Win 2k/XP
New in version (1.5672a):
* Fixed bug with Microsoft Flight Simulator 2004.
* Fixed some laptop problems.
New in version (1.5672):
* Based on the Official 56.72 drivers.
* Added FULL support for ALL laptop GO cards, still, if this build doesn't
install/work with your laptop model, send me the INF file of the drivers
that DO work with it so I can add support in a future release.
Many thanks to Pieter from laptopvideo2go.com for his help!
* Complete remake of the resolutions code and addition of new resolutions
with support for wide screen displays and laptops.
* Fixed installation issues with on-board graphic cards based on the
Vanta chipset.
* Included an exclusive Driver Cleaner Omega version.
* Removed Artifact Tester from the Package.
* Added easy identification for the Quality and Performance options after
the drivers are installed. Now is Quality [Q] and Performance [P].
* Changed the name of some files and folders for better identification.
http://www.accesswave.ca/~sruxton/drivers/nvidia_wxp_omega_15672a_7z.exe
spz
Vanta chipset.
spz
