Crash Dump
Gert123
Ich habe seit neustem das Problem das mein Rechner (trotz Neuinstallation von Windows 10) ständig Bluescreens produziert und neustartet.
Mit dem Programm "WinDbg" habe ich die .dmp - Datei auslesen können in der folgendes steht:
Microsoft (R) Windows Debugger Version 10.0.19041.1 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\061420-5906-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response Time (ms) Location
Deferred SRV*C:\Temp*http://msdl.microsoft.com/download/sy...
Symbol search path is: SRV*C:\Temp*http://msdl.microsoft.com/download/sy...
Executable search path is:
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_MMPTE_TRANSITION ***
Windows 10 Kernel Version 18362 MP (16 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff803`52e00000 PsLoadedModuleList = 0xfffff803`53248190
Debug session time: Sun Jun 14 00:58:34.535 2020 (UTC + 2:00)
System Uptime: 0 days 20:59:09.627
*** work. ***
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
************* Symbol Loading Error Summary **************
Module name Error
ntoskrnl The system cannot find the file specified
You can troubleshoot most symbol related issues by turning on symbol loading diagnostics (!sym noisy) and repeating the command that caused symbols to be loaded.
You should also verify that your symbol search path (.sympath) is correct.
For analysis of this file, run !analyze -v
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
14: kd> !analyze -v
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffffbb83f9cb3460, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8035a850818, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc0000001, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000003, Optional internal context dependent data.
Debugging Details:
*** WARNING: Unable to verify timestamp for atikmpag.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: nt!_EPROCESS ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: nt!_KTHREAD ***
*** work. ***
*** work. ***
KEY_VALUES_STRING: 1
Key : Analysis.CPU.Sec
Value: 0
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on DESKTOP-INCGQ75
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.Sec
Value: 5
Key : Analysis.Memory.CommitPeak.Mb
Value: 58
Key : Analysis.System
Value: CreateObject
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
WRONG_SYMBOLS_TIMESTAMP: 4ff75719
WRONG_SYMBOLS_SIZE: ab7000
FAULTING_MODULE: fffff80352e00000 nt
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_CODE: 116
BUGCHECK_P1: ffffbb83f9cb3460
BUGCHECK_P2: fffff8035a850818
BUGCHECK_P3: ffffffffc0000001
BUGCHECK_P4: 3
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
STACK_TEXT:
ffff8b0b`e11f4908 fffff803`5b1decea : 00000000`00000116 ffffbb83`f9cb3460 fffff803`5a850818 ffffffff`c0000001 : nt+0x1c23a0
ffff8b0b`e11f4910 00000000`00000116 : ffffbb83`f9cb3460 fffff803`5a850818 ffffffff`c0000001 00000000`00000003 : dxgkrnl+0x23ecea
ffff8b0b`e11f4918 ffffbb83`f9cb3460 : fffff803`5a850818 ffffffff`c0000001 00000000`00000003 00000000`00002000 : 0x116
ffff8b0b`e11f4920 fffff803`5a850818 : ffffffff`c0000001 00000000`00000003 00000000`00002000 ffffbb83`f9cb3460 : 0xffffbb83`f9cb3460
ffff8b0b`e11f4928 ffffffff`c0000001 : 00000000`00000003 00000000`00002000 ffffbb83`f9cb3460 fffff803`5b18e1cb : atikmpag+0x10818
ffff8b0b`e11f4930 00000000`00000003 : 00000000`00002000 ffffbb83`f9cb3460 fffff803`5b18e1cb fffff803`5a850818 : 0xffffffff`c0000001
ffff8b0b`e11f4938 00000000`00002000 : ffffbb83`f9cb3460 fffff803`5b18e1cb fffff803`5a850818 ffffbb83`fa9ad000 : 0x3
ffff8b0b`e11f4940 ffffbb83`f9cb3460 : fffff803`5b18e1cb fffff803`5a850818 ffffbb83`fa9ad000 ffffbb83`fa9ad0d8 : 0x2000
ffff8b0b`e11f4948 fffff803`5b18e1cb : fffff803`5a850818 ffffbb83`fa9ad000 ffffbb83`fa9ad0d8 00000000`00000000 : 0xffffbb83`f9cb3460
ffff8b0b`e11f4950 fffff803`5a850818 : ffffbb83`fa9ad000 ffffbb83`fa9ad0d8 00000000`00000000 ffffbb83`f9cb3460 : dxgkrnl+0x1ee1cb
ffff8b0b`e11f4958 ffffbb83`fa9ad000 : ffffbb83`fa9ad0d8 00000000`00000000 ffffbb83`f9cb3460 00000000`00002000 : atikmpag+0x10818
ffff8b0b`e11f4960 ffffbb83`fa9ad0d8 : 00000000`00000000 ffffbb83`f9cb3460 00000000`00002000 00000000`00000001 : 0xffffbb83`fa9ad000
ffff8b0b`e11f4968 00000000`00000000 : ffffbb83`f9cb3460 00000000`00002000 00000000`00000001 ffffbb83`fa9ad9e0 : 0xffffbb83`fa9ad0d8
STACK_COMMAND: .thread ; .cxr ; kb
EXCEPTION_CODE_STR: 4FF75719
EXCEPTION_STR: WRONG_SYMBOLS
PROCESS_NAME: ntoskrnl.wrong.symbols.exe
IMAGE_NAME: ntoskrnl.wrong.symbols.exe
MODULE_NAME: nt_wrong_symbols
SYMBOL_NAME: nt_wrong_symbols!4FF75719AB7000
FAILURE_BUCKET_ID: WRONG_SYMBOLS_X64_TIMESTAMP_120706-212233_4FF75719_nt_wrong_symbols!4FF75719AB7000
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {7ce4e62c-85d8-2ecd-2b51-a7c9d6d22766}
Followup: MachineOwner
Liste mal bitte deine vollständige Hardware auf, danke!
Er meint, ob du den Ram mal auf Fehler geprüft hast, hier eine Methode unter Windows:
Das neueste Bios ist da drauf?
Sonst ist da normalerweise die Grafikkarte bzw deren Treiber schuld.
