ForceWare 82.12 Beta Win2000/XP
AMD_USER
Account gelöscht.
Pollen / HB
moin
wieder ein neuer treiber
Windows 2000/XP - x32 - Official Beta
ForceWare Release 80
Version: 82.12
Release Date: December 22, 2005
BETA Driver
Pretty much all GeForce graphics cards starting at geForce 3 and higher are supported in this driver.
Added support for the GeForce 6800 GS AGP.
Added support for the Dell 3007WFP panel
Release Highlights:
* Adds support for GeForce 6800 GS AGP.
* Adds support for Dell 3007WFP panel.
* Mixed vendor support for NVIDIA SLI.
* TV-Out/HD-out support for NVIDIA SLI.
* Added support for VSync on Direct3D games when running NVIDIA SLI.
* Performance enhancements for dual-core CPUs.
* PureVideo high definition MPEG-2 de-interlacing support.
* Usability enhancements when connecting to an HDTV.
* Microsoft® DirectX® 9.0c and OpenGL® 2.0 support
* For a full list of fixed and known issues please view the Release Notes.
We have discussion topics open on these drivers right here.
GeForce4 MX 460
GeForce4 MX 440
GeForce4 MX 420
GeForce4 MX 440-SE
GeForce4 MX 440 with AGP8X
GeForce4 MX 440SE with AGP8X
GeForce4 MX 4000
GeForce4 MX Integrated GPU
GeForce FX 5100
GeForce FX 5200
GeForce FX 5200LE
GeForce FX 5200 Ultra
GeForce FX 5500
GeForce FX 5600
GeForce FX 5600XT
GeForce FX 5600 Ultra
GeForce FX 5700VE
GeForce FX 5700LE
GeForce FX 5700
GeForce FX 5700 Ultra
GeForce FX 5800
GeForce FX 5800 Ultra
GeForce FX 5900
GeForce FX 5900 Ultra
GeForce FX 5900ZT
GeForce FX 5900XT
GeForce FX 5950 Ultra
GeForce PCX 5750
GeForce PCX 5900
GeForce PCX 5300
GeForce 6100
GeForce 6150 LE
GeForce 6150
GeForce 6200
GeForce 6200 with TurboCache
GeForce 6200SE with TurboCache
GeForce 6500
GeForce 6600
GeForce 6600 LE
GeForce 6600 VE
GeForce 6600 GT
GeForce 6610 XL
GeForce 6800
GeForce 6800 LE
GeForce 6800 XEGeForce 6800 XT
GeForce 6800 GS
GeForce 6800 GT
GeForce 6800 Ultra
GeForce 7800 GT
GeForce 7800 GTX
GeForce 7800 GTX 512
Quadro4 380 XGL
Quadro4 550 XGL
Quadro4 580 XGL
Quadro FX 500
Quadro FX 540
Quadro FX 600
Quadro FX 700
Quadro FX 1000
Quadro FX 1100
Quadro FX 1300
Quadro FX 1400
Quadro FX 2000
Quadro FX 3000
Quadro FX 3400
Quadro FX 3450
Quadro FX 4000
Quadro FX 4000 SDI
Quadro FX 4400
Quadro FX 4500
Quadro NVS
Quadro NVS with AGP8X
Quadro NVS 280 PCI
Quadro NVS 285
http://downloads.guru3d.com/downloadget.php?id=1288&file=1&evp=1733268fc1552641b7c690f23f352846
gruss Amd_user
kann dann mal jemand bench ergebnisse und spiele tests posten. habe im mom den neuen whql 81.98 drauf von www.nvidia.com bei benches is er etwas schlechter als der 81.95, games konnte ich noch nicht testen.
hi
mache ich nacher muss win neu draufbraten
habe aber zu zeit nur eine 6200tc drin zu zeit sind die punkte bei
25015 bei AquaMark3 mit treiber version 81.95
so hat sich ein bischen was gändert gändert
25017 bei AquaMark3
gruss
Kann mal einer Paint Shop Pro 10 in Verbindung mit einer DC CPU testen, bei mir geht das nicht, also das Prog startet nicht!
Bei dem 81.98 steht dabei dass das Problem gelöst sein, ich weis zwar nicht was das mit dem Treiber zu tun hat, aber naja!
Wär nett wenn mal einer testen könnte!
nicht gesehen ...
Gesamtscore ist bei mir von 69922 auf 69455 gesunken.
Was anderes habe ich noch nicht ausprobiert.
hmm und wieso hab ich den dann drauf gemacht? AAAAAAAH^^ ist von nvidia´s seite her noch ein treiber geplant? sonst mach ich den 81.95 wieder drauf, der läuft bei mir ziemlich schnell und auch sehr stabil...
vielleicht bringt es nur was bei neueren Karten... mit meiner 68GT hincke ich ja schon wieder weit hinterher
vielleicht versuche ich noch den 81.98 und den 81.95
ansonsten steige ich wieder auf den 81.84 um ... der lief sehr gut bei mir.
hier behauptet ja einer schon einen noch neueren (83.10) zu haben
http://www.hardwareluxx.de/story.php?id=3311
Hab auch wieder den alten 81.87 beta drauf gemacht für mein Sys der beste von allen neuen die es im Moment gibt. :cool:
Bei mir bracht er in etwa 30 GFX Punkte mehr, in Gesamt kann ichs nicht sagen, da die CPU ca. 100Punkte langsamer ist und das stärkere auswirkungen auf den gesamtscore hat. Hab nur ca. 40P plus
