ATI CATALYST V 4.9 Beta
Jammer
Banned
W.Berlin
Quelle 3dcenter.de (Forum)
The Catalyst 4.9 beta drivers are a sneak peak into future drivers that ATI is continuously working on. They were release mainly for the OpenGL component update, targetting improved Doom3 performance. Having said that, newer generations of hardware will get the most benefit from this driver (X800* series). While I haven't done specific benchmarks, X800 users can see performance increase of 5~30%, depending on the level and the system/hardware type. Regretfully, older hardware, such as 9700's and even 9800's will not get as much benefit. And if paired with a slower system (or with less memory) might see +/- performance improvements.
spz:d
Versions history
1.0.0.362
+ Now timings can be loaded at start up. You must select which profile will be loaded at start up time, insteed of selecting clocks values.
+ Added 2 new hot keys , very usefull for mobile computer users. Will work on desktop system only if your monitor support this interface.
- Turn Monitor Off
- Turn Monitor On
+ Now color settings will not be reset if you change resolution
+ Added option to automaticaly overclock your card if any application required 3D Api (OpenGL/Direct3D)
How it works.
If you enable 2d/3d overclocking you must set which profile shoukd be loaded when application enter 3d mode and which profile load after this application finished. ATT some times can not detect when game use 3d mode. If you find such kind of game, create profile for it.
Also you can create the list of application which should be excluded from auto 2d/3d detecting. Some of the applications already excluded internaly by ATT and never will be monitored.
explorer.exe
atitray.exe
atitool.exe
nvmixer.exe
+ Changes in game profiles
For Game profiles now you can set 3 options:
1. Take no action - ATT will do nothing even if you enable 2d/3d overclocking and game use 3d mode.
2. Custom overclocking - If you set this option ATT will use overclocking profile you provided for this game only. even if 2d/3d overclocking is enabled.
3. Use auto 2d/3d - This option tells ATT to use global 2d/3d profiles. This option has no effect if you disable 2d/3d overclocking. But if you set this option (with global 2d/3d detection enabled) and your application does not require 3D mode, 3D profile anyway will be loaded.
+ Screensave will be disabled while 3D Render window is active.
- Removed "Autodetect Starting Games". Now this option is part of auto 2d/3d overclocking and always ON. It can not be disabled.
- Removed "With CPU Heat" function from Artifact tester. Now tester itself can heat main CPU.
http://www.radeon2.ru/atitray/attsetup.exe
spz:d
