40 40 00 00 88 00 07 00
F0 00 00 00 00 88 88 88 88 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07D6
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D6 07 00 00 20 00 A1 00 00 05 00 00 80 00
90 44 44 44 44 44 44 44 44 44 44 44 00 00 00 00 00
B0 44 44 44 00 44 04 44 04 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 44 44 44 00 44 04 44 04
E0 40 40 40 40 40 40 40 40 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07D7
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00004F00
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D7 07 0F 00 A0 20 A2 00 01 06 00 00 80 00
10 01 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 62 14 6B 73 00 00 D0 FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 05 2F 00 3C 01
70 10 00 FF FF CD 00 00 00 00 00 04 19 00 00 C0 60
80 09 10 D0 80 02 80 00 00 00 00 00 01 FF 00 AA AA
90 00 08 00 00 FF FF 3F 3F 00 00 00 00 00 00 00 00
A0 02 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 0A 7F 0A 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00
E0 83 28 28 39 8B 35 00 00 0F 00 C0 40 00 00 00 00
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 3 (0x03), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x07D8
Revision ID 0xA1
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x00004900
Address 4 (port) 0x00004D00
Address 5 (port) 0x00004E00
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x0B
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 D8 07 01 00 B0 00 A1 00 05 0C 00 00 80 00
10 01 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 4D 00 00 01 4E 00 00 00 00 00 00 62 14 6B 73
30 00 00 00 00 44 00 00 00 00 00 00 00 0B 01 00 00
40 62 14 6B 73 01 00 02 C0 00 00 00 00 73 8B 11 00
60 01 40 00 00 01 44 00 00 01 48 00 00 00 10 D0 FE
70 00 20 D0 FE 00 00 F8 F9 00 00 00 00 01 00 00 00
80 00 40 D0 FE 00 00 00 00 00 00 00 00 00 00 00 00
C0 D4 30 80 01 01 00 00 00 21 82 02 02 0D 0D 19 19
D0 40 00 40 01 1E 00 14 0A 05 00 00 00 00 00 00 00
E0 80 18 01 10 00 48 02 40 80 22 00 00 00 44 44 00
F0 02 FF 1E BF 01 00 00 80 10 00 00 00 00 00 00 00
Location bus 0 (0x00), device 3 (0x03), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x07D9
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 D9 07 00 04 A0 00 A1 00 00 05 00 00 80 00
40 62 14 6B 73 00 00 00 00 10 02 80 10 10 00 10 10
50 10 10 10 10 00 00 00 00 00 00 00 00 10 42 00 00
80 00 00 00 00 00 00 00 00 00 00 01 00 40 88 10 02
90 21 84 10 0C A5 94 62 0A A5 A0 31 06 A3 94 52 0A
A0 E5 94 63 0C C4 94 52 08 C4 14 00 00 00 00 00 00
B0 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00
Description Processor Device
Location bus 0 (0x00), device 3 (0x03), function 3 (0x03)
Common header
Vendor ID 0x10DE
Model ID 0x07DA
Revision ID 0xA2
PI 0x00
SubClass 0x40
BaseClass 0x0B
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF9F80000
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x15
Int. Pin 0x02
PCI registers
00 DE 10 DA 07 06 00 A0 00 A2 00 40 0B 00 00 80 00
10 00 00 F8 F9 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 15 02 03 01
40 62 14 6B 73 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 F8 F9 00 00 00 00 00 00 00 00
80 05 00 80 01 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 08 00 02 A8
Location bus 0 (0x00), device 3 (0x03), function 4 (0x04)
Common header
Vendor ID 0x10DE
Model ID 0x07C8
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 DE 10 C8 07 00 00 20 00 A1 00 00 05 00 00 80 00
40 62 14 6B 73 03 03 00 08 00 00 02 00 03 03 80 00
50 00 00 00 00 00 00 00 00 00 00 00 00 77 21 BE 16
60 41 0E 10 CE FF FF 00 00 00 00 02 00 FF FF 00 00
70 00 00 02 00 21 07 10 80 03 2E 00 80 03 2E 00 00
80 00 00 00 80 01 00 00 00 07 00 00 00 00 00 00 00
B0 45 24 30 90 01 20 00 72 82 00 00 00 45 24 30 10
C0 FF FF FF FF FF BF FF FF 00 00 00 00 77 80 77 00
D0 00 21 09 00 01 00 00 00 00 00 00 00 00 00 00 00
E0 80 00 22 00 92 14 00 00 80 00 8B 60 64 02 13 00
F0 1B 1B 1B 1B 00 FF 21 00 77 77 88 88 00 00 0F 00
Description USB Controller (OHCI)
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07FE
Revision ID 0xA1
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF9F7F000
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x16
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 FE 07 06 00 B0 00 A1 10 03 0C 00 00 80 00
10 00 F0 F7 F9 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 03 01
40 62 14 6B 73 01 00 02 FE 00 00 00 00 00 00 00 00
50 0D 00 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 4 (0x04), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x056A
Revision ID 0xA1
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xF9F7EC00
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x17
Int. Pin 0x02
PCI capability
Caps class Debug Port
Caps offset 0x44
PCI capability
Caps offset 0x80
Caps version 1.1
PCI registers
00 DE 10 6A 05 06 00 B0 00 A1 20 03 0C 00 00 80 00
10 00 EC F7 F9 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 03 01
40 62 14 6B 73 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 03 3C 0A 01 00 00 00 00
70 00 00 08 00 00 10 20 80 89 3D B6 22 77 25 24 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
B0 00 11 22 33 44 00 00 00 FF 03 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
Description IDE Controller
Location bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x056C
Revision ID 0xA1
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x44
Caps version 1.1
PCI registers
00 DE 10 6C 05 05 00 B0 00 A1 8A 01 01 00 00 00 00
20 A1 FF 00 00 00 00 00 00 00 00 00 00 62 14 6B 73
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 62 14 6B 73 01 00 02 00 00 00 00 00 00 00 00 00
50 02 F0 00 00 00 00 00 00 A8 A8 A8 20 7F 00 FF 20
60 00 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 10 2F BF 00 00 06 30 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
Description Multimedia device
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07FC
Revision ID 0xA1
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF9F78000
Subvendor ID 0x1462
Subsystem ID 0x736A
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x50
PCI registers
00 DE 10 FC 07 06 00 B0 00 A1 00 03 04 00 00 00 00
10 00 80 F7 F9 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 6A 73
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 02 05
40 62 14 6A 73 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 00 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 02 A8
70 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 0F 40 00 A2 00 00 01 00 00 00 00 20 00 00 00 00
F0 00 00 00 00 00 00 00 47 00 29 00 00 00 00 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x056D
Revision ID 0xA1
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB8
SubVendor ID 0x1462
SubSystem ID 0x736B
PCI registers
00 DE 10 6D 05 07 04 B0 00 A1 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 40 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 00 00 02 02
40 00 00 73 07 00 00 00 00 2F 07 00 00 00 00 44 01
50 00 00 00 00 00 00 00 00 F0 1F FF 1F 00 00 00 00
80 00 02 00 00 96 02 00 00 00 00 00 00 08 00 00 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 00 00 00 62 14 6B 73
C0 62 14 6B 73 03 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x056E
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1462
SubSystem ID 0x736B
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps class PCI Express
Caps offset 0x80
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
PCI registers
00 DE 10 6E 05 07 04 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 E1 E1 00 20
20 00 FA A0 FE 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 1A 00
40 0D 48 00 00 62 14 6B 73 01 50 02 F8 00 00 00 00
50 05 80 93 00 0C 30 E0 FE 00 00 00 00 B2 49 00 00
60 08 80 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 01 3D 11 00
90 00 00 01 31 80 25 08 00 C0 01 48 01 00 00 00 00
B0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 12 (0x0C), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x056F
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1462
SubSystem ID 0x736B
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x80
Port 1
Version 1.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI registers
00 DE 10 6F 05 04 04 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 F1 01 00 00
20 F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00
50 05 80 93 00 0C 30 E0 FE 00 00 00 00 A2 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 01
90 00 00 11 10 00 05 10 00 C0 01 48 00 00 00 00 00
Location bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x056F
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x40
SubVendor ID 0x1462
SubSystem ID 0x736B
PCI capability
Caps offset 0x48
Caps version 1.1
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x80
Port 2
Version 1.0
Physical slot #0
Presence detect yes
PCI registers
00 DE 10 6F 05 06 04 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 F1 01 00 20
20 B0 FE B0 FE F1 FF 01 00 00 00 00 00 00 00 00 00
50 05 80 93 00 0C 30 E0 FE 00 00 00 00 60 49 00 00
80 10 00 41 01 21 80 00 00 10 28 00 00 11 3C 11 02
90 00 00 11 30 00 05 18 00 C0 01 48 01 00 00 00 00
Description Serial ATA Controller
Location bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07F4
Revision ID 0xA2
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000D480
Address 1 (port) 0x0000D400
Address 2 (port) 0x0000D080
Address 3 (port) 0x0000D000
Address 4 (port) 0x0000CC00
Address 5 (memory) 0xF9F7C000
Subvendor ID 0x1462
Subsystem ID 0x736B
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps class 0x12
Caps offset 0x8C
PCI capability
Caps offset 0xB0
PCI registers
00 DE 10 F4 07 07 00 B0 00 A2 01 06 01 00 00 00 00
10 81 D4 00 00 01 D4 00 00 81 D0 00 00 01 D0 00 00
20 01 CC 00 00 00 C0 F7 F9 00 00 00 00 62 14 6B 73
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 03 01
40 62 14 6B 73 01 8C 02 00 00 00 00 00 00 00 00 00
50 0F 68 38 60 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 01 00 50 80 00 00 01 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 02 00 00 08 20 00 20 69
80 0F 00 00 C0 BE 79 BF 7F 00 00 EC 35 12 B0 10 00
90 5F 02 00 00 00 00 00 00 03 9F 22 A3 06 01 00 00
A0 6E 5A 00 3F 00 00 00 00 00 00 00 00 33 34 00 02
B0 05 00 86 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 02 A8
D0 00 00 00 00 0A 00 00 00 00 00 40 00 0A 00 00 AB
E0 00 08 00 44 00 00 3F 00 02 00 00 40 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 01 1F 40 00 00 00 00
Description Ethernet Controller
Location bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x07DC
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF9F77000
Address 2 (memory) 0xF9F7E800
Address 3 (memory) 0xF9F7E400
Subvendor ID 0x1462
Subsystem ID 0x366C
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.1
PCI capability
Caps offset 0x50
PCI registers
00 DE 10 DC 07 06 04 B0 00 A2 00 00 02 00 00 00 00
10 00 70 F7 F9 01 00 00 00 00 E8 F7 F9 00 E4 F7 F9
20 00 00 00 00 00 00 00 00 00 00 00 00 62 14 6C 36
30 00 00 00 00 44 00 00 00 00 00 00 00 00 01 01 14
40 62 14 6C 36 01 50 02 FE 00 01 00 00 08 00 00 00
50 05 00 87 01 0C 30 E0 FE 00 00 00 00 B0 49 00 00
60 FE 00 00 00 00 00 00 00 FF 00 00 00 08 00 02 A8
F0 00 03 00 00 30 00 00 00 02 01 00 00 02 00 00 08
Description VGA Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x05E2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFD000000
Address 1 (memory) 0xD0000000
Address 3 (memory) 0xFA000000
Address 5 (port) 0x0000EC00
Subvendor ID 0x1682
Subsystem ID 0x2394
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.2
PCI capability
Caps offset 0x68
PCI capability
Caps offset 0x78
Device type PCI-E Endpoint Device
Port 0
Version 1.0
PCI registers
00 DE 10 E2 05 07 00 10 00 A1 00 00 03 10 00 00 00
10 00 00 00 FD 0C 00 00 D0 00 00 00 00 04 00 00 FA
20 00 00 00 00 01 EC 00 00 00 00 00 00 82 16 94 23
30 00 00 00 00 60 00 00 00 00 00 00 00 13 01 00 00
40 82 16 94 23 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 01 00 E0 84 2C 01
80 10 29 00 00 01 3D 00 00 08 00 01 01 00 00 00 00
Description OHCI FireWire Controller
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x197B
Model ID 0x2380
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEBFF800
Address 1 (memory) 0xFEBFF400
Address 4 (memory) 0xFEBFF000
Address 5 (memory) 0xFEBFEC00
Subvendor ID 0x1462
Subsystem ID 0x366D
Int. Line 0x12
Int. Pin 0x01
PCI capability
Caps offset 0x44
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 1.0
PCI capability
Caps offset 0x94
PCI registers
00 7B 19 80 23 06 00 10 00 00 10 00 0C 10 00 00 00
10 00 F8 BF FE 00 F4 BF FE 00 00 00 00 00 00 00 00
20 00 F0 BF FE 00 EC BF FE 00 00 00 00 62 14 6D 36
30 00 00 00 00 44 00 00 00 00 00 00 00 12 01 00 00
40 00 00 00 00 01 80 03 00 08 80 00 00 00 00 00 00
60 89 44 6D 95 48 D4 56 A1 12 00 40 80 80 00 00 00
70 01 00 00 18 00 00 00 00 00 00 00 00 8F FF 90 72
80 10 94 01 00 00 80 00 00 10 20 08 00 11 FC 03 01
90 00 00 11 10 05 00 00 00 FC FF FF FF 00 00 00 00
A0 00 00 00 00 01 80 03 00 08 00 00 00 00 00 00 00
B0 20 00 88 7F 0C 00 00 80 22 11 A2 00 00 00 00 00
C0 C3 8B 38 A0 03 45 02 02 00 00 00 08 70 00 00 30
D0 38 00 00 80 07 08 00 10 00 00 EB 00 FF FF A0 00
E0 0F 33 0A 00 59 19 FF FF 9B 2B 10 00 82 E6 0F 00
F0 00 00 00 00 FE 23 EF FF 00 00 00 00 00 00 76 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version A7366MLN.20T
date 12/02/2008
DMI System Information
manufacturer MEDIONPC
product MS-7366
version 2.2
serial To Be Filled By O.E.M.
UUID 8043E72E-30F8DD11-A5653EE7-E10B6106
DMI Baseboard
vendor MEDIONPC
model MS-7366
revision 2.2
serial To be filled by O.E.M.
DMI System Enclosure
manufacturer To Be Filled By O.E.M.
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer Intel
model Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
clock speed 2400.0 MHz
FSB speed 200.0 MHz
multiplier 12.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 1024 MBytes
DMI Memory Module
designation DIMM0
size 2048 MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A2 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation J4A1 (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation J2A1 (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J6A1 (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (external)
DMI Port Connector
designation J6B1 - AUX IN (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation J6B2 - CDIN (internal)
DMI Port Connector
designation J6J2 - PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation J6J1 - SEC IDE (internal)
DMI Port Connector
designation J4J1 - FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation J9H1 - FRONT PNL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation J1B1 - CHASSIS REAR FAN (internal)
DMI Port Connector
designation J2F1 - CPU FAN (internal)
DMI Port Connector
designation J8B4 - FRONT FAN (internal)
DMI Port Connector
designation J9G2 - FNT USB (internal)
DMI Port Connector
designation J6C3 - FP AUD (internal)
DMI Port Connector
designation J9G1 - CONFIG (internal)
DMI Port Connector
designation J8C1 - SCSI LED (internal)
DMI Port Connector
designation J9J2 - INTRUDER (internal)
DMI Port Connector
designation J9G4 - ITP (internal)
DMI Port Connector
designation J2H1 - MAIN POWER (internal)
DMI Extension Slot
designation AGP
type AGP 4x
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type SDRAM
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
DMI Memory Device
designation DIMM3
format DIMM
type unknown
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA NVAPI
API NVIDIA I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name NVIDIA GeForce GTX 260
Revision B1
Codename GT200
Technology 55 nm
Memory size 896 MB
Memory type GDDR3
Memory bus width 448 bits
PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1682)
Model ID 0x5E2 (0x2394)
Performance Level Default
Core clock 300.0 MHz
Shader clock 600.0 MHz
Memory clock 100.0 MHz
Performance Level 2D Desktop
Core clock 400.0 MHz
Shader clock 800.0 MHz
Memory clock 300.0 MHz
Performance Level Uknown
Core clock 720.0 MHz
Shader clock 1500.0 MHz
Memory clock 1250.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
DirectX Version 10.0
