ich verwende einen HP Compaq nx 7400.
Das Problem ist, dass 3d nicht funktioniert.
Es ist DirectX 9.0c und der Grafik Treiber von HP installiert.
System Information
Time of this report: 7/13/2011, 10:06:51
Machine name: NB5002
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.101209-1647)
Language: German (Regional Setting: German)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq nx7400 (RU430ET#ABD)
BIOS: EPP runtime BIOS - Version 1.1
Processor: Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz (2 CPUs)
Memory: 2040MB RAM
Page File: 457MB used, 3473MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 945 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 950
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_27A2&SUBSYS_30A2103C&REV_03
Display Memory: n/a
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4926 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 2/15/2008 14:12:06, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: igxpmp32.sys
Mini VDD Date: 2/15/2008 14:12:06, 5854752 bytes
darksteel
System Information
Memory: 2040MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
DAC type: Internal
Display Memory: n/a
WHQL Logo'd: Yes
darksteel
