AMD + nVidia Fragen!!
Christle
Hallo ich hätte mal gerne gewusst ob es irgendwelche komplikationen geben könnte wenn ich mir jetzt ne gtx 280 einbauen würde
ich habe Folgendes System:
Family AMD Athlon(tm) 64 X2 Dual Core Processor 6400+
Architecture 64-bit Internal Clock 3.2 GHz
Memory slot
Installed Enabled Size 1.00 GB
Form Factor DIMM
Frequency 533.0 MHz
Slot DIMM_A1 [Bank0/1]
Manufacturer None
Type
Type Details -
Total Bit Width 64 b
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 533.0 MHz
Slot DIMM_B1 [Bank2/3]
Manufacturer None
Type
Type Details -
Data Bit Width 64 b
Memory slot
Form Factor DIMM
Frequency 533.0 MHz
Slot DIMM_A2 [Bank4/5]
Manufacturer None
Type
Type Details -
Data Bit Width 64 b
SAMSUNG HD400LJ SCSI Disk Device
Device Drive Type Hard Disk
Name SAMSUNG HD400LJ SCSI Disk Device
Manufacturer (Standardlaufwerke)
Model SAMSUNG HD400LJ SCSI Disk Device
Vendor ID String SAMSUNG
Product ID String HD400LJ
Product Revision String ZZ10
Serial Number
Interface Type IDE
Device Bus Type FIBRE
Capacity 372.61 GB
Drive Letters C:
CD Max Read Speed 0
CD Read Capabilities -
CD Write Capabilities -
DVD Read Capabilities -
DVD Write Capabilities -
SMART Not Supported
Acoustic Management Not Supported
Physical sector size 512 B
Name Windows (TM) Vista Ultimate
Version 6.0.6001
PlatformId 2
Service Pack 1.0Service Pack 1
Suite 256
Product Type 1
Product Version 1
Media Center true
Windows Environment 64-bit
ReadyBoost Devices
Locale DE
Desktop Width 1680 px
Desktop Height 1050 px
Desktop BPP 32 b
Internet Explorer Version 76001
Monitor
Name PnP-Monitor (Standard)
Manufacturer (Standardmonitortypen)
Max Width 1600 px
Max Height 1200 px
Supported Slot Types PCI, PCI Express
Manufacturer ASUSTeK Computer INC.
Model M2N32-SLI DELUXE
Version 1.XX
BIOS Vendor Phoenix Technologies, LTD
BIOS Version ASUS M2N32-SLI DELUXE ACPI BIOS Revision 2101
BIOS Release Date 08/06/2008
BIOS Properties Plug and Play, Flash
Card Slots
Card Slot
Order 1
Designation PCI1
Type PCI
Characteristics 5.0V, PME Signal
Data Bus Width 32 b
Details Available, Short
Card Slot
Order 2
Designation PCI2
Type PCI
Data Bus Width 32 b
Card Slot
Order 3
Designation PCIEX16_1
Type PCI Express
Data Bus Width 0 b
Details In Use, Short
Card Slot
Order 4
Designation PCIEX16_2
Type PCI Express
Data Bus Width 0 b
Card Slot
Order 5
Designation PCIEX4_1
Type PCI Express
Data Bus Width 0 b
Card Slot
Order 6
Designation PCIEX1_1
Type PCI Express
Data Bus Width 0 b
PCI Devices PCI Device
Manufacturer AMD
Location PCI-Bus 0, Gert 24, Funktion 0
Type
PCI AMD HyperTransport(tm)-Konfiguration
PCI Device
Manufacturer AMD
Location PCI-Bus 0, Gert 24, Funktion 1
Type
PCI AMD-Adresszuordnungskonfiguration
PCI Device
Manufacturer AMD
Location PCI-Bus 0, Gert 24, Funktion 2
Type
PCI AMD DRAM und HyperTransport(tm)-Nachverfolgungsmoduskonfiguration
PCI Device
Manufacturer AMD
Location PCI-Bus 0, Gert 24, Funktion 3
Type
PCI Sonstige AMD-Konfiguration
PCI Device
Manufacturer Texas Instruments
Location PCI-Bus 2, Gert 11, Funktion 0
Type
PCI Texas Instruments OHCI-konformer IEEE 1394-Hostcontroller
PCI Device
Manufacturer Silicon Image
Location PCI-Bus 3, Gert 0, Funktion 0
Type
PCI Silicon Image SiI 3132 SATALink Controller
PCI Device
Manufacturer (Standardsystemgerte)
Location PCI-Bus 0, Gert 0, Funktion 7
Type
PCI PCI Standard-RAM-Controller
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 6
Type
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 0
Type
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 3
Type
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 4
Type
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 1
Type
PCI Device
Location PCI-Bus 0, Gert 4, Funktion 0
Type
PCI PCI Standard-PCI-zu-PCI-Brcke
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 2
Type
PCI Device
Location PCI-Bus 0, Gert 0, Funktion 5
Type
PCI Device
Location PCI-Bus 0, Gert 9, Funktion 0
Type
PCI PCI Standard-ISA-Brcke
PCI Device
Manufacturer NVIDIA
Location PCI-Bus 0, Gert 9, Funktion 1
Type
PCI NVIDIA nForce PCI-Systemverwaltung
PCI Device
Location PCI-Bus 0, Gert 8, Funktion 0
Type
PCI Device
Manufacturer (Standard-USB-Hostcontroller)
Location PCI-Bus 0, Gert 10, Funktion 0
Type
PCI Standard OpenHCD USB-Hostcontroller
PCI Device
Location PCI-Bus 0, Gert 10, Funktion 1
Type
PCI Standard PCI-zu-USB erweiterter Hostcontroller
PCI Device
Manufacturer (Standard-IDE-ATA/ATAPI-Controller)
Location PCI-Bus 0, Gert 12, Funktion 0
Type
PCI Standard-Zweikanal-PCI-IDE-Controller
PCI Device
Location PCI-Bus 0, Gert 14, Funktion 0
Type
PCI Device
Manufacturer Microsoft
Location PCI-Bus 0, Gert 14, Funktion 1
Type
PCI High Definition Audio-Controller
PCI Device
Manufacturer NVIDIA
Location PCI-Bus 0, Gert 16, Funktion 0
Type
PCI NVIDIA nForce Networking Controller
PCI Device
Manufacturer NVIDIA
Location PCI-Bus 0, Gert 17, Funktion 0
Type
PCI Device
Location PCI-Bus 0, Gert 22, Funktion 0
Type
PCI Device
Manufacturer NVIDIA Corporation
Location PCI-Bus 0, Gert 13, Funktion 0
Type
PCI NVIDIA nForce Serial ATA Controller
PCI Device
Location PCI-Bus 0, Gert 13, Funktion 1
Type
PCI Device
Location PCI-Bus 0, Gert 13, Funktion 2
Type
PCI Device
Manufacturer NVIDIA
Location PCI-Bus 1, Gert 0, Funktion 0
Type
PCI NVIDIA GeForce 9600 GT
580 Watt Netztéil
und nun wollt ich wissen ob ihr mir noch irgendwelche tips geben lönntet wie ich mein system konfiguriere!!
sorry ich denke des sind zu viele infos oder?:confused::confused::confused:
Sorry - aber 5 oder 6 Zeilen hätten ausgereicht, um die vorhandene Hardware zu listen :(
NV grakas laufen auf amd systemen und atis grakas auf nv chipsatz. SLI wird nicht möglich sein aber sonst macht es der graka egal auf welchen mobo es sitzt.
das größte problem das bei dir autreten wird, ist dass deine cpu die grafikkarte extrem ausbremst! das bringt dir einen verlust bei der cpu/gk kombi ca 15-20% weniger leistung als die grafikkarte zu leisten im stande wäre.
eine 260er oder die hd 4870 wären bei dir besser angelegt. werden zwar auch ausgebremst aber net so viel wie die 280
so ist es!
aber deine cpu ist nicht die allerschnellste und die karte hat schon ne menge dampf.
was für einen monitor hast du denn eigentlich?
die infos sind doch eh aus nem systool rauskopiert und völlig unnütz
Das wird ohne Probleme funktionieren.
Bei deiner Auflösung wird der Prozessor eh kaum oder nicht limitieren.
Auf dem Board soll sogar der X4 920/940 laufen.
die limitierung hängt auf jeden fall von der verwendeten software ab, das ist richtig.
aber generell ausschliessen kann man sie nicht, jedoch wird sie bei steigender auflösung immer geringer.
