Type: Custom... Min: 8 Max: 4096 InPlace: No Mem: 400 Time: 15
CPU: 3199MHz FSB: 200MHz [199MHz x 16.0 est.]
05.11.2007 15:58
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
2:Beginning a continuous self-test to check your computer.
1:Press Stop to end this test.
2:Press Stop to end this test.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
2:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:FATAL ERROR: Resulting sum was 1.739054055716028e+019, expected: 4.894894718475561e+016
1:Hardware failure detected, consult stress.txt file.
1:Torture Test ran 3 minutes 5 seconds - 1 errors, 0 warnings.
1:Execution halted.
2:Torture Test ran 3 minutes 5 seconds - 0 errors, 0 warnings.
2:Execution halted.
