karotte*
hallo habe Vista 64 , ne 4850er und hatte den 8.7er als Treiber.
Beim Starten von Enemy territory hatte ich ne Consolen meldung :
siehe Text :
8000 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing profiles/Paranoid/etconfig.cfg
execing autoexec.cfg
execing Grafik.cfg
Unknown command "qqq"
Unknown command "sea"
execing Tools.cfg
execing nah.cfg
execing Klassen.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found logfile opened on Thu Aug 21 08:49:49 2008
Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode -1: 1680 1050 FS
...using colorsbits of 32
...calling CDS: failed, DISP_CHANGE_FAILED
...trying next higher resolution: failed, DISP_CHANGE_FAILED
...restoring display settings
...registered window class
...created window@3,22 (1686x1076)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 0 )
...65 PFDs found
...hardware acceleration found
...PIXELFORMAT 2 selected
...creating GL context: succeeded
...making context current: succeeded
...WARNING: fullscreen unavailable in this mode
...using colorsbits of 16
...window already present, CreateWindowEx skipped
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
ET startete also nicht, die Bildschirmauflösung ließ sich von 800/600 nicht mehr ändern.
Bildschirmfrequenz hatte sich auf 56 Hz reduziert.
Komisch , irgendjemand ne Ahnung was das zu bedeuten hat ?
Das Problem tritt sporadisch auf.
siehe Text :
execing default.cfg
execing Grafik.cfg
execing Tools.cfg
execing nah.cfg
execing Klassen.cfg
Intel Pentium III
Bypassing CD checks
----- R_Init -----
...initializing QGL
...65 PFDs found
...initializing QGL
RE_Shutdown( 1 )
dann is alles wieder okay
