The DPG file type is primarily associated with 'nDs-mPeG'. nDs-mPeG, usually abbreviated DPG, is a special format of MPEG-1 video specifically for playback using the homebrew Moonshell program for the Nintendo DS. The video is encoded on a computer and then transferred, along with Moonshell, to the DS for playback. The file is a standard MPEG-1 video stream (preceded by DPG-specific headers) combined originally with WAV audio, now uses MPEG-2 audio. It is a popular format supported by NDS, iPod, iPod touch, iPod nano, iPod classic, iPhone, Apple TV, PSP, PS3,Zune,Xbox, Xbox 360, Google Phone, Sony Walkman, Creative Zen, BlackBerry, Motorala, LG, Sony Ericsson, Mobile Phone, etc.
If you want to enjoy your favorite DVD movies, songs, games on these portable devices, you can convert your DVD to the DPG format. It is easy. Just use Tipard DVD to GPG Converter .It will give you a hand to rip DVD to NDS DPG/DPG2/DPG3/DPG4 video and MP3/MP2 audio. Further more, this DVD to DPG Converter can also convert DVD to any other video/audio formats: MP4, H.264, AVI, DivX, XviD, WMV, ASF, FLV, SWF, MP3, AAC, M4A, etc.
Let me show you the detailed guide:
Step 0: Download Tipard DVD to DPG Converter.
Step 1: Load DVD.
Click "Load DVD" to add your DVD contents.
Step 2: Set output video format.
Click "Profile" button from the drop-down list to select the exact output video format. You can click the "Settings" button to set parameters of your output video such as such as Resolution, Video Bitrate, Frame Rate, Audio Channels, Sample Rate, etc. to get the best video quality as you want.
Step 3: Select the output path by clicking “Browse” button from the line of destination.
Step 4: Click the "Start" button to start the conversion.
This good DVD to DPG Converter also has powerful editing functions.
1. Customize output video effect
Click “Effect” to adjust the video Brightness, Contrast, Saturation and Volume for you to get the perfect playing effect.
2. Capture any DVD clips
Click “Trim” to get any segment from DVD disk by setting the exact time or casually dragging the slider bar.
3. Crop video
Click “crop” to crop the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices.
4. Watermark your video
You can watermark your video by adding Text or Picture.
5.Join DVD contents
You can just select several chapters and contents; click merge into one file, after conversion, these contents will be saved into a single file.
6. One time, different conversion
You can convert DVD into different formats at one time.
If you are still troubling with converting DVD to DPG, why not try this software? There is also a nice DPG Converter . Come to see it!
Step 1: Load DVD.
3. Crop video
5.Join DVD contents
