Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]foobar2000 v2.26 preview 2026-01-02 wurde veröffentlicht
Mac only evening update, fixed lockup regression fix.
2025-10-24:
Fixed very old race condition bugs in decoder merit management, potentially causing decoder to be listed twice.
Fixed regression turning playback file open errors to "critical errors", incorrectly halting playback instead of playing next file.
Added support for decoding TrueHD & MLP streams in Matroska.
Removed both extremely inefficient and inaccurate probing of Matroska track bitrate. Only bitrates reported by decoders (that is all AC3 bitrates) are shown, as well as live bitrates while playing.
Fixed missing info reload when changing stream via toolbar dropdown.
Added support for M4A "long description" tag.
Enabled experimental memory-mapped SQLite reading for configuration and metadb.
Made manual metadb garbagecollect always perform sqlite vacuum.
Mac: Fixed File Operations destination being editable in "rename" mode.
Windows: Attempted workaround for repaint glitches in multiline editboxes introduced in latest Windows 11 update. Note that this is a bug in Windows not foobar2000.
Windows: Workaround for stuck visualizations if playback ends while foobar2000 is invisible.
2025-10-16:
Mac: Changed remove-item-from-playlist selection behavior, now selects next item so keyboard navigation doesn't move selection to top of the playlist.
Fixed LD & ELD AAC not being reliably sent to alternate packet decoders.
Fixed Decoding Speed Test not remembering last used DSP chain.
2025-10-12:
Windows: Fixed missing winsock init for SMB operations, causing all SMB access to fail if no other network features have been used first.
Fixed bad interaction between WebDAV filesystem and media library.
2025-10-10:
Improved recovery of malformed UTF-8 text in various tag formats.
Made malformed UTF-8 tags text reported in integrity verifier.
MP4 tagging improvements:
- Tagtype info (Apple, Nero)
- No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
- Added support for more rarely used Apple tag elements.
- No longer alters binary structure of Apple tag elements which are not affected by edits.
Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
- You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
New info field: container (MP4, Matroska, Ogg, etc)
New title formatting field: %_cpu_arch%
Mac: made playlist view receive copy/paste from Finder
Mac: New icon from Apple Icon Composer
Mac: Built with Xcode 26, enabled macOS Tahoe looks.
Mac: Install components by drag&drop from Finder to components list.
Mac: Playlist Manager columns can be toggled.
Added drag&drop from Internet Radio pages to playlist.
Attempt to play a password-protected resource such as radio stream now shows a password prompt.
Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
Equalizer now accepts presets via drag&drop from Explorer/Finder.
Workaround for foo_tags issue [being backported to 2.25.x]
Workaround for WAV headers claiming zero length [being backported to 2.25.x]
Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Cleaned up resampler settings, removed pointless "exclude rates" checkboxes, added explicit hints about formatting.
Fixed TrueHD & MLP being shown as lossy.
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Suppressed specific slow Matroska integrity checks when opening file for both playback and integrity verification.
2025-10-29:
Replaced built-in SSRC resampler with ARDFTSRC.
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Made resampler priority setting accept short names of resamplers, e.g. "retroarch;ardftsrc".
Windows: Fixed certain DSP setting pages being impossible to navigate if DSP manager was created as a modal popup.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Updated title formatting help with some recent and some not-really-recent additions.
Fixed one more obscure resampler bug.
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Removed decades old hack for MP3 radio without content-type - should work as before and get recognized by content checks.
Title formatting help updated again.
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Windows: Added console output to troubleshoot specific portable mode bug.
2025-11-04:
Resampler settings update.
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Wann kann Foobar endlich Bitstreaming, so dass Atmos-files (z.B. flac-codiert) an den AVR unverändert weitergegeben werden können? Momentan empfängt dieser nur den Core (max. 7.1 channels, denke ich), nix Objektbasiertes, was ja Doly Atmos ausmacht. Sehr schade für so einen tollen Player!
Ehrlich gesagt bin ich da nicht so tief in dem Thema, aber sollte nicht WASAPI im "exclusive Modus" oder per ASIO Output ausreichend Bitstreaming bieten?
Windows: Fixed crashing when a picture cannot be decoded for whatever reason.
Windows: Added Gdiplus fallback when Windows Imaging can't decode some image, so systems without Windows Imaging codecs can again show album art.
Mac: Implemented album art downscale-on-load, lowering memory usage of album art viewers etc (full size image is not loaded in contexts that will never show it).
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Nein, das geht leider momentan nicht. Das ist auch bekannt - ich las in diversen Foren, dass der Entwickler das nicht vorgesehen hat.
Es werden nur die einzelnen Kanäle übertragen (egal ob WASAPI oder ASIO4ALL) und der AVR zeigt ein Mehrkanal-Eingangssignal an, jedoch kein Atmos = kein wirklich "immersives" Signal. Das selbe File mit mit MPC-BE oder VLC Media Player abgespielt und es wird mit allen Metadaten per HDMI übertagen und korrekt abgespielt.
Wäre natürlich schön, wenn ich keine extra-Software bräuchte, um Titel in Atmos abzuspielen, zumal jetzt immer mehr Alben, neu oder nachträglich, Atmos-gemastert digital veröffentlicht werden.
Ok, verstehe. Tut mir leid, dass ich da jetzt auch nicht weiterhelfen kann. Evtl. wärest Du im offiziellen Forum besser aufgehoben. Es gibt dort auch den Thread [Suggestions / Wishlists] for future updates. Dort könntest Du sonst dem Feature nochmal etwas Nachdruck verleihen.
2025-11-15:
Various fixes in new album art rendering routines.
2025-11-14:
Experimental Windows Imaging Component / Direct2D album art rendering in Default User Interface.
2025-11-07:
Windows: Enabled reading of EXIF orientation info from album cover pictures.
Fixed a regression that prevented shortwindow AAC from being bounced to add-on decoder if available.
Fixed more accidentally insane resampler behaviors.
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Refined workaround for foo_tags (M-Tags) component bugs. No longer hammers all subsongs when starting playback.
Addressed properties dialog info reload glitch inflicted by disabling multi-subsong support.
Made M3U playlists referencing multi subsong files show all subsongs, restoring behavior of past foobar2000 versions.
Made entering blank incoming item sort pattern preserve original track order handed by app interacting with foobar2000, restoring behavior of old foobar2000 versions.
Added advanced preferences toggle to turn off all subsong support.
- Use carefully, might have unwanted side effects or work partially.
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Fixed lockup regression with default-sorted autoplaylists when no default sort pattern is specified.
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Improved subsample offset behavior with retroarch resampler.
2025-11-25:
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Fixed an issue with yesterday's changes in retroarch resampler that could cause glitches near the end of processed stream.
2025-12-01:
Restored out-of-the-box APL link support.
2025-11-25:
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
foobar2000 v2.25.6 Final für Android wurde veröffentlicht.
Changelog v2.25.6:
Fixed a bug in library indexing that causes Album Gain values not to be read into the database.
- To correct missing ReplayGain info, folders must be forcibly reindexed, by disabling & re-enabling in library settings.
Made current live console log downloadable via FTP server.
foobar2000 v2.25.6 Final für iOS wurde veröffentlicht.
Changelog v2.25.6:
Converter: Made "no DSP reset" explicitly shown in overview, as it's dangerous if enabled unintentionally.
2025-12-02:
2025-12-01:
2025-11-25:
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Ported "Play on" feature from foobar2000 mobile - currently accessible from playlist context menu - internet radio stations and other http links can be sent directly to any UPnP renderer device.
Default User Interface: made cycling tabs by keyboard shortcuts cancel tab rename in progress.
Default User Interface: made playlist sort operations recognize %queue_index% and other playlist specific fields.
- This change is experimental and not currently available to add-on components. SDK update documenting how to do this will be made available shortly.
Fixed Skip Track vs Playback Statistics interaction regression, skipped tracks are no longer marked as played.
ARDFTSRC resampler fixed incorrect flush behavior on seek.
Retroarch resampler reduced sample offset.
2025-12-03:
Quality/bugfix updates to both resamplers.
2025-12-02:
2025-12-01:
2025-11-25:
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Mac: Because of erratic behavior of tableview controls on latest macOS, new macOS 26 appearance has been DISABLED. This will be looked into again later.
File Operations: Fixed error with renaming files on redirected portable music folders & macOS volumes.
Fixed various regressions with network shares in Media Library preferences page.
Made new "Play On" accessible in Internet Radio panel context menus.
2025-12-09:
2025-12-03:
2025-12-02:
2025-12-01:
2025-11-25:
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
Enabled WavPack asm optimizations on Windows for slight decoding speedup.
Windows: fixed bugs related to copy-paste of file-relative locations in portable installs.
Fixed MP4 tag writer corrupting specific kinds of fragmented/streaming MP4 files. Some of these are currently untaggable (fails cleanly). This will be properly fixed soon.
Updated Opus decoder to v1.6.
2025-12-12:
2025-12-09:
2025-12-03:
2025-12-02:
2025-12-01:
2025-11-25:
2025-11-24:
2025-11-21:
2025-11-18:
2025-11-15:
2025-11-14:
2025-11-07:
2025-11-04:
2025-11-01:
2025-10-31:
Resampler fixes.
2025-10-30:
Resampler fixes.
2025-10-29:
2025-10-24:
2025-10-24:
2025-10-17:
2025-10-16:
2025-10-12:
2025-10-10:
