Field Value
CPU Properties
CPU Type QuadCore Intel Core 2 Quad Q6600, 3000 MHz (9 x 333)
CPU Alias Kentsfield
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
Original Clock 2400 MHz
Min / Max CPU Multiplier 6x / 9x
Engineering Sample No
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ASC, Full-Speed)
Multi CPU
Motherboard ID TEMPLATE ETEMPLATE
CPU #0 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 3005 MHz
CPU #1 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 3005 MHz
CPU #2 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 3005 MHz
CPU #3 Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 3005 MHz
CPU Physical Info
Package Type 775 Contact LGA
Package Size 3.75 cm x 3.75 cm
Transistors 582 million
Process Technology 65 nm, CMOS, Cu, Strained Si
Die Size 286 mm2
Core Voltage 1.288 V
I/O Voltage 1.288 V
Typical Power 130 W
Maximum Power 168.8 W
CPU Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
