Prob. mit Nero7
thomas12
Banned
habe folgendes Problem.Beim DVD-kopieren unter Shrink,kommt es zu folgender Fehlermeldung:
1C83-721K-10E5-477X-405C-373E-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14.03.2007 11:43:16
NT-SPTI used
Nero API version: 7.8.5.0
Using interface version: 6.3.1.4
Installed in: C:\Programme\Nero\Nero 7\Core\
Application: ahead\Nero - Burning Rom
Internal Version: 7, 8, 5, 0
Recorder: <Optiarc DVD RW AD-7170A> Version: 1.85 - HA 1 TA 1 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
CdRomPeripheral : TSSTcorp DVD-ROM SH-D162C atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Optiarc DVD RW AD-7170A atapi Port 1 ID 1 DMA: On
DiskPeripheral : MAXTOR STM3160211AS atapi Port 2 ID 0 DMA: On
DiskPeripheral : ST3160812AS atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
TSSTcorp DVD-ROM SH-D162C F: CDRom0
Optiarc DVD RW AD-7170A G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2096236kB)
Free physical memory: 1665MB (1705020kB)
Memory in use : 18 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.5.2007
NeroAPI
17:08:31 #1 Phase 112 File APIProgress.cpp, Line 285
DVD-Video files reallocation started
17:08:31 #2 DVDREALLOC -21 File DVDVideoCompilation.cpp, Line 1317
Required file 'VTS_17_0.VOB' is not present
17:08:31 #3 Phase 115 File APIProgress.cpp, Line 285
DVD-Video files reallocation failed
17:08:31 #4 Text 0 File NeroAPIBurnFS.cpp, Line 218
Failed to realloc DVD video files
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.26a, size=20576 bytes, created 04.06.2005 20:02:08 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Securit
Bis gestern ging alles noch wunderbar.Hatte nur einen neue Win-Treiber installiert,seitdem funk. es nicht mehr.
Bitte um Eure hilfe.
Danke!!
MfG!
