Seagate 3TB mit Runtime_Bad-Sector 1
Retrogamer
Hi, ich habe leider keinen Thread gefunden in dem SMART Werte besprochen werden, daher habe ich mal hier einen für mich erstellt.
Code:
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST3000DM001-1CH166
Serial Number:    *********
LU WWN Device Id: 5 000c50 0639f81e0
Firmware Version: CC27
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Feb  9 23:02:02 2014 CET
==> WARNING: A firmware update for this drive may be available, [COLOR=#ff0000][B]GIBT KEINE NEUE![/B][/COLOR]
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  575) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 322) minutes.
Conveyance self-test routine
recommended polling time:        (   2) minutes.
SCT capabilities:              (0x3085) SCT Status supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   119   099   006    Pre-fail  Always       -       230987736
  3 Spin_Up_Time            0x0003   094   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       456
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   061   059   030    Pre-fail  Always       -       21482035696
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always       -       3039
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       21
[COLOR=#ff0000][B]183 Runtime_Bad_Block       0x0032   099   099   000    Old_age   Always       -       1[/B][/COLOR]
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   060   045    Old_age   Always       -       28 (Min/Max 22/29)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       17
193 Load_Cycle_Count        0x0032   097   097   000    Old_age   Always       -       6688
194 Temperature_Celsius     0x0022   028   040   000    Old_age   Always       -       28 (0 13 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       883h+08m+24.374s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       11738130535
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       10572195858
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%      2236         -
# 2  Extended offline    Completed without error       00%      2068         -
# 3  Extended offline    Completed without error       00%      1900         -
# 4  Extended offline    Completed without error       00%      1732         -
# 5  Extended offline    Completed without error       00%      1564         -
# 6  Extended offline    Completed without error       00%      1396         -
# 7  Extended offline    Completed without error       00%      1228         -
# 8  Extended offline    Completed without error       00%      1060         -
# 9  Extended offline    Completed without error       00%       892         -
#10  Extended offline    Completed without error       00%       724         -
#11  Extended offline    Completed without error       00%       555         -
#12  Extended offline    Completed without error       00%       387         -
#13  Extended offline    Completed without error       00%       219         -
#14  Extended offline    Completed without error       00%        53         -
#15  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Ich konnte leider nirgends finden was der Wert Runtime_Bad_Block bedeuten soll.
Um welche Platte handelt es sich? Bist Du sicher, dass "Runtime_Bad_Block" die richtige Bezeichnung für dieses Attribut ist? Bei der ST3000DM001 zeigt CDI da nur "Verkäuferspezifisch" an.
Steht ganz oben, ist folgende:
Die "komische" mit FW CC27 wo es keine neuere gibt.
Mein Altes NAS hat diesen Wert gar nicht angezeigt.
Meine ST3000DM001-1CH166 hat die FW CC44, aber die Namen der S.M.A.R.T. Attribute kommen nicht von der Platte sondern aus dem Programm, welches die Werte ausliest. CDI nennt für das Attribut B7 (0xB7=183) nun einmal keinen Namen. Runtime_Bad_Block muss also nicht stimmen, zumal es weder Current_Pending_Sector noch Reallocated_Sector oder Offline_Uncorrectable gibt, letztere wären normalerweise die beim Selbsttest gefundenen, defekten Sektoren. Da der Aktuelle Wert mit 99 noch weit über dem Grenzwert von 00 ist, würde ich mir da nun auch nicht so viele Sorgen machen, denn wäre der Wert wirklich schon kritisch, so müsste der Aktuelle Wert auf oder unter den Grenzwert fallen.
ID 183 / B7: SATA Downshift Error Count / Verlangsamung der SATA Schnittstelle.
Dazu 5 Suchfehler ID 07, die wohl die Ursache für die Verlangsamung waren.
Beobachte einige Wochen den "Value" Wert (ein Zustandswert) der Suchfehler, wenn der steigt ist das gut.
Die Anzahl siehst du in der Spalte Raw-Value, hier die ersten 16 Bit (4 Stellen) des 48 Bit (12 Stellen)
Rohwertes. In deinem Screenshot: dezimal 21482035696 = hex 5006dd9f0 = 0005│006d│d9f0.
Ok, vielen Dank. Ich werde das mal beobachten.
