Ich habe ein problem mit meiner Sparkle 260GTX. Es erscheint nach zwei minuten spielen (Crysis oder DiRt) immer einen blue screen.
Bei Furmark stürtz die Karte immer bei 70° ab -.-!
Mein System:
Intel Q6600
Asus P5W DH Deluxe
6GB Ram von G.Skill
be quiet Straight Power 450Watt
Vista 64Bit
260Gtx @ WHQL185.85
Google sagt mir auch nichts brauchbares
Patrick
Atempt to reset the display driver and recover from timeout failed.
It this is the first time you've seen this stop error screen, restart
your computer. If this screen appers again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer for
any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable Bios memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart your
computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical information:
*** STOP:0x00000116 (0xFFFFFA800704B010, 0xFFFFFA600201A0, 0x0000000000000000, 0x
0000000000000002)
*** nvlddmkm.sys - Address FFFFFA600201A1A0 base at
FFFFFA6002001000, DateStamp 4990b203
Collection data for crash dump...
Initializing disk for crash dump...
Beginning dump of physical memory.
Dumping physical memory to disk: 100
Physical memory dump complete.
Contact you system admin or technical support group for further assistance.
Mein System:
Intel Q6600
Asus P5W DH Deluxe
6GB Ram von G.Skill
Vista 64Bit
260Gtx @ WHQL185.85
Patrick
ist das ein scheiß!
