Asus Realbench -9900K - whea 19 Tech Support
sew333
Banned
Hello. Have an real pain in a.. with stability in Real Bench. Have 9900K oced to 5ghz. Ram: Gskill 2x8GB 3000MHZ XMP
Voltage 1.300v manual,Load Line 6 level,Sync cores 50,all power limits maxed.
So i dont know how to be sure if my system is stable. Sometimes after 15 minutes realbench throw BSOD.Sometimes it will pass 2 hours. So how i can be sure all is stable then? !!!!
One time it pass 2 hours fine in REALBENCH, i am thinking its fine. Next day after 15 min BSOD in REALBENCH.
mb:Asus Prime Z390-A, Noctua NH-D15
Hello, are you stay in USA in cause of the times you wrote here.
It is 2 o clock in the night here.
I have vacation tomorrow, so I am celebrating a bit.
Whitout ECC RAM there is no warranty to be protected on all cases.
But for what do you want it stable at 5GHz?
Be happy that it works in your application used.
Whea error 19 is memory related,
No its BSoD.
0x0000003b
SYSTEM_SERVICE_EXCEPTION
Its random.
Sometimes it pass 2 hours without problem,sometimes it not pass on the same voltage in REALBENCH. Any ideas? Maybe i should bump to 1.310v?
In UEFI voltage prediction for AVX 5000MHZ is : 1.324V. Maybe listen to this and just enter 1.324V?
