ne geht net.
"These two connectors (JPWR1 & JPWR2) connect to the ATX power supply and have to work together to ensure stable operation of the mainboard.
• Power supply of 450 watts (and above) is highly recommeded for system stability.
• For ATX 12V power connection, it should be greater than 18A.
• For this model, you must use the power supply that with a -5V pin supply."
MSI Schreibt vor das es der 24Pol sein muss
