Abit Fatal1ty AN8 SLI *Sammelthread*
Hunte®
Göttingen
so ich habe grade auf die abit page geschaut und habe dort die pressemitteilung gelesen, von dem Fatal1ty AN8 SLI.
Hier einige Infos:
CPU
* Supports AMD Socket 939 Athlon 64/64FX Processors
* With 2GHz system bus using Hyper Transport™ technology
* Supports AMD CPU Cool 'n' Quiet Technology
Chipset
* NVIDIA NF4 SLI single chip
* NVIDIA Gigabit Ethernet with NVIDIA Firewall
* Supports NV SATA 3G RAID
NVIDIA SLI Technology
* Two PCI-Express X16 slots support NVIDIA Scalable Link Interface
* Increase bandwidth of the PCI Express™ bus providing 60x the bandwidth of PCI
Memory
* Four 184-pin DIMM sockets
* Supports dual channel DDR400 non-ECC un-buffered memory
* Supports maximum memory capacity up to 4GB
ABIT Engineered
* ABIT µGuru™ 2003 Technology
* ABIT OTES™ Technology
* ABIT AudioMAX™ Technology
* ABIT CPU ThermalGuard™ Technology
NV SATA RAID
* Serial ATA 3Gbps data transfer rate
* Supports SATA RAID 0/1/0+1
NV GbE LAN
* NVIDIA Secure Networking Engine
NV Firewall
* Native NVIDIA Firewall
IEEE1394
* Support IEEE 1394 at 400 Mb/s transfer rate
ABIT AudioMAX
* High quality 7.1-channel Audio Card
* Optical S/P DIF Input/Output
* Supports auto jack sensing
Internal I/O Connectors
* 2 x PCI Express X16, 2 x PCI Express X1, 2 x PCI slots, 1 x AudioMAX
* Floppy Port supports up to 2.88 MB
* 2 x Ultra DMA 133/100/66/33 IDE Connectors
* 4 x SATA 3G Connectors
* 3 x USB headers, 1 x IEEE 1394 header
Back Panel I/O
* ABIT Dual OTES
* 1 x PS/2 Keyboard, 1 x PS/2 mouse
* 1 x IEEE 1394
* 4 x USB, 1 x RJ-45 LAN Connector
Form Factor
* ATX form factor 305 x 245mm
Accessories
* Guru Panel
* ABIT AudioMAX Card
* SLI Connector Bridge
* SLI Switch
* SATA cable x 4, ATA 100 IDE Cable x 1, FDD cable x 1
* I/O shield x 1
* CD Title x 1, SATA Utility Disk x 1
* A5 standard User's Manual x 1, B5 multilingual Quick Installation Guide x 1
* Jumper Setting Label x 1
und es soll laut abit noch in diesem monat erhältlich sein.
Also kriegen wir es dann so ab Juli/August :p
Das kennen wir ja schon.
Ausser, dass es 2 PCIe Plätze gibt, gibts ja eigentlich keine Veränderung
@monstersemmel
Es wird sich vielleicht schon was aendern
Bis zum Liefertermin sollte ja die OTES Kuehlloesung passiv sein. Hoffen wir mal alle, dass dies auch so geschehen wird...
die otes-kühlung ist sowieso so überflüssig wie nur irgendetwas, alle anderen boards kommen ja auch ohne aus. das gleiche gilt für diese komische Speicherkühlung. dann lieber nen richtigen 80mm+ lüfter drüberhängen und sich oropax sparen. also eigentlich nur viel lärm um nichts (wörtlich)
der stromanschluss ist für 2 Grakas, damit die pcie-slots genug saft liefern können.
wär nett, wenn einer der besitzer mal den onboardsound testen könnte. der soll ja bei abit sli und an8 ultra dolby lizenz haben. kann er mit ner audigy2 zs einigermaßen mithalten?
wo hast du den Blödsinn mit der Dolby Lizenz her :rolleyes: auf der Audiomax Card ist ein Realtek 850 Chip.
Die Dolby Lizenz hat das Fatal1ty für den Intel Chipsatz.
hab nur was von der dolby lizenz gelesen, aber überlesen, dass das nur für die intel platform ist. hab das nicht erwartet
Ähnliche Themen
Antworten
9
Aufrufe
800
