Fehler auf HP
sarxer
hi ich bekomme diese fehlermeldung "Warning: mysql_connect() [function.mysql-connect]: User dbweb_dbweb has already more than 'max_user_connections' active connections in /home/dbweb/public_html/freeboard/mysql.inc.php on line 36
Warning: table_wrapper(/home/dbweb/public_html/freeboard/templates//tbopen.tmpl) [function.table-wrapper]: failed to open stream: No such file or directory in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 1505
Warning: table_wrapper() [function.include]: Failed opening '/home/dbweb/public_html/freeboard/templates//tbopen.tmpl' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 1505
Warning: table_wrapper(/home/dbweb/public_html/freeboard/templates//tbclose.tmpl) [function.table-wrapper]: failed to open stream: No such file or directory in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 1506
Warning: table_wrapper() [function.include]: Failed opening '/home/dbweb/public_html/freeboard/templates//tbclose.tmpl' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 1506
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/dbweb/public_html/freeboard/mysql.inc.php on line 108
Warning: not_right(/home/dbweb/public_html/freeboard/templates//ubbt_notright.tmpl) [function.not-right]: failed to open stream: No such file or directory in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 636
Warning: not_right() [function.include]: Failed opening '/home/dbweb/public_html/freeboard/templates//ubbt_notright.tmpl' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 636
Warning: table_wrapper() [function.include]: Failed opening '/home/dbweb/public_html/freeboard/templates//tbclose.tmpl' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/dbweb/public_html/freeboard/ubbt.inc.php on line 1506 " auf dieser http://www.drugbuyers.com/ homepage.
ich konnte dort heute vormittag noch drauf zu greifen. bei anderen funktioniert die seite noch. habe schon verschiedene browser verwendet.
kann mir jemand sagen was das bedeutet bzw. was ich dagegen machen kann.
bedeutet das die MYSQL Datenbank nicht erreichbar ist!
Höchstwahrscheinlich ist die Datenbank überlastet,
oder das Script ist abgestürtzt.
Hast irgendwas drann gemacht?
Passwort verändert? Tabellenname der Datenbank geändert?
Ich glaub aber eher: Die Daten sind aus der Datenbank gelöscht!!
Tipp: Traffic mal checken...
Ne... erste Zeile
Es waren einfach zu viele Leute gleichzeitig online... max_user_connections kann man irgendwo in den mysql user eigenschaften einstellen... erhöhen und gut ist :)
@jpp07
stimmt, aber die anderen Zeilen drunter?
Das bedeutet das die Dateien "home/dbweb/public_html/freeboard/ubbt.inc.php"
im Stammverzeichniss nicht vorhanden sind.
Kann aber auch sein das wie du richtig gesagt hast zuviele drauf
zugreifen und deshalb die Dateien gesperrt werden und er
deshalb die anderen Fehlermeldungen anzeigt...
