[Sammelthread] Clevo Barebone - Upgrade & Modifikationen (alle Modelle)
Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones :wink:
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR (Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/091. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/091. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/091. System BIOS 1.02.08 for P570WM only.
2013/01/191. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/191. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/191. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/071. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/071. System BIOS 1.00.02 for P570WM only.
LINKS:
[Sammelthread] 17,3" Clevo P570WM(3) SLI/CFX High-End DTR (2012)
# 17,3" Clevo X7200 (Release Q3/2010) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/10/281. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/231. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/081. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/101. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/201. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/251. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/111. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/251. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/051. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/151. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
2010/09/301. System BIOS 1.00.03.
2. Solve "system can't identify nVIDIA GTX 460M VGA card correctly" issue.
LINKS:
[How-to-Video] AMD Radeon HD 7970M CrossFireX Installation in EUROCOM Panther 2.0 (X7200)
# 17,1" Clevo D90xF (Release Q2/2009) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/05/251. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/301. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/221. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/161. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/241. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
LINKS:
[User-Review] 17,1" Clevo D900F Gamer/Workstation Notebook
[How-to-Video] NVIDIA GeForce GTX 680M upgrade in EUROCOM D900F Panther
# 17,1" Clevo D90xC (Release Q2/2007) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2008/12/121. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/121. KBC/EC firmware for Windows XP keyboard only.
2008/12/121. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/201. KBC/EC firmware for VISTA keyboard only.
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/201. KBC/EC firmware for XP keyboard only.
2008/10/14Support Q9550 CPU.
2008/09/10Support nVIDIA NB9x series VGA.
2008/07/22Support 9800M GT VGA card.
2008/06/121. KBC/EC firmware for XP keyboard only.
2. Solve "sometimes system can't boot up" issue.
2008/06/121. KBC/EC firmware for VISTA keyboard only.
2008/05/20Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30 1. KBC/EC firmware for VISTA keyboard only.
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/301. KBC/EC firmware for XP keyboard only.
2008/03/21Support both partnet board and daughter board.
2008/03/12Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/121. KBC/EC firmware for VISTA keyboard only.
2. Solve VGA temperature probe inaccuracy issue.
2008/03/121. KBC/EC firmware for XP keyboard only.
2008/01/21Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/181. KBC/EC firmware for XP keyboard only.
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/291. KBC/EC firmware for VISTA keyboard only.
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/291. KBC/EC firmware for Windows XP keyboard only.
2007/10/291. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/231. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/161. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
LINKS:
[User-Review] CLEVO D901C ...8700GT SLI trifft Quadcore
SLI/CFX GAMER NOTEBOOK (Mobil CPU)
# 17,3" Clevo P370EMx (Release Q3/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/081. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/261. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/261. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/261. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/151. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/241. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/241. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/241. System BIOS 1.02.06 for P370EM3 only.
2012/10/121. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/281. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
LINKS:
[Sammelthread] 17,3" Clevo P370EM(3) SLI/CFX Gamer Notebook (2012)
# 18,4" Clevo P180HM (Release Q3/2011) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/07/061. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/181. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/041. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/211. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/071. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/02/251. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/221. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/101. EC firmware 1.00.08.
2. Modify nVIDIA VGA fan table.
2010/07/151. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support ATI HD5870 VGA.
2010/05/071. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/151. System BIOS 1.00.06.
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/301. System BIOS 1.00.04 and EC firmware 1.00.02.
2010/02/051. System BIOS 1.00.02.
2. Update code base.
LINKS:
[How-to-Video] NVIDIA GeForce GTX 680M Upgrade in EUROCOM X8100 Leopard
[How-to-Video] AMD Radeon HD 7970M upgrade in 18.4" EUROCOM X8100 Leopard Notebook
17" GAMER NOTEBOOK
# 17,3" Clevo P170EM (Release Q2/2012) 03.05.13
TECHNISCHE DATEN: (Modell C)
BIOS CHANGELOG:
releasechanges
2013/04/151. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/091. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/301. System BIOS 1.02.14 for P170EM only.
2012/10/301. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/121. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/281. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/311. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/241. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/271. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/111. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/151. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/081. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
LINKS:
[Sammelthread] 17,3" Clevo P170EM(3) Gamer Notebook (2012)
# 17,3" Clevo P170HMx (Release Q1/2011) 04.05.13
TECHNISCHE DATEN: (Modell C & D)
BIOS CHANGELOG:
releasechanges
2011/10/281. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/161. EC firmware 1.00.08.
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/091. System BIOS 1.01.10 for P170HM only.
2011/09/091. System BIOS 1.01.05 for P17xHM3 only.
2011/08/111. System BIOS 1.01.03 for P17xHM3 only.
2011/08/051. System BIOS for P170HMxx only (except P170HM3).
2011/06/101. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/271. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/061. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/221. EC firmware 1.00.05.
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/181. EC firmware 1.00.03.
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/251. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/141. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
LINKS:
[Prema Mod] P1x0HMx Mod-BIOS
[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
# 17,3" Clevo W88xCU (Release Q3/2010) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/10/081. System BIOS 1.00.05.
2. Solve the audio problem of BIOS 1.00.04.
2010/09/141. System BIOS 1.00.04.
2. Solve "Windows Experience Index is incorrect" issue.
2010/08/061. System BIOS 1.00.03.
2. Solve “system can’t identify Intel K0 stepping CPU” issue.
2010/07/091. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/03/03ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/261. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/221. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/081. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/201. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/171. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/201. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/181. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/301. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/251. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/111. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
LINKS:
26.06.10 [User-Review] Clevo W870CU / XMG7.c - bis zu 3,8GHz
15" GAMER NOTEBOOK
# 15,6" Clevo P15xEMx (Release Q2/2012) 04.05.13
TECHNISCHE DATEN: (Modell A & B)
BIOS CHANGELOG:
releasechanges
2013/03/231. System BIOS 1.02.17 for P150EM only.
2013/03/151. System BIOS 1.02.17 for P151EM1 only.
2013/01/191. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/191. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/301. EC firmware 1.02.11 for P151EM1 only.
2012/10/301. System BIOS 1.02.14 for P151EM1 only.
2012/10/301. EC firmware 1.02.11 for P150EM only.
2012/10/301. System BIOS 1.02.14 for P150EM only.
2012/10/121. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/281. EC firmware 1.00.08 for P150EM only.
2012/09/071. System BIOS 1.00.10 for P151EM1 only.
2012/09/071. System BIOS 1.00.10 for P150EM only.
2012/08/311. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/241. EC firmware 1.00.07 for P150EM only.
2012/07/121. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/291. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/151. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/041. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
LINKS:
28.06.12 notebookreview.com = P150EM Upgrading from 675M to 680M!
# 15,6" Clevo P15xHMx (Release Q1/2011) 04.05.13
BIOS CHANGELOG:
releasechanges
2011/11/041. EC firmware 1.00.13.
2. Solve “sometimes screen flickers” issue.
2011/09/161. EC firmware 1.00.12.
2011/09/091. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/051. System BIOS 1.01.12.
2011/07/151. EC firmware 1.00.11.
2011/07/011. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/061. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
(need to update LAN driver to 6.0.26.6 or later)
2011/03/251. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/251. System BIOS 1.01.04.
2011/01/141. System BIOS 1.00.03 and EC firmware 1.00.02.
LINKS:
# 15,6" Clevo W860CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/3/3 ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/10/29 1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20 1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17 1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6 1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11 1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21 VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/4/30 1. System BIOS 1.00.13 for W86xCU only.
2010/2/25 1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11 1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
LINKS:
10.01.11 [How-to-Video] Mount AMD Radeon HD6970M to EUROCOM Cougar Laptop (W860CU)
10.01.11 [Video-Review] EUROCOM W860CU Cougar HD 6970M
08.12.10 [User-Review] 15,6" Clevo W860CU Gamer Notebook
ANHANG
# Clevo Barebone - MXM3.0B Grafikkarten 16.09.12
nVidia GeForce GTX 280M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 285M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 460M (GF106/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 480M (GF100/352SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 485M (GF104/384SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 560M (GF116/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 670M (GF114/336SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 680M (GK104/1344SP) 4096MB (256Bit/GDDR5) 100W-TDP
_
ATI Mobility Radeon HD 5870 (RV840/800SP) 1024MB (128Bit/GDDR5) ~75W-TDP
_
AMD Radeon HD 6970M (RV940/960SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
AMD Radeon HD 7970M (Wimbledon XT/1280SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
Wer sein Clevo aufrüsten will, kann ja mal in meinem Verkaufthread reinschauen, habe da einen i7 2920XM zu verkaufen...
Grüße
gibt es jemand der mir villt Helfen könnte ?
würde gerne mein Clevo D900F aufrüsten aber das mit VBios und und das doppelte Heatsink für die Grafikkarte macht mir arbeit falls jemand
sich ausckent und mir Privat helfen könnte würde ich sehr dankbar sein würde ihm auch was dafür zahlen :wink:
- - - Updated - - -
Bitte um Hilfe bin ein Clevo D900F Besitzer und wollte es umrüsten bitte um eure Hilfe :-)
ich habe ein Clevo W25CSW Barebone mit i7-4712.
Es tut sich aber nichts nach dem einschalten. Lüfter dreht nicht, die blaue LED an der Taste leuchtet kurz auf und geht dann wieder aus.
Hat einer eine Idee? Gibt es bei dem Barebone außer dem Einbau von Prozessor, RAM und SSD noch etwas zu tun?
Vielen Dank
hms
habe ein D901C und 2 9800M GTX.
Hat jemand die nötigen Bios-files für den SLI-Betrieb und ne Anleitung?
Ist es normal, dass beide Karten jeweils nur im Daughter-Slot erkannt werden und laufen?
ich habe den Clevo P150HM mit i7-2630QM und ATI6970m.
Was kann ich denn nun bedenkenlos aufrüsten? Verstehe die Bilder nicht so wirklich.
CPU: i7-2920XM
VGA: GTX 580M (offiziel) / HD 7970M (inoffiziell)
Hammer vielen dank! Wegen offiziel und inoffiziell nutze ich dann lieber google möchte hier nicht als völliger dummkopf dastehen.
Top, danke nochmal. Daumen hoch!
Gibt es mittlerweile eine Möglichkeit die 8970m im p150hm zum laufen zu bringen ?
Ich brauche dringend eine neue Leistungsfähige Grafikkarte. Falls jemand noch einen Tipp zur Beschaffung hat würde ich mich auch gern über eine PN freuen.
nochmal ich :-)
Mein Netzteil vom Clevo P150HM hat sich verabschiedet. Woher könnte ich denn ein günstuges bekommen? Amazon sind 90€.
AC Input: 100-240V~
DC Output: 19V 9,47A
Wattzahl steht leider nichts drauf und wegen dem Stecker bin ich mir nicht ganz sicher da ich keinen Meßschieber da habe.
W= V x A ;)
> 180W
P15 hat normale 2 PIN Stecker, da kannst Du auch andere Modelle verwenden (19.5v geht auch)
Ich habe mal eine Frage. Habe ein Clevo m980nu mit 2xgtx280m. Habe im Internet jetzt gelesen das wohl auch eine bzw 2 gtx670m laufen sollen. Weiß da jemand etwas darüber ob das funktioniert?
Schon mal danke für die Hilfe :d
@ sl3vin
Das einfachste ist doch bei einem Händler von Clevo-Barbones zu schauen! ;)
Klick mich! :d
Hallo Jungs.
Folgendes Anliegen habe ich.
Ich besitze eine Clevo W540EU. Dieses habe ich damals noch von Hawkforce als Restposten bekommen.
Bin soweit super zufrieden mit dem Teil nur eine Sache gibt es die mich stört. Und zwar das Display es löst nur mit 1366x768 auf und wenn ich bissel was am programmieren bin stört mich das dann doch schon.
Nun zu meiner Frage offiziell wurde das Notebook scheinbar nur mit dieser Auflösung angegeben bzw. nur dieses Display. Gibt es vllt. doch eine Möglichkeit dort ein Full HD display auf 14" einzubauen ?
Schonmal vielen Dank
ich habe ein Clevo P150HM und mir ist die 6990M abgeraucht. Nun hatte ich bei Clevo angefragt, was ich da tun kann und eine Liste mit Grafikkarten bekommen. Da stand auch die Geforce 480M dabei, die ich mir jetzt bei Ebay gekauft habe. Ich habe aber so das Gefühl, dass die Karte nicht unterstützt wird. Mein Standard-Bios erkennt die Karte richtig, aber im Win7 wird nur Standard VGA angezeigt und der Nvidia Treiber ist deshalb nicht installierbar. Gibt es jemand, der mir da weiterhelfen kann mit einem vbios oder ähnlichem, oder der mir mit Sicherheit sagen kann, dass die Grafikkarte definitiv nicht passt. Ich glaube Clevo, hat mir da schlichtweg eine falsche Karte genannt.
Danke und beste Grüße Flash
Dann ist nicht das clevo bios drauf sondern dell oder msi und du must die inf datei des treibers ändern. Google mal danach. Blos nicgt das Bios der Grafikkarte ändern! Kompatibel ist die gtx 480.
Gesendet von meinem GT-I9505 mit der Hardwareluxx App
Supi ;)
Soooo, hab mal die Heatsink für das p1xxSM für die 8970M geordert.. Laut T|I Forum soll diese wohl perfekt auf die 7970M passen, nur die Wärmeleitpads sind halt falsch, aber das kann man ja korrigieren. Na dann warten wir mal ab..
Hallo :)
Ich bin neu hier, habe mir diesen Thread schon fast vollständig durchgelesen, bis ich DIESEN BEITRAG gefunden habe :d Genau die Frage, die mich seit längerem Beschäftigt.
Ich würde gerne die Wärmeleitpads austauschen (2 x 8970m, P375SM). Habe bisher NIRGENDS eine Info bekommen, welche mir die richtige Stärke der Pads offenbaren würde. Daher habe ich bereits mit verschiedenen Stärken "herumexperimentiert", das Ergebnis lässt aber zu wünschen übrig. Die grauen PHOBYA-Pads scheinen gut zu sein, aber sind nicht so weich, wie die originalen. Es wäre wirklich mega-super-dolle-toll, wenn einer von Euch mir die richtige Stärke der Pads für RAM, VRMs und die anderen (kenne den Namen nicht) sagen könnte.
Im Techinferno-Forum hatte ich zwar die Frage auch gestellt, habe aber keine Antwort erhalten. Vielleicht könnte jemand, der demnächst die Paste tauscht, die Pads vermessen und mit ein Bild von den Heatsinks hochladen, an denen ich erkennen kann, wie die Pads im Originalzustand und/oder gemoddet auszusehen haben.
Würde mir weitere "Experimente", die bereits zum 3 Mal knapp 40 Euro verschlungen haben, ersparen und ich könnte wieder mal so richtig lange zocken.
Danke für Eure Hilfe ;)
1,5 Jahre. Die alten Pads sind nicht mehr gebrauchsfähig.
Ich hab das XMG P502 und wollte mal wissen welches Bios ich ganz genau von Prema brauch? Hab die Win Taste auf der rechten seite. Lohnt sich das Prema Bios überhaupt? Welches Vbios wäre das richtige für die GTX680m wo man denn keine OC Sperre mehr hätte. Es gibt ja soviel Biose im Netz, da kann man viel falsch machen.
Hi,ich bin neu hier und hab da mal ein skuriles Problem.
Ich befürchte ich hab meine Radeon HD6970 in meinem One / Clevo P150HMx geschrottet.
Vielleicht zu heiß geworden. Erst Bildfehler, dann schwarzer Bildschirm.
(Kühlrippen waren voll mit Staub (innen zw. Lüfter und Kühlrippen, von außen nicht sichtbar.)
Ja, mangelnde Wartung wg. Unwissenheit :wall:)
Aber jetzt kommts.
1.) Rechner startet (Bild da), bis Win7 animierter Startbildschirm, dann schwarz.
2.) Start in Win7 Abgesicherter Modus. GraKa wird nicht erkannt. Auflösung ist 640x480 mit 16 Farben (nicht 16-bit) -> praktisch nicht nutzbar
2.1) Ist auch nicht umstellbar. Zwar werden andere Auflösungen angeboten, nach dem Umstellen bleibt es aber bei 640x480x16Farben.
3.) Im Bios wird sie aber korrekt erkannt.
4.) GPU-Z erkennt sie auch, meldet aber GPU aktuell 100MHz und RAM aktuell 150MHz.
5.) Ohne GraKa (also physisch ausgebaut) bleibt der Bildschirm schwarz, weil (wie ich gelesen haben) die interne Grafik IGP beim P150HM nicht angeschlossen ist.
ABER
6.) Lubuntu 14.10 startet von CD ohne Probleme mit 1920x1080 in 32-bit
Wie kann das denn gehen? Linux wird ja wohl nicht die IGP anbinden können ;-)
Aber sollte Lubuntu einen Grafiktreiber haben der aus der gebratenen Karte noch
Office-Leistung in 1920x1080x32bit herausholen kann?
Und nun meine Frage: Wie kriege ich das unter Win7 hin? (Auflösung 1920x1080x32bit)
Vielen Dank im Voraus.
Chris
Hi sl3vin
Win7 neu aufgesetzt. ->640x480x16Farben!
ATI-Treiber lässt sich nicht installieren, da 640x480 zu klein sind für das Installationsfenster (dank des blöden Werbebildes in der Mitte :stupid: )
Daher Nein zu den Treibern
Chris
Hallo zusammen,
ich habe ein P170SM mit ATI 8970m Grafikkarte, bin soweit total zufrieden aber habe das Problem das einige Games nicht mit der ATI sondern mit der Intel starten. Wie kann ich das einstellen ? Über Eigenschaften geht es nicht und im Geräte Manager die Intel ausschalten bringt auch nichts leider.
Gibt es da einen Trick ?
XMG P501 Pro / Clevo P150HM
Ohh hoffentlich ist der Thread nicht eingeschlafen, denn ein Neuling braucht Hilfe :-D
Ich besitze ein Schenker XMG P501 Pro, was ja dem Clevo P150HM wohl entspricht (soviel war der Neuling schon in der Lage zu recherchieren ;-) )
Nun ist mir darin die 6990m wohl abgeraucht, beim starten sehe ich manchmal blaue Streifen, manchmal bootet er auch ohne Grafikfehler, dann beginnt aber nach ein paar Minuten flackern und Bildverschiebung im Windows Betrieb, bis hin zu schwarzem Bildschirm, Gerät läuft aber weiter.
Ist auch passend 1 Monat nach Ablauf der Garantie kaputt gegangen das Ding (hatte es als Restposten bei XMG damals ergattert, daher bis vor kurzem noch Garantie) Habe mit denen telefoniert und sie würden "netterweise" die Versandkosten übernehmen und den Kostenvoranschlag für die Reparatur übernehmen, aber er könne schon jetzt sagen, dass er für dieses Modell nur noch gtx 560m da hat und ich mit über 400€ Kosten rechnen müsste.
Durch mein bisheriges Nutzungsverhalten hab ich aber gemerkt, dass ich kaum damit Spiele (hab ich weiterhin mit dem Desktop gemacht) und mir würde ein reiner CPU Betrieb reichen (der I7 2670QM hat ja meines wissen nach integrierte Grafik).
Auf den Vorschlag hin meinte der Techniker, das würde nicht gehen, weil das Bios-seitig gesperrt ist und die Verwendung einer Grafikkarte quasi ein "Zwang" ist.
Ich kann mir das eigentlich nicht vorstellen. Geht nicht, gibts nicht. Ich meine am Desktop kann man das doch auch im BIOS einstellen? Ist das wirklich hardwareseitig gelötet, dass ich da keine Chance auf diese "günstige" Reparatur-Variante habe? Ich hab bei NB ja echt keine Kenntnisse im Schrauben, aber dank dem Internet würd ich mir zutrauen die Grafikkarte auszubauen, nur will ich eben, dass das Ding dann noch läuft und ein Bild ausgibt.
