[Sammelthread] Raspberry Pi
Für alle die bereits bestellt haben, ne interessante Info:
Manufacturing hiccup
Posted on March 8, 2012 by liz
77
It’s inevitable, isn’t it – you’re freewheeling along perfectly happily and then you get a puncture.
As you’ll have noticed, there’s been a bit of a delay in shipping the first batch of Raspberry Pis out to people. This is because of a hardware parts substitution that was made in the factory by accident: specifically, where we’d specified jacks with integrated magnetics in the BOM and schematics, the factory soldered in non-magnetic jacks. No magnets means no network connection. We’ve known about this for four days now, but we haven’t been able to tell you about it because it meant we had to do some further tests to make sure that nothing else was affected.
An illustration of where the factory went wrong - one of these jacks has integrated magnetics and the other doesn't. Which do you think is which? (I'll leave the answer in the comments later when you've had a chance to guess. Don't be misled into thinking there's information in the colour of the connectors.) It's actually very hard to tell unless you look at the insides of the part, either by doing what Gordon did and using pliers to take it apart when he realised something was wrong ("tin opener method") or...
…by taking an X-ray. The jacks in this image are not necessarily in the same order as the ones in the spot-the-difference image above - I'm not making it that easy for you!
This is a side view of the sort of jack we didn't want on the board. Pete Lomas, who designed the Raspberry Pi hardware, unmounted this jack from one of the boards we got back from the factory and X-rayed it for us.
This jack has integrated magnetics. You can see from the X-ray that it looks very different internally from the non-magnetic version above.
Happily, it’s a very minor problem to fix (desolder the dud jack/solder on a new one), and the factory is nearly done working on replacing them on the first set of boards. This means that the first tranche of boards should still go out to customers as we were expecting. There may now be a slight delay in later batches if there’s a problem sourcing enough magnetic jacks (we’ve got teams hunting them down already); all the stock of jacks we believed we had in place and ready to turn into the ethernet ports on your Raspberry Pis turn out not to be the correct part, so we’re having to start again and move through the negotiating/ordering/delivery cycle as fast as we can. Our partners at Element 14/Premier Farnell and RS Components are working hard to help us cater for this, and to expedite supply of the Raspberry Pi.
We are very, very sorry. We know you want your Raspberry Pi as soon as possible (and many of you are being inhumanly patient, having followed us since we launched this website eight months ago). We’ll keep you updated with how manufacture is moving; this is, in the scheme of things, a minor problem, but it’s still a bump in the road and we know that we rely on your goodwill to keep things moving forward.
Quelle: Raspberry PI
Interessantes Teil. Aber wie kann man da HDDs anklemmen?
Ich sehe keine SATA Ports.
SD-Karte als HDD oder über USB, sonst keine möglichkeit
Sata USB Adapter mit Stormversorgung.
Sowas wie z.b.
Delock Konverter USB 3.0 zu SATA 6 Gb/s
oder Platine vom Usb 2.0 Gehäuse und an das Y-Stormkabel nen Handylade Gerät.
Da Model B 2 Anschlüsse hat kann an Nummer zwei eineTastatur-Toutchpad Kombi dran wie Logitech K400.
Nutze die mit Fedora 17 (x86) am Server und am Asus Transformer Tablet (Tegra) und Android HC. (inkl. Touchpad)
Edit: Alternativ eine HDD mit Netzwerkanschluss http://preisvergleich.hardwareluxx.de/?cat=hdmultim&xf=973_LAN~973_Gb+LAN~973_WLAN#xf_top
Hmm SD Karten bzw USB 2.0 sind doch recht langsam.
Da wäre die LAN Variante schon interessanter. Kann man denn über LAN booten?
100Mbit/s LAN ist langsamer als USB2, gute SD Karten packen auch mehr als die 10MB/s (ungefähr) die man mit nem 100Mbit/s Netz erreichen kann.
Ob die Hardware überhaupt USB2 voll ausreizen kann ist fraglich.
Der Flaschenhals wird da die interne Anbindung an den SoC sein. Außerdem teilt sich USB und LAN die Anbindung, wird also beides gleich langsam sein. Deshalb auch kein 1Gbit LAN, weil das die ARM-CPU eh nicht verarbeiten kann.
Aber hey, das teil kostet 35€ :D
PS:
Soweit ich weiß kann der Raspberry nur von der SD Karte booten, zumindestens beim booten nach erstem Stromkontakt. Später kann dann auf eine HDD gewechselt werden.
Does the device have support for any form of netbooting or pxe?
No. However, it’s such a low power device that we expect it to be left on much of the time!
How does it boot?
You have to boot from SD but a USB HD can “take over” after the initial boot. You cannot boot without an SD card.
FAQs | Raspberry Pi
Ist schon bekannt ob 23,976hz reibungslos funzen? Das video in der XBMC Präsentation war ja glatt 24hz...
Gekauft wird das Teil definitiv, die Frage ist nur wie viele davon :D
Neben dem ursprünglichen XMBC gibt's auch den ersten OpenELEC Port OpenELEC for Raspberry Pi | Raspberry Pi .
Der PI wird definitiv als HTPC gekauft (auch wenn der "nur" zum surfen oder als "Disko"-Anlage am 50" Plasma reicht).
Edit: neue Konfig mit Worlddomination Grafik
2 x DeLOCK Konverter USB 2.0/3.0 auf SATA 22 Pin (61883)
1 x DeLOCK 61898 4-port, USB 3.0
1 x DeLOCK HDMI Adapter, Stecker/Buchse, gewinkelt rechts (65076)
2 x DeLOCK USB 3.0 Adapter, USB-A (Buchse) auf USB-A (Stecker) (65174)
1 x Inline USB 2.0 Kabel-Hub 4-Port - schwarz - ohne Steckernetzteil - mit Micro-B und Mini USB Stecker
(HDMI und Ethernet nach hinten, 2x USB 3.0 nach oben)
Bin gespannt ob der Hub das aushält, der rote Port soll 2A abkönnen und nur Storm liefern.
Nun brauch ich nur noch das Raspberry ...
Wie siehts nun aus? Hat schon jemand eins der Dinger abbekommen?
Bei mir ist heute (~2 Wochen nach der Registrierung) zumindest mal die Registrierungsbestätigung gekommen. :haha:
Scheinbar tut sich was, habe eben von Farnell UK eine E-Mail bekommen und konnte anschließend per mitgeliefertem Link nen Raspberry Pi bestellen! :-D
ich habe gestern auch eine E-mail von Farnell bekommen, aber wo soll man da eine Bestellung abgeben können? Der Link für mich zu einer Seite, wo ich mein Land und ob ich Business und Privat bin. Unter Privat gibt es nur eine Liste mit Händlern.
Evtl. hast du dich nicht vorher auf die Warteliste setzten lassen. (Preorder Notification)
Normalerweise sollte der Prozess so gehen.
Link klicken, Germany & Privat auswählen, runterscrollen Addresse + Master/Visa eingeben und fertig (T-Shirt nicht vergessen).
Wenn es jemand interessiert hier die Email.
Great news!
You can now order your Raspberry Pi by clicking on the link below. Thanks for staying patient with us.
The wait for Pi is (nearly) over
The Pi began its journey as a crowdsourced community project. Given the volumes involved and the demographic mix of likely users, the development board exemption on compliance testing is not applicable. As a result, even the first uncased developer units of Raspberry Pi will require a CE (compliance tested) mark prior to distribution in the EU.
We're supporting the Raspberry Pi Foundation in doing everything possible to bring the Pi to the world as quickly as possible, and minimise any further delay. (Find out more here.)
At this time orders will continue to be kept to one per person, to ensure the products get into the right hands.
Simply click on the link below to place your order.
habe das heute Morgen nochmal versucht, da ging es dann. Ka warum.
Na da bin ich ja mal gespannt auf das kleine Teil. Gehäuse ist quasi schon fertig, dass Teil wandert dann als 2. HTPC mit Openelec oder Raspbmc, ins Schlafzimmer oder zu den Eltern :D.
Ich habs mir auch am Samstag bestellen können, mal sehen wielange es jetzt noch dauert. Im Moment haben die ja irgendwelche CE-Überprüfungen am Laufen. Bis Ostern wird's ja wohl nicht mehr klappen, aber wenns bis zum ersten Mai da ist, dann könnte ich dann nen Gehäuse basteln... :D
Wie sieht es bei RS Components aus ?
Ich habe bis jetzt nur eine weitere "Verzögerungs"-Email bekommen, bestellen konnte ich noch nicht.
Jemand hier, der bei RS schon bestellen konnte ?
Achja ?
Hier im Forum ist bis jetzt nur von Farnell UK die Rede, und niemand hat was über
eine erfolgreiche Bestellung bei RS Components geschrieben.
Und mit "Jemand hier" meine ich hier im Forum und nicht irgendwo anders.
Wenn du lesen und denken könntest würdest du das verstehen.
habe vor 2 Tage bei Farnell 2 PIs bestellt.
Hatte mich bei der Vorbestellung registriert,und dann einige Wochen später eine email bekommen und direkt bestellt.
Nun kam heute eine Bestätigung leider nur für einen PI und als Liefertermin wurde KW33 genannt :-(
naja...warten wir ab
PS:habe über einen Firmenaccount bestellt
Wer hat noch eine Bestätigung bekommen?
Omfgilol... das ist ja Mitte August, ich habe noch gar nicht bestellt weil mir das zu stressig war. Müßte da nicht so langsam mal ein etwas größerer kommerzieller Hersteller drauf aufmerksam werden und die Teile in vernünftiger Stückzahl herstellen? Nur weil das Teil für die dritte Welt ist muß ja auch die Verfügbarkeit nicht wie in einer Bananenrepublik sein...
Sollte es wirklich so werden, dass ein größerer Hersteller mit aufspringt und ihn produziert, wird der Preis wohl steigen.
Irgendwer muss doch die Manager Boni zahlen!!!
Ich hoffe für mich nur, dass sie nicht in einem Monat eine neue Version mit mehr RAM oder besserer CPU/APU raus bringen, sondern das die Ausführung jetzt erst mal so bleibt.
Die ersten Einheiten sind verschickt worden, vielleicht hat ja auch ein Luxxer demnächst einen in der Hand und kann berichten.
Ist mittlerweile schon jemand in den Genuß eines Pi´s gekommen?
Laut offizieller Website sollen ja alle Besteller die vor dem 18.04. vorbestellt haben, ihren Pi bis spätestens Ende Juni erhalten haben....
Lassen wir uns überraschen! :cool:
Hab mich am 19. bei RS vormerken lassen.
Ich hoffe bis es da ist (was sicher noch dauert) ist eine lauffähige XBMC Version draussen...
