Bin auf die suche, hab ein A33606-PCI-01P Expander, und würde gern die im eine "normale" Mainboard nutzten. Da ich bis jetzt PCI-X Controller gehabt habe wo leider jetzt Mainboard Kapput gegangen ist.
Würde lieber ein normale board mit PCIe x8/16 und Controller dafür.
Zur expander:
Also ich brauche auch neue Mainboard+CPU,sollte sparsam sein und Controller soll drauf normal funktionieren ohne welche Beschränkungen.
Zur expander:
Expander: A33606-PCI
A complete, pre-programmed, Gen2 6Gbps SAS Expander in a PCI/PCI-Express card form factor.
The A330606-PCI board is designed to allow a system designer complete flexibility in the use of the LSISAS2x36 expander. By purchasing the Astek product, engineers can rely on Astek's team of storage experts to deliver firmware and configuration assistance and support. The A33606 design allows platform builders to use the SAS expander ports in any combination (9 x4 wide ports, 4 wide ports and 20 target disks, etc.) and access a variety of enclosure management services including standard 4-pin fan supply/controls, GPIO pins for sensors and LED drivers, thermal monitoring, SGPIO interfaces on all internal SFF-8087 connectors, and an RS232 management port.
The A33606-PCI card is a plug-and play solution, requiring no circuit design or complex software development, but is powerful enough to be extended and expanded to scale up to your design needs. Astek can even deliver custom SCSI Enclosure Services firmware to make your platform a market standout.
A33606-PCI - Serial Attached SCSI Expanders - Astek Corporation
