kartoffelluder
Semiprofi
ja!!
in NTFS
ntfs is immer besser..und schneller als fat32
fat 32 kann eig. nur 4 gig verwalten..
in NTFS
Das interessante habe ich mal markiert.. viel GlückChanging a volume's existing file system can be time–consuming, so choose the file system that best suits your long–term needs. If you decide to use a different file system, you must back up your data and then reformat the volume using the new file system. However, you can convert a FAT or FAT32 volume to an NTFS volume without formatting the volume, though it is still a good idea to back up your data before you convert.
xD ... naja danke jungs für die hilfe ... mom, kurz formatieren![]()
