Hallo!
Von Mtron gibts nun auch ne mini PCIe SSD für Netbooks:
Mtron hat diese speziell für das Asus 901 X entwickelt.
Sie entspricht dem PICIe D-Typ
Feature
> Performance
• Maximum sustained read: 100MB/s
• Maximum sustained write: 107MB/s
• Maximum IOPS: 15,000 (sequential write by 512B unit)
> Form factor: 30.0mm x 50.95mm x 6.0mm
> Memory type: SLC NAND flash memory
> Interface standard: PCI Express 1x
> Transfer mode:Supports 1-Lane 2.5Gbps PCI Express bus
> Storage capacity: 16GB
> Input voltage: 3.3VCC (±5%)
> Flash management algorithm: static and dynamic wear-leveling, bad block management algorithm
> ECC (Error Correction Code): BCH 7 bits ECC
> Write endurance: >70 years @ 50GB write/day at 16GB SSD
> Read endurance: unlimited
> Data retention: 10 years
Feature
> Performance
