[Sammelthread] Clevo Barebone - Upgrade & Modifikationen (alle Modelle)
Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones :wink:
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR (Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/091. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/091. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/091. System BIOS 1.02.08 for P570WM only.
2013/01/191. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/191. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/191. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/071. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/071. System BIOS 1.00.02 for P570WM only.
LINKS:
[Sammelthread] 17,3" Clevo P570WM(3) SLI/CFX High-End DTR (2012)
# 17,3" Clevo X7200 (Release Q3/2010) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/10/281. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/231. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/081. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/101. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/201. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/251. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/111. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/251. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/051. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/151. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
2010/09/301. System BIOS 1.00.03.
2. Solve "system can't identify nVIDIA GTX 460M VGA card correctly" issue.
LINKS:
[How-to-Video] AMD Radeon HD 7970M CrossFireX Installation in EUROCOM Panther 2.0 (X7200)
# 17,1" Clevo D90xF (Release Q2/2009) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/05/251. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/301. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/221. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/161. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/241. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
LINKS:
[User-Review] 17,1" Clevo D900F Gamer/Workstation Notebook
[How-to-Video] NVIDIA GeForce GTX 680M upgrade in EUROCOM D900F Panther
# 17,1" Clevo D90xC (Release Q2/2007) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2008/12/121. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/121. KBC/EC firmware for Windows XP keyboard only.
2008/12/121. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/201. KBC/EC firmware for VISTA keyboard only.
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/201. KBC/EC firmware for XP keyboard only.
2008/10/14Support Q9550 CPU.
2008/09/10Support nVIDIA NB9x series VGA.
2008/07/22Support 9800M GT VGA card.
2008/06/121. KBC/EC firmware for XP keyboard only.
2. Solve "sometimes system can't boot up" issue.
2008/06/121. KBC/EC firmware for VISTA keyboard only.
2008/05/20Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30 1. KBC/EC firmware for VISTA keyboard only.
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/301. KBC/EC firmware for XP keyboard only.
2008/03/21Support both partnet board and daughter board.
2008/03/12Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/121. KBC/EC firmware for VISTA keyboard only.
2. Solve VGA temperature probe inaccuracy issue.
2008/03/121. KBC/EC firmware for XP keyboard only.
2008/01/21Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/181. KBC/EC firmware for XP keyboard only.
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/291. KBC/EC firmware for VISTA keyboard only.
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/291. KBC/EC firmware for Windows XP keyboard only.
2007/10/291. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/231. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/161. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
LINKS:
[User-Review] CLEVO D901C ...8700GT SLI trifft Quadcore
SLI/CFX GAMER NOTEBOOK (Mobil CPU)
# 17,3" Clevo P370EMx (Release Q3/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/081. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/261. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/261. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/261. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/151. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/241. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/241. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/241. System BIOS 1.02.06 for P370EM3 only.
2012/10/121. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/281. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
LINKS:
[Sammelthread] 17,3" Clevo P370EM(3) SLI/CFX Gamer Notebook (2012)
# 18,4" Clevo P180HM (Release Q3/2011) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/07/061. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/181. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/041. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/211. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/071. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/02/251. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/221. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/101. EC firmware 1.00.08.
2. Modify nVIDIA VGA fan table.
2010/07/151. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support ATI HD5870 VGA.
2010/05/071. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/151. System BIOS 1.00.06.
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/301. System BIOS 1.00.04 and EC firmware 1.00.02.
2010/02/051. System BIOS 1.00.02.
2. Update code base.
LINKS:
[How-to-Video] NVIDIA GeForce GTX 680M Upgrade in EUROCOM X8100 Leopard
[How-to-Video] AMD Radeon HD 7970M upgrade in 18.4" EUROCOM X8100 Leopard Notebook
17" GAMER NOTEBOOK
# 17,3" Clevo P170EM (Release Q2/2012) 03.05.13
TECHNISCHE DATEN: (Modell C)
BIOS CHANGELOG:
releasechanges
2013/04/151. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/091. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/301. System BIOS 1.02.14 for P170EM only.
2012/10/301. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/121. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/281. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/311. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/241. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/271. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/111. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/151. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/081. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
LINKS:
[Sammelthread] 17,3" Clevo P170EM(3) Gamer Notebook (2012)
# 17,3" Clevo P170HMx (Release Q1/2011) 04.05.13
TECHNISCHE DATEN: (Modell C & D)
BIOS CHANGELOG:
releasechanges
2011/10/281. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/161. EC firmware 1.00.08.
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/091. System BIOS 1.01.10 for P170HM only.
2011/09/091. System BIOS 1.01.05 for P17xHM3 only.
2011/08/111. System BIOS 1.01.03 for P17xHM3 only.
2011/08/051. System BIOS for P170HMxx only (except P170HM3).
2011/06/101. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/271. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/061. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/221. EC firmware 1.00.05.
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/181. EC firmware 1.00.03.
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/251. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/141. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
LINKS:
[Prema Mod] P1x0HMx Mod-BIOS
[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
# 17,3" Clevo W88xCU (Release Q3/2010) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/10/081. System BIOS 1.00.05.
2. Solve the audio problem of BIOS 1.00.04.
2010/09/141. System BIOS 1.00.04.
2. Solve "Windows Experience Index is incorrect" issue.
2010/08/061. System BIOS 1.00.03.
2. Solve “system can’t identify Intel K0 stepping CPU” issue.
2010/07/091. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/03/03ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/261. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/221. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/081. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/201. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/171. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/201. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/181. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/301. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/251. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/111. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
LINKS:
26.06.10 [User-Review] Clevo W870CU / XMG7.c - bis zu 3,8GHz
15" GAMER NOTEBOOK
# 15,6" Clevo P15xEMx (Release Q2/2012) 04.05.13
TECHNISCHE DATEN: (Modell A & B)
BIOS CHANGELOG:
releasechanges
2013/03/231. System BIOS 1.02.17 for P150EM only.
2013/03/151. System BIOS 1.02.17 for P151EM1 only.
2013/01/191. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/191. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/301. EC firmware 1.02.11 for P151EM1 only.
2012/10/301. System BIOS 1.02.14 for P151EM1 only.
2012/10/301. EC firmware 1.02.11 for P150EM only.
2012/10/301. System BIOS 1.02.14 for P150EM only.
2012/10/121. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/281. EC firmware 1.00.08 for P150EM only.
2012/09/071. System BIOS 1.00.10 for P151EM1 only.
2012/09/071. System BIOS 1.00.10 for P150EM only.
2012/08/311. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/241. EC firmware 1.00.07 for P150EM only.
2012/07/121. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/291. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/151. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/041. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
LINKS:
28.06.12 notebookreview.com = P150EM Upgrading from 675M to 680M!
# 15,6" Clevo P15xHMx (Release Q1/2011) 04.05.13
BIOS CHANGELOG:
releasechanges
2011/11/041. EC firmware 1.00.13.
2. Solve “sometimes screen flickers” issue.
2011/09/161. EC firmware 1.00.12.
2011/09/091. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/051. System BIOS 1.01.12.
2011/07/151. EC firmware 1.00.11.
2011/07/011. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/061. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
(need to update LAN driver to 6.0.26.6 or later)
2011/03/251. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/251. System BIOS 1.01.04.
2011/01/141. System BIOS 1.00.03 and EC firmware 1.00.02.
LINKS:
# 15,6" Clevo W860CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/3/3 ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/10/29 1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20 1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17 1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6 1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11 1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21 VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/4/30 1. System BIOS 1.00.13 for W86xCU only.
2010/2/25 1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11 1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
LINKS:
10.01.11 [How-to-Video] Mount AMD Radeon HD6970M to EUROCOM Cougar Laptop (W860CU)
10.01.11 [Video-Review] EUROCOM W860CU Cougar HD 6970M
08.12.10 [User-Review] 15,6" Clevo W860CU Gamer Notebook
ANHANG
# Clevo Barebone - MXM3.0B Grafikkarten 16.09.12
nVidia GeForce GTX 280M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 285M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 460M (GF106/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 480M (GF100/352SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 485M (GF104/384SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 560M (GF116/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 670M (GF114/336SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 680M (GK104/1344SP) 4096MB (256Bit/GDDR5) 100W-TDP
_
ATI Mobility Radeon HD 5870 (RV840/800SP) 1024MB (128Bit/GDDR5) ~75W-TDP
_
AMD Radeon HD 6970M (RV940/960SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
AMD Radeon HD 7970M (Wimbledon XT/1280SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
Kein Thema, immer wieder gerne!
Habe nochmal im NBR gesucht und habe meine Bestätigung gefunden. Es gibt einen aktuelleren Thread aus 2015 wo das ganze vom Nutzer "jaybee" auch bestätigt wird, siehe hier:
Clevo P170HM GPU Replacement/Upgrade | NotebookReview
Sorry das ich dir keine positive Nachricht geben kann :(
Wenn du die 7970m verkaufst, schau doch besser nach einer kompatiblen 680M (vBIOS MUSS beim p1x0HM folgendes sein: 80.04.29.00.01). Die hat super OC potenzial, brauch keinen Blindflash und läuft mit gemoddeten Treibern. Dazu findest du im Notebookreview Forum einige Threads, ggf. hat jemand sogar im Marketplace eine 680M zu verkaufen.
Grüße
F1r3
hallo erstmal ^^
hab das gleiche problem mit meiner 7970m ist auch aus einem p370m mit revision 1.1 .... verkaufe meine auch gerade nur ist es nicht so leicht die weg zu bekommen ^^ habe also ein laptop daheim stehn ohne grafikkarte und bin 200euro ärmer.... supi....
ich suche schon seit Tagen im Netz ein Bios oder Bios Mod für mein Clevo P180HMx, leider habe ich keinen Link mehr gefunden der aktiv ist.
Meine aktuelle Bios Version: 1.01.01 EC 1.00.02
Vieleicht könnt ihr mir ja weiter helfen, wo ich ein Update her bekomme.
Wo gibts eig einen ausfürlichen Thread zu den Aktuellen Notebooks wie dem P771DM (Schenker U706) usw?
Schau dich am besten im Notebookreview Forum um - die deutsche Community ist wohl zu gering ;)
Im NBR gibt es für das BATMAN Notebook einen großen Sammler :)
mysn.de > Treiber > Archiv > P801 (Schenker für P180HM) > BIOS > 1.03.04
Ich habe aber auch mal ne Frage zum BIOS. Weiß jemand ob das letzte BIOS für den M860TU schon die GTX 285m untertützt?
Wenn ich das recht lese, gab es die 285M nie für MXM Type III, sondern nur als MXM 3.0B-Karte.
Du kannst allerdings eine 280M verbauen.
Hat jemand schon mal ein eGPU Setup am p370 via thunderbolt betrieben oder geht das gar nicht?
Mfg
Gesendet von meinem D6603 mit der Hardwareluxx App
An welchem P370 genau? Die Buchstaben dahinter klären erst über die Generation auf :)
Verdammt, stimmt ja der Anschluss passt garnicht. Da habe ich aber auch voll gepennt...
Die 280M soll im Schnitt allerdings nur 5-10% langsamer sein aber passen.
Hmm ja, jetzt muss ich nur noch ne 280m zu nem vernünftigen Preis und als MXM 2.1-Ausführung finden. Naja ist zum Glück nicht dringend, meine FX2700m läuft noch problemlos. :)
Uh, das wird sicher nicht billig, selbst die 260M geht teilweise für 80-90€ weg.
Du brauchst übrigens explizit die MXM 2.1 Type IV Version, alle anderen MXM 2.1 Karten werden nicht passen :d
Hat sich ohnehin erledigt, da man keine 8GB RAM ins M860TU rein bekommt (jedenfalls nicht in eine 2-Kern-Version), wie ich eben rausfinden durfte. :grrr:
Nutzt ihr vielleicht eine BIOS oder VBIOS Modifikation von dem bekannten 'Master of (v)BIOS Mods' Prema?
'Freut' ihr euch darüber, das euer Clevo Barebone euch durch die modifizierte Firmware mehr Freiheiten an die Hand gibt, als der Auslieferungszustand?
Wünschst ihr euch auch bei zukünftigen Clevo Barebone diese Freiheiten zu haben?
...dann mögt ihr vielleicht mit ein paar Euros die Prema Spendenaktion auf notebookreview.com unterstützten und 'Danke sagen' :wink:
Hi liebe Clevo Gemeinde,
wie schaut es aus mit CPU Tausch beim Clevo N960TD.
Freund hat den aus versehen mit den I3-8100 bestellt.
Er kommt günstig an einen I7-8700 und ich suche parallel für ihm hier im HWLuxx einen I7-9700 oder I9-9900.
Laut Clevo passen alle 8th und 9th Generation CPU mit TDP von 65W ( �天Clevo )
Muss irgend bios Update eingespielt werden oder einfach CPU rein und fertig.
Hey Leute hab hier ein CLEVO P375SM-A jetzt möchte gerne das Standard "Finger Sensing Pad" tauschen da es nicht beleuchtet ist ...
meine Vermutung ist folgende: Da es so aussieht als ob man bei Hotkey 3.10.23 (verschiedene Farben auswählen kann) sollte doch möglich sein ???
Hat hier schon mal jemand diesen Mod gemacht ?
Und wo bekomme ich das beleuchtet Pad her
MFG
Ich hätte da mal eine Frage. Ich habe ein P751tm1-G mit einer NVIDIA RTX 2060 wie sieht es da in Zukunft bezüglich Upgrades mit neuen Grafikkarten aus? Braucht es dabei für jede neue Grafikkarte ein neues Bios Mode?
OK die meinen: è—�天Clevo es machbar wäre.
Treiber:
�天Clevo
https://clevo-computer.com/de/support-treiber/
Bios: -------------------------------------------------------------------------------
OK laut HANDBUCH passen nur die da rein !
Intel® Core™ i7-8700 processor (14nm, 3.2GHz, DDR4 2666MHz, 12MB Smart cache, TDP: 65W)
Intel® Core™ i5-8400 processor (14nm, 2.8GHz, DDR4 2666MHz, 9MB Smart cache, TDP: 65W)
Intel® Core™ i3-8100 processor (14nm, 3.6GHz, DDR4 2400MHz, 6MB Smart cache, TDP: 65W)
kann jedoch sein das diese nicht mehr Aktuell ist die ändern das ja ohne Ankündigung…
Wegen dem Bios Upadte könnte man auch alternativ dort vorbeischauen: Schenker XMG Seite und da nach Schenker XMG Apex 15 XMG APEX 15 (ID: XAP15E18) Download Portal (Clevo N950TP6) suchen …
oder diesen Link ONE.de Service-Center - ONE K61-8NB-E (Clevo N960TD) - Downloads
Dann halt einfach ausprobieren um zu sehen ob´s geht ?!
jetzt noch das übliche ; ich übernehme keine Haftung wenn ihr Murks baut !
- - - Updated - - -
- - - Updated - - -
schau mal hier: XMG ULTRA 15 - Dank aktuellster Hardware spielst Du hiermit auf ULTRA
und später kanst dann immer noch die
NVIDIA GeForce RTX 2070 | 8 GB GDDR6 und noch etwas später die NVIDIA GeForce RTX 2080 | 8 GB GDDR6 rein stecken ! das sollte doch eine weile reichen...
