What's New? (2k/XP 2.5.44)
* Based on the Catalyst 4.5 drivers.
* Updated the Omega version of RadLinker (1008), now the Profiler include options
to enable TAA modes and to establish the desired TAA Threshold for D3D apps.
* Added and removed a LOT of tweaks, ATI changed some internal settings and some
old tweaks won't work anymore from now on.
* Fixed support for Mobility 9700.
* Fixed the "Hibernation not working" problem in laptops.
* Added support for the Following laptop wide screen resolutions: 800x480,
960x600, 1024x600, 1024x480, 1280x600, 1280x768, 1280x800, 1680x1050, 1920x1200
* Re-enabled a desktop wide resolution: 1280x768
* Added an EXCLUSIVE new Omega utility which adds the ability to SWAP between
the soft-mod and the normal driver without the need to re-install the whole
drivers. (Thanks to Chris W, Author of RadLinker)
* Removed Artifact Tester 5 from the package. (Sorry Alberto)
* Included the latest version of ATITool. (Thanks W1zzard)
* Since the package has grown in size I will be distributing the installer in
compressed CAB format to save some bandwidth, it must be decompressed using one
of these tools (latest version): WinAce, WinRAR or WinZip. Then run the extracted
file to start installation of the drivers.
http://www.omegacorner.com/drivers/ati/rad_w2kxp_omega_2544.cab
spz
