RX360 Triple Radiator help
Sniper1010
Hi guys,
I was wondering if the XSPC RX360 could cool my core i7 920 (do) oc to 3.0 - 3.2ghz wich is considered a little/mild overclock and a EVGA GTX260 sc 55nm. With decent temps?
The reason for this question is i'm a bit worried, i know the XSPC RX360 has good reviews. Also the rad is mounted outside of the case, i presume for cool air..?
I prefer people who have similar set ups like mine, pump - 360 rad - i7 cpu - gpu - res - pump....Because all my money is spend, no more left.
Did i made the right choice for the rad please note i dont do high overclock just a 3 or 3.2ghz overclock.
Just to be sure here are my watercooling components: (and pc components)
Aquastream XT pump
Watercool HT 3.0 copper 1366
EK Water Blocks EK-FC260
XSPC RX360 Triple Radiator
Swiftech res revision 2
3 x Noiseblocker NB-Blacksilent XL1 fans for rad
masterkleer 3/8 - enzotech 3/8 compression fittings
(Lian li tyr pcx-500, EVGA x58 sli LE, Intel i7 920 (do), intel postville SSD 80gb, WD black 500gb, 6gb ddr3 mushkin 1600mhz, EVGA GTX260 sc 55nm, corsair HX650)
So what you guys think of it?
Thanks in advance
Just to be clear: You bought your components and now you are asking for advice? Normally it is the better way to ask before buying anything..... :rolleyes:
I know but i did post a nother question on the watercooling components but the question was if those watercooling components are of good quality cpu block, pump etc etc. I supose people would warn me if the rad i had in mind wasnt good. But i did not get any signs the rad was not good. So i ordered and got all my wc parts.
After that i did some browsing mainly for picture gallerys of wc set ups.
And then i saw people using a 240rad for cpu and a 240 rad for gpu. Or 480 rad for cpu and gpu. Etc etc. So i had my doubts i'm i right? Or is the XSPC RX360 Triple Radiator good enough for my setup.
Yeah i'm new to watercooling i posted all my questions and it was a good to go every wc part was (i assume) checked so if people would see i want to cool my i7 and gtx260 with one 360 rad people would act if it was not so good idea but people didnt act so i ques it was good. (But in the end i'm responsible) But now after some researching for pictures see above why.
I hope you understand why the dillema.....
I found the thread of mine here wich tells me the rad is good to cool both the i7 and gtx260 so this thread can be closed. Sorry for the mistake.
