Raid Error Meldung
michi2k
Hi!
Bekomme im 3 Ware Browser Menü für den Raid Controller (3WARE 9650SE-2LP) diese Auswertung mit den folgenden Errors angezeigt.
May 09, 2008 04:07.12PM (0x04:0x0009): Drive timeout detected: port=0
May 09, 2008 04:06.07PM (0x04:0x0009): Drive timeout detected: port=0
May 06, 2008 10:00.47PM (0x04:0x0009): Drive timeout detected: port=0
May 06, 2008 07:01.17PM (0x04:0x0009): Drive timeout detected: port=0
May 05, 2008 10:01.01PM (0x04:0x0009): Drive timeout detected: port=0
May 05, 2008 07:01.59PM (0x04:0x0009): Drive timeout detected: port=0
May 02, 2008 10:00.47PM (0x04:0x0009): Drive timeout detected: port=0
May 02, 2008 07:01.21PM (0x04:0x0009): Drive timeout detected: port=0
Apr 30, 2008 10:00.46PM (0x04:0x0009): Drive timeout detected: port=0
Apr 30, 2008 07:01.19PM (0x04:0x0009): Drive timeout detected: port=0
Apr 29, 2008 10:00.46PM (0x04:0x0009): Drive timeout detected: port=0
Apr 29, 2008 07:01.25PM (0x04:0x0009): Drive timeout detected: port=0
Apr 28, 2008 07:01.17PM (0x04:0x0009): Drive timeout detected: port=0
Apr 23, 2008 07:01.27PM (0x04:0x0009): Drive timeout detected: port=0
Apr 22, 2008 10:00.47PM (0x04:0x0009): Drive timeout detected: port=0
Apr 22, 2008 07:01.18PM (0x04:0x0009): Drive timeout detected: port=0
Apr 21, 2008 10:00.51PM (0x04:0x0009): Drive timeout detected: port=0
Apr 21, 2008 07:01.24PM (0x04:0x0009): Drive timeout detected: port=0
Apr 16, 2008 10:00.50PM (0x04:0x0009): Drive timeout detected: port=0
Apr 14, 2008 10:00.47PM (0x04:0x0009): Drive timeout detected: port=0
Apr 14, 2008 07:01.19PM (0x04:0x0009): Drive timeout detected: port=0
Apr 11, 2008 07:01.26PM (0x04:0x0009): Drive timeout detected: port=0
Apr 09, 2008 10:00.48PM (0x04:0x0009): Drive timeout detected: port=0
Apr 09, 2008 07:01.29PM (0x04:0x0009): Drive timeout detected: port=0
Apr 07, 2008 10:01.02PM (0x04:0x0009): Drive timeout detected: port=0
Apr 07, 2008 07:01.23PM (0x04:0x0009): Drive timeout detected: port=0
Apr 03, 2008 07:01.25PM (0x04:0x0009): Drive timeout detected: port=0
Apr 02, 2008 10:00.50PM (0x04:0x0009): Drive timeout detected: port=0
Apr 02, 2008 07:01.18PM (0x04:0x0009): Drive timeout detected: port=0
Apr 01, 2008 10:00.48PM (0x04:0x0009): Drive timeout detected: port=0
Mar 26, 2008 07:01.20PM (0x04:0x0009): Drive timeout detected: port=0
Mar 14, 2008 11:22.46AM (0x04:0x0005): Rebuild completed: unit=0
Mar 14, 2008 12:01.42AM (0x04:0x000B): Rebuild started: unit=0
Mar 14, 2008 12:01.27AM (0x04:0x003B): Rebuild paused: unit=0
Mar 13, 2008 07:03.48PM (0x04:0x000B): Rebuild started: unit=0
Mar 13, 2008 07:01.17PM (0x04:0x0002): Degraded unit: unit=0, port=0
Mar 13, 2008 07:01.17PM (0x04:0x0009): Drive timeout detected: port=0
Mar 12, 2008 10:00.51PM (0x04:0x0009): Drive timeout detected: port=0
Mar 12, 2008 07:01.28PM (0x04:0x0009): Drive timeout detected: port=0
Mar 06, 2008 10:00.48PM (0x04:0x0009): Drive timeout detected: port=0
Mar 06, 2008 07:01.25PM (0x04:0x0009): Drive timeout detected: port=0
Mar 05, 2008 10:00.49PM (0x04:0x0009): Drive timeout detected: port=0
Feb 25, 2008 07:01.21PM (0x04:0x0009): Drive timeout detected: port=0
Feb 21, 2008 10:00.47PM (0x04:0x0009): Drive timeout detected: port=0
Feb 21, 2008 07:01.19PM (0x04:0x0009): Drive timeout detected: port=0
Klicke ich bspw. den letzten Eintrag vom 09. Mai 2008 an, brint er mir folgende Erklärung:
Event Type
Error
Cause
A drive has failed to respond to a command from a 3ware RAID controller within the allowed time limit (20 secs.). After sending this error message, the controller will attempt to recover the drive by sending a reset to that drive and retrying the failed command.
Possible causes of drive time-outs (also known as ATA-Port time-outs) include a bad or intermittent disk drive, power cable or interface cable.
Action
If you have checked hardware connections and no cause other than the drive can be found, replace the drive.
You may also want to use the drive manufacturer’s diagnostic and repair utilities on the drive.
In der Startmaske des Raid Controller Menüs steht der Raid Status "OK" und unter Drive Information wird eine HD als "DEVICE ERROR" gekennzeichnet.
Steht der status "OK" momentan nur dafür dass das System quasi mit der 2ten Platte des Raid 1 am leben gehalten wird ich aber die defekte HD austasuchen soll?
Also ich denke die eine HD ist hinüber, nur das "OK" irretiert mich irgendwie...
die eine HDD wird hinüber sein... stecke die doch mal an deinen onboard Controller und check die Platte mit dem Herstellertool.
Habe sie mal an einen anderen PC gehängt und da läuft sie im Windows Betrieb bisher Einwand frei. BS ist Server2003. Habe mal die Festplatte mit Boardmitteln überprüfen lassen und es wurde auch was gefixt aber ob es das war..hmm
mit Boardmitteln? Du meinst jetzt aber nicht chkdsk oder sowas oder?
Benutze mal das Herstellertool und mache da einen erweiterten Test...
Ja hatte mal just 4 fun das in Windows integrierte Feature laufen lassen. Hatte sogar Fehler gefunden aber weiss schon der große Wurf ist das nicht.
Habe jetzt endlich mal Zeit gehabt und Hutil drüber laufen lassen, siehe da --> im Arsch ;)
Komisch, die Samsung Platten laufe bei mir nie reibungslos durch den Gewehreistungszeitraum.
