Ja.... Uri Geller ....Der macht alles heile. Der macht auch die XBOX360 leiser alleine durch seine Kraft.
UT3 kommt auch für die 360? Dachte das is nen PS3 Exkl.??
Ja und dann legt er los. Macht alles heile.
aber achtung, vll hüpft sie sonst noch runter... aber nu wieder btt
"No, the edge comes in the fact that the PS3 installs a large amount of game files to the hard drive, dramatically reducing load times between stages and cinematics. I've timed the game on both systems numerous times, and each time has been consistently in the PS3's favor. Transitions to gameplay from starting menus are relatively close, frequently within half a second or so of each other, but when you're loading up a cutscene or having another pause in the action, the 360's times are easily three times that of the PS3."
sowie nahezu einheitliche Ladezeiten
The reason there are less visible jagged edges on the PS3 version is that it smoothes them out by blending frames (what I’ve called “motion blur” here), whereas the Xbox 360 version has no need to blend frames, as it has “real” 2xAA.
It has further transpired that without the blending of frames, the PS3 would have no AA at all. This method of Anti-aliasing is not new or uncommon, but it can have disadvantages, as shown in the above still images.
