Need: 2048MB OCZ EB DDR PC-4000 PE bios einstellungen ?
RockOn
Semiprofi
Hy,
Ich suche stabile bios einstellungen für OCZ EB DDR PC-4000 2x1024MB Platinum Edition ( OCZ5002048EBPE-K ), für dfi nf4 sli-dr ( siehe sig ).
Und ein gutes bzw bestes bios.
ERLEDIGT 1) ein tip für ein OCZ optimiertes bios!
Download: 704-2BTA
Mirrow: 704-2BTA
Aktueller Thread: LINK
ERLEDIGT 2). Bios einstellungen
Genie BIOS Settings:
FSB Bus Frequency............................. - 265
DRAM Configuration Settings:
DRAM Frequency Set............................ - 200=RAM/FSB:01/01
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - 3.0
RAS# to CAS# delay (Trcd)..................... - 03 Bus Clocks
Min RAS# active time (Tras)................... - 07 Bus Clocks
Row precharge time (Trp)...................... - 02 Bus Clocks
Row Cycle time (Trc).......................... - 07 Bus Clocks
Row refresh cyc time (Trfc)................... - 14 Bus Clocks
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 02 Bus Clocks
Read to Write delay (Trwt).................... - 03 Bus Clocks
Refresh Period (Tref)......................... - 4708 Cycles
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - Level 7
DRAM Data Drive Strength...................... - Level 2
Max Async Latency............................. - Auto
DRAM Response Time............................ - Normal
Read Preamble Time............................ - Auto
IdleCycle Limit............................... - 256 Cycles
Dynamic Counter............................... - Disable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(4 Bursts)
Quelle: DFI Forum, speziell von dfi getestet!
PS: mit google und sufu nicht das passende gefunden.
was heißt beim OC machen sie sehr früh schlapp?
Meine laufen mit dem Default einstellungen bis ca 270. Hab aber noch net weiter getestet
expert hat ein ganz anderes bios als alle anderen nf4 /d/sli/sli-dr...könnte dadrann liegen.
ca. bei 230mhz und mem defaults
3-3-2-8 sonst steht alles weitere default
so hier mal nen pic von meinen 8x 1gb ocz EB pc 4000 PL :-D
will mal schauen was oc mässig in den teilen steckt *jajaja*
und den besten werde ich behalten...burn....
Ne, die haben 3-3-2-5 oder 2.5-3-2-x wenn man ein super RAM hat.
Brauchst du noch Settings oder hast du welche?
wow danke ich habe dort selbst schon mal geschaut aber nix gefunden. (sie scheinen sich auf ein spezielles bios und cpu zu beziehen aber egal)
Vielen Dank!!!
hMz also meine EB's laufen selbst bei einem stark getweaketen Bios perfekt, ich weiß echt net warum manche probleme haben, die richtigen einstellungen zu finden
das expert hat ein ganz anderes bios als die normalen fn4 ...sli...sli-dr....
daher kannst du es nicht vergelichen.
aber wenn es bei dir so gut läuft freu ich mich für dich.
Nun kannst du gleich ein paar ram settings hier lassen für das expert, damit andere user nicht lange suchen müssen ?
