[Sammelthread] Crysis Performance & Tweaking
Hier im übrigen der Komplette changelog... für uns ist eigentlich nur der mittelteil interessant.
Fixes
* Fixed: Potential crash in D3D10
* Fixed: Orange boxes apearing when hispec savegame loaded into lowspec game.
* Fixed: Inconsistent damage dealt to vehicles when shot by LAW.
* Fixed: Reflection resolution on D3D10, MultiGPU reflection update fix
* Fixed: Memory leak with FSAA modes
* Fixed: Infinite ammo hacks.
* Fixed: Memory leak in D3D10 when switching screen modes
* Fixed: Muti optimizations
* Fixed: When player melees during gun raise animation, their gun will be in a permanantly raised position.
* Fixed: Crash when loading savegame with level exported recently by editor
* Fixed: Virtual keyboard does not function properly when a game pad is connected
* Fixed: Users can lose the ability to look around with the Right Stick
* Fixed: Setting screen resolution to "default" stops user from selecting last resolution
* Fixed: Bug when changing resolution in D3D10
* Fixed: Issues with Depth of field and water droplets in D3D10
* Fixed: Crash on NaN warning
Updates
* Added: Motion Blur UI and V.SYNC UI options
* Optimized: Motion blur
* Optimized: FSAA (Full Scene Anti-Aliasing)
* Optimized sound id implementation
* Enabled VSync functionality in D3D10
* New benchmarking files for ice CPU benchmark.
* http/xmlrpc password protected remote control session
* Marked debug cvars as cheat
* F12 (screenshot) now works in restricted mode as well
Tweaks
* Reduced LAW splash damage vs. infantry in PowerStruggle mode
* Slowed Rocket projectile speed down in MP slightly
* Disabled automatic turret bounding boxes on vehicles to prevent issues with LAW hit detection
* Reduced grenade explosion radius in multiplayer
* Clamped water tesselation to avoid cheating in MP
* MultiGPU improvements with depth map updates
Hat von euch einer evtl. einn ähnliches Sys wie meins (mit Vista 64) und kann mir mal sagen wie ich es am besten zocken kann (DX9 oder DX10, niedrige Auflösund dafür mehr AA oder umgekehrt....)
Hab zwar schon viel ausprobiert aber bin damit nicht wirklich zufrieden.
Der MP ist geil :confused:, besser als der COD4 Schrott.
naja COD hat 100.000 Spieler Crysis 500 ich glaub das sagt alles.:shot: Vorallem weil bei Crysis eh jeder nur diesen powerstruggle modus spielt was anders hat das ja auch nicht.
Und woran liegt das niemand crysis spielt, weil die gaylords es wie bei FarCry nicht geschissen bekommen, schaus dir doch mal an, am Anfang waren alle da, es gab Bugs, aber alle waren optimistisch, die Monate zogen ins Land und die Spieler merkten das Crytek nichts macht, tja und wir alle wissen wie schnellebig die community ist...
Hm, hab im GPU Bench kein Frame mehr als vorher, und auch ingame is es nich merklich besser. Aber allgemein fehlen mir irgendwie 5FPS, irgendwas läuft da nicht ganz richtig..
bei mir unter Vista 64 und Crossfire auch keine Verbesserung sichtbar... Hab immernoch diese Performanceinbussen in der Recovery-Map sobald ich in die Richtung der Berge schaue (von 50FPS auf 9FPS)... Das selbe in der Onslaught-Map im Panzer wenn ich in Richtung des grossen Berges schaue, der langsam abbröckelt und der Alientempel langsam zu sehen ist. Nur noch eine Diashow... dreh ich mich weg hab ich fast 50FPS.
Ich versteh das nicht. :confused:
..super Patch muss ich sagen... :rolleyes:
Sorry aber woher nimmst du die Aussage ?
Völliger Schwachsinn den du da von dir gibst aber mit deinen knapp 100 Beiträgen musst du es ja wissen .
Also entweder hab ich was verhaun oder die 4 Monate Arbeit warn fürn arsch.
Nach der installation stehen alle Ki-Gegner nur noch sinnlos inner Welt rum (bemerkenen ein zwar, aber auf ne Reaktion wartet man vergeblich). Die Save-Games hats auch noch verhaun ...also ich weis nich...
Bis jetzt würde ich allerdings gerne den beiden Yerli Brüdern fett in die Eier treten!
Sind aber Drei :fresse:
Kann mal einer den originalen CVar Ordner upen nach erfolgreicher Patchinstalierung. Ich hab mein getweakten drin und wollte nochmal schaun ob sich was geändert hat. :)
Erster Benchmarktest vor und nach Installation von 1.1 Patch.
Muss dazusagen das sind meine Multiplayer Einstellungen.
Alle beide Tests durchgeführt mit Crysis Benchmark Tool.
Version 1.0:
08.01.2008 18:33:31 - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX10 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: Custom
Custom Quality Values:
VolumetricEffects=Medium
Texture=Medium
ObjectDetail=High
Sound=Medium
Shadows=Medium
Water=Medium
Physics=High
Particles=Medium
Shading=Medium
PostProcessing=Medium
GameEffects=Medium
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 46.05s, Average FPS: 43.43
Min FPS: 34.89 at frame 1953, Max FPS: 55.50 at frame 1743
Average Tri/Sec: 45655904, Tri/Frame: 1051209
Recorded/Played Tris ratio: 0.87
!TimeDemo Run 1 Finished.
Play Time: 44.17s, Average FPS: 45.28
Min FPS: 34.79 at frame 1963, Max FPS: 55.71 at frame 1761
Average Tri/Sec: 48227196, Tri/Frame: 1065169
Recorded/Played Tris ratio: 0.86
!TimeDemo Run 2 Finished.
Play Time: 44.32s, Average FPS: 45.12
Min FPS: 34.62 at frame 1965, Max FPS: 55.81 at frame 1762
Average Tri/Sec: 48094684, Tri/Frame: 1065823
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX10 1680x1050 AA=No AA, 32 bit test, Quality: Custom ~~ Overall Average FPS: 4520
Version 1.1:
08.01.2008 18:42:06 - Vista 64
Texture=Medium
ObjectDetail=High
Sound=Medium
Shadows=Medium
Water=Medium
Physics=High
Particles=Medium
Shading=Medium
GameEffects=Medium
Play Time: 43.06s, Average FPS: 46.45
Min FPS: 36.94 at frame 1978, Max FPS: 58.53 at frame 116
Average Tri/Sec: 48799920, Tri/Frame: 1050670
Play Time: 41.44s, Average FPS: 48.26
Min FPS: 36.29 at frame 1972, Max FPS: 63.65 at frame 90
Average Tri/Sec: 51417556, Tri/Frame: 1065366
Play Time: 41.59s, Average FPS: 48.09
Min FPS: 35.75 at frame 1959, Max FPS: 63.65 at frame 90
Average Tri/Sec: 51256996, Tri/Frame: 1065778
Completed All Tests
Run #1- DX10 1680x1050 AA=No AA, 32 bit test, Quality: Custom ~~ Overall Average FPS: 4817,5
Also ich finde ein wenig hat der Patch schon gebracht auch wenn es viel zu lange gedauert hat bis er raus kam.
Totaler Bullshit. Guck mal auf mein Ranking, das ist ein wenig über 500. :lol:
So hab auch Patch drauf, was für ne Zeitverschwendung. Hab das Gefühl das es beschissener läuft als vorher. Bei mir funktionieren nicht mehr alle Spielstände und mir fehlte plötzlich die Waffe nach dem Laden. Schrott!!!
Oh schaut mal, wenns schon keine performanceschübe gibt, so gibt es doch ein neues Alienfeature :)
schöner blauer Suchscheinwerfer ^^
.maSk kannst du mal den orig. Cvar Ordner hochladen (von der gepatchten Version) hab mein nichmehr :(
Mit DirectX9 bingt es bei mir keine verbesserung! Aber unter DirectX10 bringts so 3-4fps.
sry war ebend noch einkaufen :)
€: hab das hier noch gefunden
Danke an PCGH für die schnellen Tests :)
Also wieder einmal für die Katz danke Crytek das ihr uns so heiß drauf gemacht habt und das es wieder einmal nichts geworden ist.
Nicht desto trotz habe ich aber das Gefühl als wenn das Spiel runder läuft, nicht viel, aber die FPS Einbrüche scheinen bei schnellen Drehungen nicht mehr so arg häufig vorzukommen...
Ja ich hab mit 10fps mehr gerechnet. Also nen Performence Patch sollte spürbare Unterschiede und keine meßbaren haben. Ich warte mal noch den neuen Nvidia Treiber ab, der für den Patch kommen soll aber so richtig glaube ich nicht mehr an einen fps boost und 1-2 fps mehr kann man ja nix anfangen.
Nun mal ehrlich leute
Crysis is saugeil
vorallem die grafik
und man kann sich nicht über die performande aufregn weil mit ner graka um 150 euro ist man schon gut dabei
crysis läuft sogar auf meinem lapi -> siehe signatur
zwar nur mit ca 15 fps aber es läuft
was man von spielen wie rainbow six vegas nicht unbedingt behaupten kann
de anforderungen sind im high bis very high bereich astronomisch doch sollte fast jeder in der lage sein crysis mindestens auf niedrigen einstellungen zu spielen
und jeder von euch der schon mal versucht hat etwas mit dx zu programmiern weis wie extrem viel aufwand das ist
also ich finde die leute von crytek haben da ganz gute arbeit geleistet
ein großes lob meinerseits!
MFG BigBearHL
wer will schon auf niedrig spielen :) also ich find alles unter high siet aus wie far cry :d
lol was soll den das jetzt :fresse: will den patch install.aber dann frägt er nach der original.cd lol ja und woher jetzt nehmen??(game online gekauft und downgeloadet) sowas hatte ich ja noch nie..man crysis langweilt mich immer mehr!!!
Jop finde ich auch, die Performance ist für das gebotene doch voll in Ordnung.
Es war doch vorher schon klar, dass man da keine FPS Sprünge von 10FPS erwarten kann... das ist doch nur naives Wunschdenken...
